Sherman filterbank
Page 1 of 1 [10 Posts]
DNME
PostPosted: Wed Nov 07, 2007 6:53 am    Post subject: Sherman filterbank Reply with quote  Mark this post and the followings unread
I know there are already allot of post about using the G2 as a filterbank, but couldn't find anything about the possibility to create a Sherman filterbank with the G2. I was wondering if it's possible to do it.
mother misty
G2 patch files: 130
PostPosted: Wed Nov 07, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi DNME,
Roland Kuit made a filterbank-patch,
don't know how close this comes to the real thing
http://electro-music.com/forum/post-21555.html#21555
egw
G2 patch files: 8
PostPosted: Wed Nov 07, 2007 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the routing diagram for the original Sherman Filterbank:
 Filesize:  16.55 KB
 Viewed:  516 Time(s)
www.gregwaltzer.com
DNME
PostPosted: Wed Nov 07, 2007 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, thanx for the link and the routing diagram! Will check it!
3phase
G2 patch files: 141
PostPosted: Sun Nov 11, 2007 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
difficult goal.. the sherman filter has a really sick sound ...it dont even trys to be a mathematical correct filter and is therefore probably more difficult to emulate than a moog filter... you would need to much dsp for something you can have for a few hundred coins in real..
main thing about the sherman is its internal distortion..is rather a distortion pedal with modulated filters than a filter as you know it..people use it for its overtones... it would be a hard challenge to catch some of this digitally...
i dont have a sherman anymore..but when i come along one for a good rate i will grab it again.. its a recommendable fx unit...
DNME
PostPosted: Sun Nov 11, 2007 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
3phase
You're right about the filterbank. It's got that sick sound, I used it once to make a Hardcore Kick routing a Tr 909 trough it. Don't have one myself, but might get one too one of these days.
Was just wondering if anything comes close using the G2 to gain & distort a real 909. I Am working on a patch to gain / distort / filter / eq a 909 kick drum, but it's hard to get rid of that digital sound Wink and since I am new using the G2 it will take a while before I understand the smartest way to route everything.
egw
G2 patch files: 8
PostPosted: Sun Nov 11, 2007 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
You could use the filters on the G2 and route the signal through a stomp box for the distortion (or vice versa). With the 4 inputs and 4 outputs on the G2 you could even make several passes through external devices (assuming a mono signal) as part of the same patch.
www.gregwaltzer.com
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Nov 11, 2007 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
put eq's around the distortion module (before and after), this really beefs up the OD module.
/Dasz
DNME
PostPosted: Sun Nov 11, 2007 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
Yeah did that and also some filters and I got close to the sound I want, but it still needs more work. When I've my "first" patch done I'll post it Smile
emeleia
G2 patch files: 5
PostPosted: Tue Nov 20, 2007 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
Hi DNME,
Shocked
just the patch i was looking for. thanks!! Very Happy
