THD107 Quadrature Function Generator PCB's HAVE ARRIVED!
Post new topic   This topic is locked: you cannot edit posts or make replies. Moderators: Scott Stites
Page 6 of 8 [186 Posts]
Randaleem
PostPosted: Tue Nov 20, 2007 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Scott!
Total agreement.
OTOH several people had enquired both on and offlist for a QFG BOM with mouser numbers as offered by Magic Smoke for the Mankato. So they've now got one!
But again? Total agreement. Laughing
Kind regards, Randal
Coriolis
PostPosted: Tue Nov 20, 2007 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Most of your previously ordered QFG boards have been shipped.
Eh...you are shipping the boards? I must have missed a post here on that or what?
C
djthomaswhite
PostPosted: Thu Nov 22, 2007 3:04 am    Post subject: MOTM Format FPE Panel
Subject description: My MOTM Format Panel for the THD107A
Hi all,
Here is a 1U FPE Panel in MOTM format that I will be using for my own Quadrature Generator. I omitted the fine control and will possibly use a ten-turn pot for the main rate control instead. I also opted for only one modulation input with the intent to mix CVs externally. Kind of simple, but it is space saving. I did not want to commit 2U to this due to space concerns in my modular. Thanks to Randall for putting this PCB together based of yet another great TH design. Heres hoping for that quad VCA to come soon so I can get rockin' with the quad panning!
Thomas
www.naturalrhythmmusic.com/diy.html
TW_TH_Quad_Function_Generator.fpd
 Filename:  TW_TH_Quad_Function_Generator.fpd
 Filesize:  1.65 KB
 Downloaded:  467 Time(s)
PostPosted: Thu Nov 22, 2007 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Thomas.
Thanks for the contribution, but nothing works this end. is a 'pfd' a valid file? It's only coming down as 4kb here Confused
edit. DOH! My stupid mistake! 'front panel designer'!!
Could you doewnload a pdf instead?
Thanks for the file
(damn macintosh Laughing )
ACHTUNG!
krisp14u
PostPosted: Thu Nov 22, 2007 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Thomas
like the design I think I may use this for my 2 panels
and for lucky sods with a macintosh I have upped a PDF
tw_th_quad_function_generator_862.pdf
 Filename:  tw_th_quad_function_generator_862.pdf
 Filesize:  83.07 KB
 Downloaded:  444 Time(s)
Paul Darlow
www.krisp1.com
Randaleem
PostPosted: Thu Nov 22, 2007 8:06 am    Post subject: Re: MOTM Format FPE Panel
djthomaswhite wrote:
Here is a 1U FPE Panel in MOTM format that I will be using for my own Quadrature Generator.Thomas
Hi Thomas,
Did you intend to leave off the V/Oct CV input? I didn't see a reference to it in your description of the why's of your choices. If that wasn't a planned result, you could probably put the range toggle amidst the LED rings to free up a 1/4" jack location. Wouldn't necessarily need the hi,med lo labeling due to the LED's giving pretty quick and nearby feedback to the switch's position meaning?
I've noticed now that several people have presented designs with the LED's and/or Output jacks in a "Z" pattern (operationally) instead of the "O" pattern that seems more useful to me.
So perhaps I'm missing something here?
I'd expect the LED's to follow the electrical phase relationship with 0 on the "starting line", 90 above it, 180 is back on it, and 270 is below. From there electrically we go to 360, which is the same as zero in this case. This is the same way we'd draw the triangle waveforms of the QFG output (Above and below GND). On the panel these would be a diamond shape as you have drawn, but with different labeling than you're showing.
Similarly, the Output jacks would be following the electrical phase angle relationship, but constrained to a rectangle due to panel size. So they'd be top left 0, top right 90,bottom right 180, bottom left 270. Done this way, if you patch each "corner" of the output jacks to a "corner" of the room, when that VCA does its thing, you'll have the expected circular movement. The way you (and others) have it, the sound would follow a zigzag "Z" instead of a circle unless you "crossed paths" relative to the panel layout. Hope this makes sense. (OR, 0 could be LL, 90UL, 180UR, 270LR. Depends whether you mentally "roll" the LED "diamond" backwards or forwards to fit the jacks pattern.)
Laid out as I've described, any adjacent jack or led is a 90 shift, a 180/inversion is a diagonal visually. Ergonomically this makes sense to me?
Anyways, since I've now seen several panels from different people done this way (Starting with Bugbrands), I'm wondering if there's something I'm missing which makes the 0, 90, 270, 180 "Z" layout better in some way than the 0, 90, 180, 270 "O-shaped" one?
Here's a PDF of your design edited to my described layout for comparison.
What am I missing here?
Next, Let me throw out one more possible reason to have an expanded panel. If you use one output OF the QFG to modulate itself; you can create 4 distinctly different patterns in a resulting waveform. All four are nice, but Two are especially interesting from a control perspective. First of these is a "gothic window arch", or two log curves back to back. But the real sleeper is the second one is more widely known as a "hypertriangular" waveform, which is two expo curves back to back. This waveform spends less time at the peak, and more along the way to and from it. It has been shown to result in a more natural sound when used in control of phasing and flanging. (And other places too!) Here you can get it for "free" by simply using one of the outputs into a modulation input. Extremely useful.
Having done this, you no longer have a modulation input for anything else, like a higher frequency "wiggle/chorus/movement" modulation...
Then, Having dual outputs lets you use one for modulations, and the second to feed that VCA you mentioned.
Just wanted to mention that you may be leaving a lot of the raw power of this thing locked up when you go with a minimal panel. (Yes, you can still patch most of this in somehow, but it's far easier as part of the module in this case, IMO.)
TW_THD107-2.pdf
 Filename:  TW_THD107-2.pdf
 Filesize:  75.56 KB
 Downloaded:  420 Time(s)
djthomaswhite
PostPosted: Fri Nov 23, 2007 10:27 pm    Post subject: Panel Choices
Subject description: ...continuation of the "why's"
Hey Randal,
Thanks for the feedback and questions. Let me try to address them.
1v/oct jack Missing: Not really planning to use this as a VCO where that type of tracking would be needed. All of the CV's are summed and I figure that summing can take place in an external mixer into one jack with a knob to control the level. If the CV input had a reversing attenuator I would have had two jacks for sure.
Panel labeling: I went with the LED labeling to go along with the other rotary module in my system (sequencer) where the start of the rotation is at 12'oclock. Since the Jacks at the bottom would be in a square formation I did not see the importance of tryin to get close with labels when still not being able to get a diamond-shaped jack layout on the 4 output jacks.
Jack Labeling: I will switch my jack labeling to reverse the bottom two labels. I didn't even think about that when throwing the design together. Thanks for bringing that up!
My panel design may change a bit once I get the PCB. I always wait to order panels until I actually have the pcb in hand to give one last consideration to the chosen design. I do have one question though... how do you guys go about getting the FPE designs into these nice pdf documents? Never tried that before but it would be handy for future postings. Thanks gang. Very Happy Glad to be on the list,
Thomas
Thomas
Randaleem
PostPosted: Sat Nov 24, 2007 3:17 am    Post subject: Re: Panel Choices
HI Thomas,
Thank you for the details of your reasoning! It's always nice to see another perspective! Especially for something one is close enough to, that he (I) might be missing the forest in the trees!
As for that attenuverter "driving" the inclusion of a second summing jack, you might want to include that second jack. If you look closely at my prelim larger QFG panel, you'll see the -1,0,+1 label on one mod input, with 1,10 (should've been 0,10) on the other. I've got a couple little very inexpensive additions to the QFG adressing this desire/need in a unique way. And a second expressed one too! (I don't want to say more until the boards are in hand, but I'd include that second jack. Laughing) I kitchen sinked this PCB before I understood that I could sell QFG kits but not completed modules. My loss is your gain!
Notice also the extra power supply pads in a couple places on the PCB, as seen on the PCB pics at the beginning of this thread and on the large component ID reference page I posted as a PDF.
On that note, here's where I give the requested "Props" to Shawn for that PDF ease!
Because He is the one who discovered and documented a way to easily go from the FPD files to DXF for use in a CNC machine which he shared with me to beta test for him awhile back. It's pretty slick! One of the steps in his process is to use a pdf printer driver. We both independently ended up choosing cutePDF writer. This is a free 3rd party windows printer driver that basically magically creates a pdf from nearly anything you'd normally print another way.
So to post the PDF of your FPE panel, I simply chose cutePDF as my "printer" in FPE, told it where to save the file and pressed "Print".
All thanks and appreciation for the ability to do that (in my case) go to Shawn! Props!
BTW, We're glad to have you here!
PostPosted: Sat Nov 24, 2007 3:50 am    Post subject: Re: Panel Choices
Randaleem wrote:
HI Thomas,
No no, no, no, NO!
(removed emoticon- wasn't quite the one I wanted to use- and caused a lot of trouble- my bad. Embarassed btw, this post was never a 'knock' just having fun with everybody- including myself! Wink Smile )
The expression goes;
"Can't see the wood for the trees" !!!
Bloody yanks with their feeble attempts of "playing on English"- god forbid!! Rolling Eyes Laughing
PostPosted: Sat Nov 24, 2007 2:18 pm    Post subject: Re: Panel Choices
Randaleem wrote:
[...]to the QFG adressing this desire/need in a unique way.
in the diy forum we recently collected ways to do attenuvertion. any chance you post a schematic of your method?
fluxmonkey
PostPosted: Sat Nov 24, 2007 2:40 pm    Post subject: Re: Panel Choices
v-un-v wrote:
Randaleem wrote:
HI Thomas,
No no, no, no, NO!
idioms are funny things, very regional. i'd always heard "can't see the forest for the trees", myself. using google as a rough gauge of actual (worldwide) usage:
"forest in the trees"--824 hits
"wood for the trees"--approx 188,000
"forest for the trees"--approx 597,000
fortunately, lanuage is a living thing, so (with the help of this post) "forest in the trees" just gained a couple google points... i kind of like it, it's got a nice poetic twist, so i'll start using it more often.
aside: v-un-v, that fingerwagging icon seems to be emblematic of several of your recent posts... did the queen appoint you Principal Scolder, or is some nuance escaping me?
b
EdisonRex
Audio files: 172
PostPosted: Sun Nov 25, 2007 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
While I am waiting for my QFG boards to arrive, I did have a question for Randaleem, namely, has one of these boards been built yet, and if so, got some pics and samples? I intend to run one of my at low range, and the other at audio range. The low freq version I am thinking using it for Orban-Parasound-ish effects with a VCA array. The audio version I will add it to the arsenal, with some of Ian's waveshapers.
Thanks for the docs, too.
Garret: It's so retro.
Randaleem
PostPosted: Sun Nov 25, 2007 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
On that note: The last of the individual QFG's will go out in Tomorrow's mail.
Yes. In the interest of "brevity" Wink I've replaced a raw PCB pic on the first page of this thread with a completed protobuild pic. The other 49+ from the build document will not be posted here! Very Happy
You can see in the posted pic the v/oct trimmer laid down as I described in the BOM. You can also see that I didn't have top adjusting 100K trimmers, and made an error in putting said side adjusting screws towards the top of the module (where I figured they'd be easier to adjust after completion.) TOTALLY forgetting the HUGE 2.2uF Cap that "would" soon be in the way! Embarassed You can also see that I used a large-ish blue C12 .001 timing cap to show the room you have for large caps in all three range positions.
The board has been run at both 12 and 15V with standard values, and no ill effects have been noted. (Thanks here due to another excellent design from Thomas Henry!)
The MTA power connector you see has been reversed both with and without (12 and 15V) power on and the protection circuitry works as expected. No damage. Even when I can see sparks as I remove and attach the connector. I did not tempt fate by repeatedly reversing and correcting in a short timeframe however. And I wouldn't suggest that, though it would probably be okay. The PTC's used have an extremely low resistance so there is no need to leave them out in a 12v version. (This is th efirst time I've used this kind of circuit protection, and to be honest, I didn't feel like it wass going to be an ongoingthing in future modules due to space and cost. But now that I've seen it in action, It will become part of the routine! (Still considering whether it might be better situated on a distro board as Peter G has done with the Plan B distro. But IMO its value and utility is readily apparent, and the cost is negligable in comparison. Thank you John Blacet!)
All controls work as expected, mod input and v/oct also okay. Standard red and green single LEDS have been tried successfully. And then 2 lead bipolar red/green were tried and this is what I'd strongly suggest using. I will be changing the BOM to reflect this. I set them so that green was positive and red negative. VERY useful. No added circuitry needed.
Both JRC13700's and National LM13700's were tried with no discernable difference observed at any point of operation. The board you see in the pic has been powered up and "manufacturing triangles" for several days at a time.
All in all, I'm pleased with the results, and see no reason to expect that anyone else won't be. Again, one must look to Thomas Henry in admiration, thanks and respect. And also to Scott Stites for building his "bridge" from TH to us all.
and samples?
This is my Achilles heel. I explained to Scott that I've never actually recorded anything, ever with a PC. He suggested a freeware program (Audiology?) that I have not yet taken the time to install or learn. That will change in the next couple weeks, but as for now, I remain a single live performance only synthesist. Soon others will be able to fill in this blank.
Should be no problem.
Well, I did provide two R11 positions to attempt to "help" those wanting to use this more as a VCO with a tempco. But, as was mentioned here previously, the filter caps used to smooth the connect transition come into play at audio rates using the standard values. A nice pseudo-sine wave begins to appear at about 4kHz, where soon after it also begins attenuating. So if triangle wave audio is your goal (Thomas designed this as an LFO), you'll likely want to attend to C3 and C4, and perhaps some resistor changes as well. There is ample audio range, going from sub-audio to beyond hearing with the rate pot (and attenuated to silence by the filter) using Thomas's suggested .001uF c12 tuning value. (With the triangle slope distortion mentioned by Thomas and Scott at frequency extrema relative to chosen cap value.)
More docs are coming; brevity it seems, is not my strong suite!
Thank YOU all for the orders, patience and support!
Scott Stites
Audio files: 96
PostPosted: Sun Nov 25, 2007 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC, it was Audacity. Download that and fire up some samples!
It'll do until you can get one of those multi-track recorders, which are really nice.
Cheerio,
Scott
My Site
Randaleem
PostPosted: Mon Nov 26, 2007 2:06 am    Post subject: Re: Panel Choices
Hi Fonik!
Sorry, somehow I missed this post of yours before now. There is nothing special or unique about the attenuverter circuit, in fact the little utility PCB I'm making supports several types of "AUV" as seen in that other thread you've mentioned.
The "unique" part I referred to is how the PCB mounts and is used. More on that when they're ready for use.
EdisonRex
Audio files: 172
PostPosted: Mon Nov 26, 2007 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Randall, thanks for that. By "audio frequency" I think 3kHz is probably tops. I'll be using it for some complex modulation. Anyway, your picture shows me what I need to see.
and yes, Audacity - if you wonder how fast I can post audio clips, Audacity is the reason. You'll wonder how you got along without it before.
janvanvolt
PostPosted: Tue Nov 27, 2007 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my front panel design (dotcom style) :
http://apollo.open-ears.de/pdf/thd107-demo.pdf
maybe i'm doing a silkscreen for it, but not sure about it yet.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
RF
Audio files: 28
PostPosted: Tue Nov 27, 2007 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
That's nice, Unit-sound.
janvanvolt
PostPosted: Tue Nov 27, 2007 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
For those who are curious, i am currently working on a frontpanel for the upcoming Haible FrequencyShifter :
http://apollo.open-ears.de/pdf/fs1a-demo.pdf
TheAncientOne
PostPosted: Wed Nov 28, 2007 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this may have been asked before, but I have to admit my seach-fu is weak: What technique did you use for your panel layout? I like the way it gives such a realistic view of the panel.
Thanks
Mike
janvanvolt
PostPosted: Wed Nov 28, 2007 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, the honor should be given to Yves Usson. He has created a collection of scripts for unix which makes a pdf file out of some eps files.
Randaleem
PostPosted: Thu Nov 29, 2007 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan,
That's a beautiful panel image, as others have also said.
My concern is for its utility. You may wish to read the comments I made above above about the bottom row of jacks on your panel being in reverse of what is perhaps more intuitive. And also, I'd strongly suggest you move the range switch up next to, or in the center of the LED's so you can have a 2nd CV/modulation input. Trust me when I say that having more than one CV input for this module is a good thing!
BTW, did Yves post those scripts anywhere for public use?
Danno Gee Ray
PostPosted: Sat Dec 01, 2007 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone here received their QFG circuit boards from Randallem yet?
EdisonRex
Audio files: 172
PostPosted: Sat Dec 01, 2007 6:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm still waiting. I have had no PM or email regarding the shipment, either.
Danno Gee Ray
PostPosted: Sat Dec 01, 2007 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Edison. Anybody in the US have their boards yet?
