Photon
EdisonRex
Audio files: 172
Posted: Mon Sep 24, 2007 7:41 am Post subject:
Those plastic toggles were quite good, actually. Ingenious, in fact. Beat the crap out of those little bat switches.
I think that colour scheme, either one would be radical. _________________ Garret: It's so retro.
Randaleem
Joined: May 17, 2007 Posts: 456 Location: Northern CA, USA
Posted: Mon Sep 24, 2007 8:06 am Post subject:
| EdisonRex wrote: | Those plastic toggles were quite good, actually. Ingenious, in fact. Beat the crap out of those little bat switches.
I think that colour scheme, either one would be radical. |
Agree about the toggles. When everything was entered in by switches; they were pretty nice to use. As Edison sez; there's no way we could've flipped the hex on bats as fast as we could with these, hex.load.hex.load.
Here's a couple pics of a new clone of the one I used to toggle a bit back in high school.<G> Then we got a '33 teletype and life was much improved!
The IMSAI Has the right number of toggles too...
It appears they're making some different updated clones (note the second pic), so this may be a good resource for finding the switches, etc.
These pics came from: http://www.imsai.net/
Fond memories.
Kind regards,
Randal
36.5 KB |
| Viewed: |
8982 Time(s) |
58.62 KB |
| Viewed: |
285 Time(s) |
clickmrmike
Posted: Mon Sep 24, 2007 8:27 am Post subject:
0.1% resistors? |
Anyone have a source for 0.1% resistors (through hole) stateside? The only place I can find is Mouser; and I'm not thrilled about paying US$1.37 each for them for the 20 needed in the Klee.
click! |
Randaleem
Posted: Mon Sep 24, 2007 8:49 am Post subject:
Re: 0.1% resistors? Subject description: get 1%'ers and sort 'em! |
| clickmrmike wrote: | Anyone have a source for 0.1% resistors (through hole) stateside? The only place I can find is Mouser; and I'm not thrilled about paying US$1.37 each for them for the 20 needed in the Klee.
click! |
Hi Mike,
You don't need to get those if you're willing to do a bit of sorting. Just get 1%'ers. I remember reading a statistical analysis (backed up by a practical experiment) that said you could find a match within 4-8 pulls, working from a typical modern mfrs. output.
So buy 200 (20neededx8pulls worst case=160) and you'll have 'em covered. FWIW, Scott has posted that he also did it this way. And bumped up the spec because not everyone will want to do the sorting. (And he added that at the time he didn't realise the R's were that expensive, and again suggested sorting instead.
Kind regards,
Randal |
Scott Stites
Audio files: 96
Posted: Mon Sep 24, 2007 12:53 pm Post subject:
I matched the ones on the breadboard. Bill sent me some 0.1%'s that I believe are the same as in his kit, and I used those on the protobuild. Probably a difference between BB and PCB, but things sure seem a lot tighter on the proto.
I think there were some cheaper alternatives out there?
E-Rex and Photon - one cool thing to put on a panel would be a set of pushbutton switches for the range control. I find myself finding variations that mesh with different intervals. With the rotary switch, one has to plow through the ranges to get from one to the other. Pushbuttons would let you jump from one to the other. Perhaps Andy's special pads on the PCB could be used for that, too. The external range input is good for that, too.
I've learned that, if I want to sleep, it's best just to avoid turning the Klee proto on.
Joined: Jan 31, 2003 Posts: 18256 Location: Durham, NC
Audio files: 227
Posted: Mon Sep 24, 2007 2:29 pm Post subject:
I built one of those IMSAI's when they first came out. The ALTAIR 8080 was the first. I went with the new technology. I learned a lot. Started programming in assembly, wrote my own multi precision integer math package. Microsoft's first product, AFAIK, was Basic for these 8080 type computers.
But this is Off Topic... _________________ --Howard
my music and other stuff |
Posted: Mon Sep 24, 2007 6:29 pm Post subject:
| Quote: | | But this is Off Topic... |
Ah, but still great computing history !!
| Quote: | wrote my own multi precision integer math package
Oh yes, can appreciate that man ....
I wish I still had my old wire wrapped 8085 circuit boards from college
Bill |
Posted: Mon Sep 24, 2007 6:39 pm Post subject:
Well, here is the entire finished Klee with the power supply mounted. Another view of just the power supply and another of an example of some of the modification we were doing during the testing. Keep in mind that the finished circuit boards will have no such components hanging onto the IC's like this. All the changes are fully incorporated into the PCB design. These two resistors are "lap" soldered right onto the pins of the operational amplifier legs. This particular modification added 140 millivolts hysteresis to the clock and load input comparator amplifiers.
Bill
183.65 KB |
| Viewed: |
257 Time(s) |
177.92 KB |
| Viewed: |
225 Time(s) |
157.77 KB |
| Viewed: |
221 Time(s) |
Posted: Mon Sep 24, 2007 6:48 pm Post subject:
| Quote: | | I matched the ones on the breadboard. Bill sent me some 0.1%'s that I believe are the same as in his kit, and I used those on the protobuild. Probably a difference between BB and PCB, but things sure seem a lot tighter on the proto. |
Yes Scott, that is correct, the kits will be 100K 0.1% resistors. The only difference with the kitted ones are that they will be 1/8W but will fit very neatly onto the analog board. My cheaper source for the 1/4W dried up
I will resort to matching only if all possible, cheaper, sources have all but dried up on me. I just don't want to pay upwards of $ 0.40 for a single freaking resistor and I don;t want to pass such a cost to the consumer
Bill |
Dave Kendall
Posted: Tue Sep 25, 2007 4:47 am Post subject:
| Quote: | | one cool thing to put on a panel would be a set of pushbutton switches for the range control |
Would this help with that? Pins 14 thru 17 of the 74C922 provide latched 4 bit BCD outputs that could be useful too. Although a bit pricey, the 74C922 looks like a very useful IC.
Dave |
Posted: Tue Sep 25, 2007 5:16 am Post subject:
That is a beautiful little circuit Dave! That would make a very nice optional extra for the Klee. Ken comes up with some great ideas hey? The chip is a bit pricey, (AU$30) but worth every cent for what it does. _________________ What makes a space ours, is what we put there, and what we do there. |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Tue Sep 25, 2007 7:09 am Post subject:
from 200 pcs. of 1% resistors not one is 100K. most of them are 99-99.5
will those do right or i have to try another batch? |
Posted: Tue Sep 25, 2007 7:18 am Post subject:
The resistors in question need to be matched "to each other" it's a ratio thing. So the important thing is how similar they are, not actually how close to 100K they are. If you have 25 of them which are between 99.2 and 99.3 then that's fine. I got 100 or so, measured them, and layed them out on a piece of paper with boxes marked 99.5, 99.6, 99.7 etc. I actually ended up with most in the 100.0 and 100.1 boxes, so those are the ones I used. _________________ What makes a space ours, is what we put there, and what we do there. |
a.b.o.z.
G2 patch files: 4
Posted: Tue Sep 25, 2007 7:22 am Post subject:
oh then I'm cool.
thnx uncle |
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Tue Sep 25, 2007 5:30 pm Post subject:
state machine,
that looks a lot like a pc power supply - is it one?
i thought the consensus was that pc power supplies are bad for synth use,
OTOH, the klee is not a synth...
please enlighten me. |
Posted: Tue Sep 25, 2007 6:36 pm Post subject:
| Uncle Krunkus wrote: | The next thing I'm going for are 4mm * 6mm long, Countersunk, Hex head, Black. And I reckon they'll have 'em too. You should have seen the rows of cabinets!  |
Yep, they had 'em. They look very professional too. I got 30 for about AU$6  _________________ What makes a space ours, is what we put there, and what we do there. |
Adam-V
Posted: Tue Sep 25, 2007 6:57 pm Post subject:
Can someone please point me in the direction of the latest schematics for the electro-music Klee? I'm struggling to find them; the only link I've found so far points to a non existent zip file of Uncle K's strip layout.
Adam-V |
Posted: Tue Sep 25, 2007 7:22 pm Post subject:
Scott and I decided to hold off on posting the final schematics for the EM Klee, just in case it may have sparked competition for the PCB. Everyone who orders a set of PCBs will get a copy of the schematics, as well as the interconnect (which has been posted) plus build notes, operations manual etc. etc.
No doubt, at some time further down the track, Scott will release the final schems publicly, but we wanted to ensure the financial support which the EM Klee PCBs will pump into electro-music.com first. _________________ What makes a space ours, is what we put there, and what we do there. |
Adam-V
Posted: Tue Sep 25, 2007 7:29 pm Post subject:
OK, Fair enough. I was kind of hoping to peruse them for the sake of customisation but I can wait for my PCBs to arrive before I do that.
Adam-V. |
Randaleem
Posted: Wed Sep 26, 2007 1:29 am Post subject:
| State Machine wrote: | | Generally the frequencies used by the pulse width modulators inside <modern> switching power supplies will not be a problem when using them in audio applications when properly utilized. Lots of audio gear now has switchers powering their circuits. The debate of using switchers over linear supplies reach religious proportions. I say, if you can't hear any difference, then use it. |
Bill,
Excellent comment! (I added a <bold> modifier to your quoted text above)
Like you say; this is one of the religious topics! And like many religious things; it probably has its roots in things of long ago?
As with every other electronic component, Switchers have been VASTLY improved over the years. Their strengths and limitations have become better understood, and their designers have optimised them for uses more varied than before.
IMO part of the problem is that the surplus market has a wide array of switchers available at incredibly great prices. One should keep in mind that moreso than with linear supplies, a surplus switching PSU is usually "tailored" to its intended application. This includes things like allowable noise and its frequencies, as well as load variation dynamics and response, etc. Just saying, "Is a switcher okay for synths" is not enough.
So given this situation when someone asks, "Can I use a switcher?", it probably makes sense to warn against using them generally. Linears are more forgiving to be sure.
So while you still may not want to use a PC-intended switcher for your synth; this does not mean all switchers are bad for audio applications.
PSU type, the intended specific application, how it's mounted and where, shielded or not, wiring run length and location, etc. all will have an effect on the results.
As Bill wrote above, "properly utilised".
It also remains true that linear supplies have inherent advantages in some audio apps. But switchers have their advantages too.
It would be nice to see a modern switching PSU compared directly with a linear supply in a "normal" synth application by someone with the test equipment to show the real differences.
Until then, I'm with Bill. If you can't hear the difference, what difference does it make?
As we put more and more digital controls and modules "back" into our synths, the switcher "noise" issue becomes more wobbly IMO.
Kind regards,
Randal (who still uses linears, but not for "religious" reasons.) |
creekree
Posted: Wed Sep 26, 2007 1:51 am Post subject:
| Uncle Krunkus wrote: | | Scott and I decided to hold off on posting the final schematics for the EM Klee, just in case it may have sparked competition for the PCB first. |
i am more than happy with than. i have to admit that i was kinda... pissed off when i learned in another thread what some member of this forum pulled off. |
Posted: Wed Sep 26, 2007 2:34 am Post subject:
i will use a cheap unregulated switching PSU for the klee (about 5.- EUR). the klee has it's own voltage source for the critical parts, so i should be fine with that. even more considering all the decoupling caps used for the PCBs and the ICs... _________________
Tech Buddy at Random*Source |
Dave Kendall
Posted: Wed Sep 26, 2007 4:23 am Post subject:
Subject description: new switching PSU thread? |
How about starting a new thread where people can post model numbers/details/whatever of switching PSUs that have successfully been used in synths? and maybe, more importantly, ones to avoid?
I'd start it meself, but, err, so far have chickened out and stuck to power one linear jobbies, so haven't got anything to post.....
Dave |
