 Forum index » Clavia Nord Modular » G2 Patches - Completed » Pad
Cheap Pad
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jul 17, 2004 4:01 pm    Post subject: Cheap Pad Reply with quote  Mark this post and the followings unread
Here is a cheap (dsp) pad. If you delete the FX section, it will do 32 voices unexpanded. The Chorus looses 1 voice but I think is needed for such a simple patch.
Not that you normally need 32 voices, if you have lots of other stuff loaded in the other slots, this will give you 7 note polyphony in one slot.
I think it is quite nice in its own right, sort of polysixish.
The primary tricks employed to get low DSP usage are
    1. No filter, use shape oscillator for time varying spectral content.
    2. Second Oscillator is simple sine with optional static shaper for more brightness.
    3. Use morph functions for velocity, keyboard scale etc.
    4. Use global LFO for vibrato (through wheel)
CheapPad.pch2
low dsp pad
 Filename:  CheapPad.pch2
 Filesize:  1.42 KB
 Downloaded:  2461 Time(s)
Audio files: 235
PostPosted: Sat Jul 17, 2004 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Variation 3 sounds like an Farfisa mini compact organ I used have. It was cheap. Wink
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jul 17, 2004 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only the chorus saves it from ultimate cheapness I think. The Shape Oscillator by itself, reminds me of the Casio CZ101, another 'not quite' classic.
