 Forum index » Online Music
Waldorf XT filter tweaks demo
Page 1 of 1 [6 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Oct 11, 2007 11:51 am    Post subject: Waldorf XT filter tweaks demo Reply with quote  Mark this post and the followings unread
This, rather hastingly put together demo shows different filter characteristics possible (utilizing high resonance settings top illustrate the effect on character) when using the waveshape filter in the waldorf xt.
Near the end i select the 12db LP and the 24db LP for comparison too.
Yes, this is not my set. And yes, it is coming along well (but very slowly), finally Very Happy Very Happy Very Happy !
/Dasz
xt waveshaper filter tweak.mp3
 Filename:  xt waveshaper filter tweak.mp3
 Filesize:  1.77 MB
 Downloaded:  3424 Time(s)
altemark
PostPosted: Thu Oct 11, 2007 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've been looking for some example mp3 for just that part of the xt - thanks!
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Dec 15, 2007 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I have now constructed a G2 and XT combination composed of:
1. Out - Osc - Waves out / send - no filter to subs (these go into the input 3/4 of a G2)
2. In - Filter - External Input only / the return - this goes into the filter. out to main
3 G2 witch patch which routes input 3/4 to the output which goes into the xt audio in.
Actually, now that I think of it, I ought to use the subs only for the xt filter in and out patches (using sub 3 and sub 4 as two discrete sources).
What do you think?
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Dec 15, 2007 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks, I appreciate that Wink
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu May 28, 2009 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
a new related topic:
recently I did some filter work in the g2, and I posted the patch, and an mp3 demo of the g2 comparison with a x0xb0x and a blofeld ...
here is the demo, can you spot the g2 or x0x or blofeld?
http://electro-music.com/forum/phpbb-files/g2_diy_cg_bandpass_x0xb0x_and_blofeld_303_filters_578.mp3
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu May 28, 2009 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
