<on air> Twyndyllyngs cancelled tonight Chez Mosc
Solina or Onmi ensemble board?
Page 4 of 16 [394 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 14, 15, 16 Next
If I'd make a string chorus PCB, what kind of multi-BBD circuit would you prefer?
Solina style (also: Crumar Performer, Böhm Phasing Rotor, and others)
62%
 62%  [ 28 ]
ARP Omni style
13%
 13%  [ 6 ]
Elka Synthex 4 BBD circuit
11%
 11%  [ 5 ]
other (please name in thread)
6%
 6%  [ 3 ]
I would want neither - it's old fashioned and overused, and if I need it, there are digital FX boxes
6%
 6%  [ 3 ]
Total Votes : 45
jhaible
PostPosted: Sun Oct 14, 2007 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
keithwin wrote:
Good to hear your well Jurgen,
grandata appear to have TDA's in the UK - not tried them yet, just about to.
http://www.grandata.co.uk/acatalog/Grandata__TDA_745.html#a18601
That's good to hear. I really think it's not such a rare chip at all. It was popular in Germany among DIYers, but hasn't been used in that many commercial devices. (Yes, it's in the TAM-19.)
I suspect there must be thousands of these scattered over shops around the world.
The good availability was why I chose that chip in the first place. I just got worried as my #1 source, Reichelt, has dried up on these.
JH.
bugbrand
PostPosted: Sun Oct 14, 2007 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link Keith -- I'd not come across that place before. Very good to know. Super cheers!
Jurgen - I'd like to reserve two boards please & thanks!
http://www.bugbrand.co.uk
keithwin
PostPosted: Sun Oct 14, 2007 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
They appear to do japanese transistors too,
I have placed an order today:
DESCRIPTION QUANTITY PRICE COST
TDA1022 6 £3.30 £19.80
Subtotal: £19.80
Shipping: £1.00
VAT: £3.65
Total: £24.45
How about that shipping cost?
I'll see what arrives
Smile
Luka
PostPosted: Sun Oct 14, 2007 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
could i reserve 1 board jurgen
thanks
problemchild
melbourne australia
jhaible
PostPosted: Sun Oct 14, 2007 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Thanks for showing interest - to you and to all the others who did.
I think this PCB will definitely be made, and I'll post an email order form in a few days, just as I did with the Tau.
You all just make sure to get these BBD chips Smile
JH.
mono-poly
PostPosted: Sun Oct 14, 2007 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
4 boards please Smile
jhaible
PostPosted: Sun Oct 14, 2007 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll give a discount starting with 5. Smile Smile Smile
JH.
mono-poly
PostPosted: Sun Oct 14, 2007 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmmmm bom
jhaible
PostPosted: Sun Oct 14, 2007 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let's see if you like it!
http://www.jhaible.heim.at/triple_chorus/jh_string_ensemble_demo_just_strings_r8b.mp3
More here:
http://www.jhaible.heim.at/triple_chorus/triple_chorus.html
JH.
Serenadi
PostPosted: Sun Oct 14, 2007 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
You're very close to the original, congrats !!!
Since I only knew conventional pad sounds, this one is great surprise.
I like it very much. Cool
Enhancing bell sound
jhaible
PostPosted: Sun Oct 14, 2007 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Serenadi wrote:
Shocked
I'm still unsure if the first sample (with just strings) is too lush for a true Solina emulation. But the last sample (adjusting the waveform) shows what span of sounds is possible, and I think there's a spot where it sounds like solina.
http://www.jhaible.heim.at/triple_chorus/jh_string_ensemble_demo_waveform_adjust_r8b.mp3
(To my ears it sounds just right at about 8 ... 10 seconds into this sample.)
BTW, that waveform adjustment was intended to be just a 100k trimpot. But I'll probably bring it out as a normal 100k lin pot to the frontpanel, to allow more variation than to just have "the" solina sound.
JH.
softfin
PostPosted: Mon Oct 15, 2007 12:35 am    Post subject:
Subject description: !
Man, that thing sounds nice! I have to think hard how many boards I will eventually buy...two is the minimum as I got chips to populate only two at the moment.
I've almost reached the roof of this months diy budget, so if there's no hurry with payment, I will take 5 boards!
Once again, thanks Jurgen!
LWG
PostPosted: Mon Oct 15, 2007 1:46 am    Post subject: Re: Chorus board Reply with quote  Mark this post and the followings unread
Jurgen,
Hope you are feeling better from the hospital stay, (apparently you are, if you’re back at this so soon).
If I may offer a suggestion; when attempting to tune the chorus phaser to the Solina’s calibrated (or sweet spot) setting, you may want to consider the raw signal you’re feeding into the unit. Even if you have the most accurate chorus settings for authentic Solina, it may be harder to tell by ear, as the OB-8 (like most classic poly synths, ala P5, MM, etc.) have a more wideband osc signal than the typical raw string synth wave. The Solina/SE/Omni series have a pre-chorus string voice thats more
band-limited than those classic poly synths.
The string voices (on most of those old machines) have a distinct high-pass (and some lowpass) cut on them that is a major factor them their initial character.
I believe, if you tune the chorus using a synth such as the Yamaha CS, the additional highpass filtering would make it easier to model the Solina’s initial string voice character.
Once you’ve locked in on the settings you want to use for the classic Solina sound, you could use the OB and larger bandwidth synths to check for optimal headroom.
Just my .02. Sounds good so far.
Regards,
Lawrence
mono-poly
PostPosted: Mon Oct 15, 2007 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
great examples.
gonna get me some coffee and listen them again!
Broadwave
Audio files: 6
PostPosted: Mon Oct 15, 2007 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Just ordered my TDA's, so I'm definately up for a board Very Happy
Thanks,
Andy.
chriswilliams
PostPosted: Mon Oct 15, 2007 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Likewise, I'm ordering the parts now - please put me on the list for a board Smile
clickmrmike
PostPosted: Mon Oct 15, 2007 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone know a US-based source for these chips?
clickmrmike
chriswilliams
PostPosted: Mon Oct 15, 2007 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Unless I'm mistaken, I think Small Bear Electronics is US based - that's where I'm getting mine from Very Happy
http://www.smallbearelec.com
b-funk
PostPosted: Mon Oct 15, 2007 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
i´m in, too...
(toomanyprojectstoomanyprojectstoomanyprojectstoomany...)
guitarfool
PostPosted: Mon Oct 15, 2007 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Put me down for 2, too.
clickmrmike
PostPosted: Mon Oct 15, 2007 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I'm in for one, too.
clickmrmike
bambam
PostPosted: Mon Oct 15, 2007 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Put me down for one PCB, i might be able to stretch that to two Wink
Ordering my TDA1022's now.
bambam
PostPosted: Mon Oct 15, 2007 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone in australia thinking of this project? I may be able to help with a small combined order of TDA1022's
Probably around $12au each which is a little bit more than suppliers OS but postage etc would be a decent save on the final cost as they are in australia.
If anyone is interested let me know by tomorrow as i'll be ordering then.
Brett
Luka
PostPosted: Mon Oct 15, 2007 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm in melbourne,
i think ill order some when i order all my vactrols
12 seems pretty expensive brett
where are you ordering from?
they are only US$6.50 at smallbear, and we have a great AUS-US conversion rate at the moment
problemchild
melbourne australia
bambam
PostPosted: Mon Oct 15, 2007 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah i just checked out smallbear. and they actually do very reasonable postage so i ordered there Smile
