Finished my Klee!
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
23isgood
PostPosted: Sun Dec 09, 2007 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a tune I just finished with the Klee. All the drums are coming from my diy drum machine. The event generator I built not to long ago is triggering all the drum sounds except the kick. The klee is triggering the kick. The event generator's internal clock is driving the Klee. The Klee is driving three XR2206 VCO's, two MOTM EG's, one VCA-1, and the 3320 filter. I am only using register B!
I also used a Space Echo 201, a Lexicon MPX-100 and my Mackie 1604 mixer. There is a lot of post processing. Compression, EQ, Flanging (waves plugins).
pete
Update, I moved the tune to the, "A collection of Klee musics" thread.
http://electro-music.com/forum/post-156985.html#156985
[Blue Hell - added a link]
Check out my music
Danno Gee Ray
PostPosted: Sun Dec 09, 2007 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent piece!
Audio files: 224
PostPosted: Sun Dec 09, 2007 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats... Good work.
23isgood
PostPosted: Sun Dec 09, 2007 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys! I just realized that I should have posted this in the, "A collection of Klee musics" thread. How can I link it to there?
pete
Check out my music
EdisonRex
Audio files: 172
PostPosted: Sun Dec 09, 2007 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Much fun to listen to! Very "drummy". Keep it coming!
Garret: It's so retro.
Audio files: 224
PostPosted: Sun Dec 09, 2007 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The simplest way to move the attachment it to delete it and repost to the other topic. Not elegant, but it works.
Audio files: 297
PostPosted: Sun Dec 09, 2007 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or simply post a link to this thread or the mp3 alone in the other thread ... less work ....
Too late I see Very Happy
Audio files: 224
PostPosted: Sun Dec 09, 2007 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that would have been less work, but not the tunes are in the same place.
23isgood
PostPosted: Mon Dec 10, 2007 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh I forgot to mention that my Klee's trigger outputs will not trigger my CGS drum modules, the Cynare, and the dual chime. I think the gate outputs didn't work on the CGS stuff either. Do I have to adjust resistor values on my Klee to accommodate the CGS stuff?
thanks
pete
Check out my music
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Which range are your trigger outputs, 5 or 10V?
It's interesting - IIRC, I had 5V outputs on the BB, but it still triggered the Cynare (I don't have the other modules you mention).
My Site
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Okee doke - the drum module (which I have, too, forgot to mention) and the chime simulator should trigger on anything above 3V. The Cynare should trigger on anything above 2V. In fact, if you look at the Cynare schematic, you might notice it has a 100K/15K divider as a reference to the input comparator, just like the Klee (mosc needs to invent an innocent "whistling" icon Laughing ).
I'm fairly certain I ran both the Cynare and drum module off of 5V on breadboard Klee, but, being on breadboard, it's possible the flavor of the day could have been different. In any case, both trigger on my Klee, which has the 10V range outputs.
Just to be sure it's not a case of trigger width as opposed to level - you can double-check that by plugging a gate output to the trigger inputs of the modules - it looks like each of those modules has an input cap to turn whatever is presented to them into a pulse.
I know you mentioned that you may have tried the gates, but the gate width will vary with the clock - to remove that as a consideration, you can manually step the Klee by pressing the manual step switch. I designed that so the gates would stay high as long as they switch was pressed. The gate bus LEDs will stay high as long as that switch is pressed (of course, as long as a gate is progammed for the current step on a particular bus), meaning that the gate outputs are held high. The results of that would confirm or deny that pulse width is a concern here.
As an aside, the manual step switch is a way you can merge gates "on the fly", (even the master gate bus!) though each time you press it, it will step the sequence up one step.
Cheerio,
Scott
My Site
23isgood
PostPosted: Mon Dec 10, 2007 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok just checked and it seems that they do work with the trigger outs. Whats not working is the trigger input to the Cynare. If I take the trigger out from the Klee and plug it into the sustain input on the Cynare, it works. I setup the Klee to output 5v gates and triggers. I know the Cynare trigger input works, cuz I have been using it with my event generator just fine.
Check out my music
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick question: what level does your even generator put out?
My Site
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anudder kwik kwestion: if you plug a Klee gate output to the trigger in of the Cynare, will it trigger from that?
My Site
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
My brain's probably distorted right now, but I can't see any way for the Sustain input of the Cynare to actually trigger it. It goes high when there's a gate signal (something greater than 2V), but there's a blocking diode in place so that it doesn't make it through to the trigger portion. What it does is allow the damper control to have an effect on the decay - if it's high, the envelope cannot discharge through the damper, so the decay will be longer than if there were not a gate signal present (under normal circumstances).
I'm sure you know this already, but this is why Ken states:
Note: if the damper decay rate is set to minimum, and the sustain input is below about 2V, the envelope will be set at minimum, with the decay control having very little effect, so if you do not wish to use the sustain input, the damper decay rate should be turned to maximum.
I'll whip out the Cynare board when I get home and give it a whirl to see if anything pops up - I'll cut my levels down to 5V range to emulate what you're experiencing.
That is, if I have power when I get home - we're expecting an ice storm here.
I'll let you know what I find out. If I have power. Rolling Eyes
Cheerios,
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Mon Dec 10, 2007 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I tried out my Cynare - mine triggered OK with the Klee trigger outputs. I rigged up a 100K pot and reduced the trigger output from the Klee - the Cynare stopped triggering at right around +2V. I thought I'd try putting the triggers into the sustain input to see what happened, but it wouldn't trigger off of those. It's a headscratcher!
Cheerio,
Scott
My Site
23isgood
PostPosted: Sat Feb 09, 2008 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well it appears that the replacement CD4034 for register B has gone bad! Luckily I bought two of them so I just put the second one in there and its working. Even though my Klee is working fine now, I cant let it slide without figuring out why these chips keep going bad in register B. Can someone shed some light on why they keep going bad? Could it be bad grounding?
thanks,
pete
Check out my music
Scott Stites
Audio files: 96
PostPosted: Sat Feb 09, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure what could cause it - which manufacturer was it (TI or ...?).
Was the failure mode the same as before?
As an aside, I patched up my Klee just last weekend - first time I'd actually played the modular since right before Christmas. The Klee has been on, though, for most of the time, though - it's on the same powerstrip as my DW6K and SH-201.
I've been syncing it to MIDI through a MAP MTS-100. Twisted Evil
My Site
23isgood
PostPosted: Sat Feb 09, 2008 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your Klee has been turned on since Christmas!? Wow. Can leaving gear on for that long be bad? So the first symptoms I noticed, was that the Register B cv outs where not working. Then I noticed that the 8*16 switch was not working. Eventually the register B LED's would all stay on, and then the Klee just locked up. These are the similar problems that I had before. The first chip was the one I got from Bill, and the second one was from TI. I need to buy a few more just in case.
Check out my music
Scott Stites
Audio files: 96
PostPosted: Sat Feb 09, 2008 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it's only been on if I have the other synths turned on Very Happy
What are you using for a power supply?
My Site
23isgood
PostPosted: Sun Feb 10, 2008 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh ok, it hasn't been on all this time. Im using a power one power supply. The same as in the MOTM supply.
Check out my music
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Apr 09, 2008 12:35 pm    Post subject:   Reply with quote  Mark this post and the followings unread
i got new mobile phone that records video clips oujea. shit it is.
here's variation of scott's golden pot settings.
my modest soundlab.
short one.
cheers
ivan
Scott Stites
Audio files: 96
PostPosted: Fri Apr 11, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool, indeed, Ivan! I'd love to see a longer clip of it.
Arrgh, I wish I was YouTube capable (of making a vid that is).
Cheerio,
Scott
My Site
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Apr 11, 2008 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thnx scott.
i hope very soon to make something longer,
im in process of making some modules to make use of klee even more.
cheers
ivan
