Calliope
Page 1 of 1 [5 Posts]
Electric Press
PostPosted: Thu Nov 15, 2007 1:36 pm    Post subject: Calliope Reply with quote  Mark this post and the followings unread
Hi Guys,
first things first.. Great work on the G1 to G2 converter, still use the original mod most days and to finally get some of the old patches up and running is great!
second thing is a bit of a challenge, i'm after either a G1 or G2 patch of a calliope? (basically a steam organ used at fun fairs) i've tried a few things, but if anyone knows of a patch i'd be well made up!
Regards
Wes
G2 patch files: 626
PostPosted: Thu Nov 15, 2007 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
Here are a couple of options. The DX7 factory rom 1 has a calliope, not one of the better patches though.
Also from Chet's PM tutorial, a simple physical model of a blown pipe might be good place to start.
caliopePM.pch2
 Filename:  caliopePM.pch2
 Filesize:  1.75 KB
 Downloaded:  1893 Time(s)
ROM-1b3.pch2
 Filename:  ROM-1b3.pch2
 Filesize:  3.32 KB
 Downloaded:  2058 Time(s)
Electric Press
PostPosted: Fri Nov 16, 2007 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks alot..
I'll give them a try monday and let you know how i got on Wink
w
cappy2112
PostPosted: Thu Nov 29, 2007 11:34 pm    Post subject: Re: Calliope Reply with quote  Mark this post and the followings unread
Electric Press wrote:
Hi Guys,
Regards
Wes
Just curious- Why is this thread in the FAQ?
PostPosted: Fri Nov 30, 2007 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good question Tony ... had not noticed ... moved it.
