tr-505 no battery power
Page 1 of 1 [7 Posts]
binarybloke
PostPosted: Sat Nov 03, 2007 3:11 pm    Post subject: tr-505 no battery power Reply with quote  Mark this post and the followings unread
noob bender here - i just got hold of a tr-505 but the unit will only power-up from an ac adapter. there seems to have been some kind of battery leak at some point as i found lots of crap on the battery contacts but after cleaning and checking connections the machine still wont boot up unless using 9v psu.
can anyone give me some pointers?
binarybloke
PostPosted: Tue Nov 06, 2007 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alternatively if someone could tell me the correct wiring configuration from the CN4 connection to the battery compartment, that would be a big help. Very Happy
Audio files: 309
PostPosted: Tue Nov 06, 2007 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I bet Laughing , tried a Google on this, but found nothing .. well so did you I guess Wink
binarybloke
PostPosted: Wed Nov 07, 2007 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Blue, worth a try Wink
binarybloke
PostPosted: Thu Nov 08, 2007 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, can anyone tell me if bending while using a 9v psu with the 505 is a bad idea?
Kassen
PostPosted: Thu Nov 08, 2007 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's supposed to be a bad idea.... but I modded mine to have separate outputs (didn't like any of the glitches I found that much) while it was plugged in and I'm still alive.
In case of doubt you can always use those rubber washing up gloves.
Kassen
binarybloke
PostPosted: Fri Nov 09, 2007 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the rubber gloves advice Very Happy i did some poking around last night with a circuit breaker attched to the psu and no probs yet.
I read a post somewhere suggesting that drum machines/synths of this nature that use 9v are relatively safe, something to do with the amount of charge stored in capacitors being pretty low.
