mixer/multiple circuit?
Page 1 of 1 [6 Posts]
Nikmis
PostPosted: Thu Sep 06, 2007 5:13 pm    Post subject: mixer/multiple circuit?
Subject description: first time caller, long time listener
what do people recommend as the best and easiest ways to make a 3-in mixer with 3 outputs thats good for preserving control voltage signals, like pitch CV, as well as audio? it doesn't seem too far out to me, but i couldn't find anything anywhere.
crashlander42
PostPosted: Thu Sep 06, 2007 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built the 1u and 2u audio/CV mixers from Yusson's site last week and I'm just as pleased as can be with them both. I've used them both for mixing audio as well as CV and they've worked fine. If you wanted more outputs on it you could always add a distributor. Which is the module-next-door on my synth.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
Dave Kendall
PostPosted: Fri Sep 07, 2007 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
These are very useful, and small too......
They've got 2 outputs not 3 though.
Nikmis
PostPosted: Fri Sep 07, 2007 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking of both of those, actually. But with the CGS mixer, would adding an extra output affect the circuit at all? with the Yusynth Mixer/Mfos distibutor combination, I suppose I could use them both together. They are simple enough, as well. And the yusynth and cgs schematics are pretty much the same, just the opamp setup, and then another because its inverted.
so that part is ok. but here is probably a dumb question; Does the MFOS distibutor work fine for audio as well.
Funky40
G2 patch files: 5
PostPosted: Fri Sep 07, 2007 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I build all my Modules with multiple outs.
In the past i just added some sockets without changing something.
Today i replace the outresistor with a wire,
and then i solder to each socket a own out resistor.
The newer mixer has a bufferstage behind the Mixer with TL072,
the older have not.
It works everything for me ! but it might not all be perfect Wink
goldenechos
PostPosted: Fri Sep 07, 2007 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
HIgh precision CV summing can be tricky. The op-amp choosen can have an impact on accuracy. You need something with low input bias and offset currents. I have seen the TL072 used with good success.
Try a combinationn of a resistor and low value trimmer in the feedback path of the second opamp so that you can trim to exactly 1V/ oct. (if that is what you are summing). If you are concerned with droop due to tapping multiple outputs I would suggest non-inverting followers (again, low input bias and offset currents) on each tap.
Probably you CV ins are fairly high impedence though, and the combination of that with the option to trim in more gain should set you up nicely.
TR
