varying capacitance to change pitch on mt-240
Page 1 of 1 [5 Posts]
synthmonger
PostPosted: Sun Nov 04, 2007 2:03 pm    Post subject: varying capacitance to change pitch on mt-240 Reply with quote  Mark this post and the followings unread
I've found that varying the pitch to a great degree is only possible by swapping capacitors. Ideally, I would like to make this variable via a potentiometer/vactrol so I can implement voltage control.
On a side note, has anyone found a way to add volume control to the drums/chords without using switches?
liquidpaper
PostPosted: Fri Nov 23, 2007 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
there are such things as variable capacitors (just like potentiometers and photocells are variable resistors). i don't know what you could hack them out of. here's a link showing the kinds:
http://www.surplussales.com/Variables/AirVariables/AirVariableCapsIndex.html
octatone
PostPosted: Fri Nov 23, 2007 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
DIY:
Cardboard and foil:
http://www.crystalradio.net/beginners3/cap.shtml
Or a little more classy:
http://www.eham.net/articles/5217
PostPosted: Fri Nov 23, 2007 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe also have a look here, for a solid state solution.
liquidpaper
PostPosted: Sat Dec 22, 2007 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
you could also use a rotary switch and connect different capacitors to it.
