Posted: Mon Sep 22, 2003 5:48 am Post subject:
Numerology 1.2 released |
Numerology 1.2 Released!
Version 1.2 adds several powerful new features to Numerology's arsenal of sequencing modules. In addition to hosting AudioUnit Synthesizers and Effects, Numerology's new DualLFO module and parameter modulation features give you and endless supply of options for sound mangling.
And since Numerology can now be used as a complete stand-alone virtual composition and sound making environment, it now comes with several example sessions that show off many of the new features. Just load them up and hit 'play'.
And if all that wasn't enough, the full Numerology download includes a free drum synth plugin developed by Bitshift Audio!
What is Numerology?
Numerology is a modular sequencing and audio plugin environment for Mac OS X. It takes sequencing and modulation metaphors established by the analog sequencers of the 70's, and implements them in a structured and highly interactive software environment designed for experimentation, improvisation and live performance. By using Numerology in conjunction with your choice of Audio Unit plugins and hardware synths, you can create an open compositional environment that is truly your own.
Primary Features:
Step Sequencing
Modular Sequencing
Audio Unit Hosting
Parameter Modulation
Integrated Audio and MIDI Mixing
MIDI Generation:
MIDI Notes, CC, NRPN, Pitch Bend
MIDI Learn
Advanced Preset Management
Song Arrangements
Performance-oriented design
What's New:
Numerology version 1.2 adds several very powerful new features to Numerology's already sizable arsenal of sequencing machines, including Audio Unit hosting, Parameter Modulation, and an obnoxiously flexible LFO module. Each of these features alone offers important new capabilities to the Numerology user, but where these features really shine is when they are used in combination.
Audio Unit Hosting
Numerology 1.2 lets you run Audio Unit synthesizers and effects directly in the program, including mixdown of multiple instrument groups to a stereo output. In addition to the selection of Apple AUs included with OS X, you can add AUs from the growing number of commercial and free-ware Audio Unit synths, samplers and effects. Create a virtual studio that is truly your own. An up-to-date list of AUs is available, of course, at osxaudio.com.
Included among the standard Apple AU offerings are a DLS/Sountfont sample playback engine (complete with a custom Numerology interface) high-pass, low-pass, and band-pass filters, high and low shelving filters, graphic and parametric eq's, and delay and reverb modules. All the basics to get you started. Even if you never add another AU to this selection, the creative use of parameter modulation and sequencer programming can quickly take you into uncharted musical territory.
The new Parameter Modulation module allows you to quickly add automation to almost any module parameter, including Audio Unit parameters. This seemingly simple addition opens up a world of new possibilities for sequencing and timbral manipulation:
Create chaotic sequences by using one sequencer to modulate the start position or clock division of another sequencer.
Modulate parameters on AU synths and effects to create phrase-level timbral changes.
Integrate sounds from your hardware and software synths by modulating both from the same control source, by using both parameter modulation and CC or NRPN output.
Explore the world of glitch by modulating non-continuous parameters, such as some delay and reverb parameters on Apple AUs.
Create complex control values that you can perform in real time by modulating LFO parameters from another LFO or sequencer, and assigning key parameters to be controlled by a hardware fader box.
LFO Module
The Dual LFO module is a great new source for generating control signals, either to generate pitch or velocity values for notes, act as a control source for Numerology's MIDI CC or NRPN output modules, or to modulate other parameters. This module includes two low-frequency oscillators that each have a number of powerful features:
Pulse width control over all waveforms LFO period programmable in increments of 1/16 notes, beats or measures, for LFO times as long as 100 measures, or directly in Hertz. Controls for waveform level, starting phase, rectification and inversion. Hard Sync setting, to automatically reset the LFO in time with your music. All parameters can be modulated to create complex waveforms.
And if that isn't quite enough, you can combine the output of both LFOs (either mixed or ring-modulated) to get even more complex signals. Use Numerology's MIDI learn feature to attach some hardware controls to some of these LFO parameters, and you may forget all about using a keyboard to control your synthesizers.
And There's More...
Numerology 1.2 now has two options for UI graphics: a lighter, 'Metal' UI (shown above) for daytime and contrast-challenging conditions, and a darker 'Studio' UI for use in low-light situations.
A number of usability enhancements have been added to Numerology since version 1.1, including automatic routing of modules for common cases, and role-specific sequencer prototypes (Pitch, Velocity, Control, etc.).
An updated sync reception algorithm improves sync to MIDI clock when using unstable sources, and avoids drift over long periods.
More info at: http://www.five12.com/numerology.html
