para
bugbrand
Posted: Sun Sep 02, 2007 12:31 pm Post subject:
Steven, this is freaking exciting! Anyone else ever heard of a pot variable capacitor 'cos I certainly haven't.?!.
I will definitely have a play sometime.
I'm sure others will agree ---> thanks for sharing this! _________________ http://www.bugbrand.co.uk
para
Posted: Sun Sep 02, 2007 12:34 pm Post subject:
its so simple that i'm shocked i haven't stumbled on someone else even trying it. at least not like this and certainly not variable
steven |
bugbrand
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Mon Sep 03, 2007 11:37 am Post subject:
WOW!
So max capacitance is 100pf, variable to zero?
Does it matter what the size of the cap is?
Veerry interesting!
C |
para
Posted: Mon Sep 03, 2007 2:42 pm Post subject:
no the minimum cap size is the 100pf or whatever you use in there, it can be anything and the amp multiplies it so it gets huge and off the charts. like over 100uf. i don’t have any way to measure it so i just substituted a 100uf for the mimeo in the same circuit and got similar results. just guessing. then if you want to define the range you choose the appropriate pot value to limit the amount it amps the capacitance
steven |
revtor
Joined: Oct 05, 2005 Posts: 79 Location: NewJersey, USA
Posted: Mon Sep 03, 2007 7:20 pm Post subject:
Steve, is this one of your "parasite" boards?? _________________ beep blurp flurrrp fiszzzzp pow bakka wakka wakka -A synth freaks mental notes. |
Funky40
G2 patch files: 5
Posted: Tue Sep 04, 2007 2:06 am Post subject:
thanks para
It's very interesting |
para
Posted: Tue Sep 04, 2007 4:28 am Post subject:
yes the design is used in a parasite but there is a bit more to that design regarding power and stuff.
also i think i should say that this sort of thing is generally called a "capacitance multiplier" when used at a fixed setting. my use of the term “variable capacitor” may be throwing people off.
steven |
germaniac
Posted: Tue Sep 04, 2007 10:54 am Post subject:
Hey Steven, thanks for posting this schemo--very cool!
I've seen a couple "variations" on this, but yours looks the simplest (a good thing IMHO). Here are two more for reference, neither of which I have tried. They may work as well, better, or worse for all I know. With all due thanks and credit to the originators of these designs/schemos.
Regards,
Joe
9.49 KB |
| Viewed: |
9556 Time(s) |
62.38 KB |
| Viewed: |
206 Time(s) |
para
Posted: Tue Sep 04, 2007 1:52 pm Post subject:
my last response was lost to board malfunction… lame.. it was something like
interesting thanks. but those seem to be the opposite of what mine does. they take a cap and make it smaller and mine takes it and makes it larger.
so with theirs if you use a 100n you get about 0n to 100n ( or close)
and with mine using a 100n you get 100n to over 100uf ( or more i don’t have anyway to measure it )
both are usefully for different situations though
steven |
Joined: Apr 03, 2004 Posts: 24500 Location: The Netherlands, Enschede
Posted: Tue Sep 04, 2007 2:30 pm Post subject:
| para wrote: | | my last response was lost to board malfunction… |
Yes, unfortunately :
| Quote: | | From time to time the forum will be unavailable for a few minutes while we are working on the software. |
and that might loose some stuff as well, sorry. _________________ Jan
para
Posted: Tue Sep 04, 2007 2:56 pm Post subject:
no no… i wasn’t complaining. i completely understand and sympathize. this board is huge and has enough mods and stuff to make upkeep and server issues a serious pain. i had just forgotten most of what i had written
you guys can do no wrong in my eyes!
steven |
Posted: Tue Sep 04, 2007 3:16 pm Post subject:
| para wrote: | | i had just forgotten most of what i had written |
I know, the computer is my memory
What I do from time to time when the board is not responsive or I pick up bad vibes or anything, is to copy the text I just typed to the clip board, just in case. And when you did hit send already the browser's back button will still get your text back I think ... in firefox. (edit: yes it does)
Thanks for your kind words  _________________ Jan
para
Posted: Tue Sep 04, 2007 3:30 pm Post subject:
| i keep notepad open all day for exactly that reason but i had just closed it to clean up my desktop. the one time i need it... |
shawn
Posted: Sat Sep 15, 2007 10:37 pm Post subject:
| Any luck with any of you guys trying this? I haven't had much luck yet. I recall you saying that there was some trick into powering it? Would it be bipolar -/+ or gnd/+? |
para
Posted: Sat Sep 15, 2007 10:45 pm Post subject:
? it works for sure and no there is no trick to it. you can power it however the chip you choose wants to be powered.
the + and - are the polarity of the cap similar to an electrolytic
steven |
synthmonger
Posted: Sun Nov 04, 2007 11:41 pm Post subject:
| Not having much luck with it. I tried a few different ways of powering it and I'm not able to vary the capacitance. You sure this schematic is all good? I need something like this to vary the pitch in my MT240 ;X |
para
Posted: Mon Nov 05, 2007 12:36 am Post subject:
its been months since i messed with it on the breadboard and then i copied the scheme - haven't revisited it at all. some day soon though.
i was using a 258 at the time i think, with just a 9v for power, and i played with it for days so i was not hallucinating. it did work
steven |
synthmonger
Posted: Mon Nov 05, 2007 1:23 am Post subject:
Were you using it on a keyboard or anything? I'm still having such a minimal amount of pitch change with my mt-240 It goes about down about 1 semi-tone. I can swap the onboard caps to a max of 300pf before it gets too low and cuts out, so I know the pitch can go down several octaves.
I tried it out with a basic 40106 oscillator and was getting the same effect.
I tried powering it with a 9v battery, two 9v batteries, and a maxim +/-9V chip with a 9VDC jack.
Would it be possible to test it out on a toy or something? The thing barely takes a minute to breadboard. I would reallllllllllllllllllllllllllllllllllly appreciate it  |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
para
Posted: Mon Nov 05, 2007 1:29 am Post subject:
just to be clear this is a multiplier, it takes the given value and increases it. it will not make it smaller.
i only tested it on a 40106 osc i think.
s |
para
Posted: Mon Nov 05, 2007 2:46 am Post subject:
i don't know what to say. i just spent 45 minutes trying everything i could think of and it does not work. i really wish i could go back in time right now.
i went threw all of my notes and research and shit and boarded it up with a tested 40106 osc using a 358 with a single supply and a 072 with a bipolar and grounding the cap to Vref and the rail and it does not work as it did.
i feel like a real asshole, but it really did work. like i said i spent days playing with it fine tuning it and shit and i'm pretty sure i tested it in a couple other things like my shitty vco as a timing cap and stuff and it worked in everything, if not i wouldn’t have made the pcb’s which i guess will be garbage now unless it’s an easy fix. i have to have missed something going from the board to scheme. i was working with like 20 different designs on the table at once so i guess it was bound to happen. sadly i don't have the time to mess with it anymore for a long while. i'll leave it boarded as long as i can before i need that for something else so i can play with it when i get ideas. as soon as i have it working again i'll post the correction.
you can start the name calling now.
steven |
sneakthief
shawn
Posted: Mon Nov 05, 2007 10:18 am Post subject:
| Good to know that I wasn't the only one to get this working but also sad to hear that you made pcbs for this already! My only advice is possibly finding someone who can replicate your findings in the future to prevent that from happening. |
