Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Tue Dec 18, 2007 4:07 pm Post subject:
Pre-amplifiers |
Maybe a little off topic, but usefull if you want a microphione pre-amp in your system.
I need a microphine pre-amplifier for recording and I am on a low budget. I have been looking at various behrigner ones and thought " Hey I could just build my own for cheaper and in a custom rack case/panel?" ( which always seems to be the case at the moment )
My question is - if I built this
http://sound.westhost.com/project66.htm
would it be able to mach or maybe out perform the quality of a low cost commerical pre-amp? - I guess by taking out all the bells and whistles of a product you end up with a cleaner signal?
I am also wondering if there are any pre-amplifier circuits/projects out there that people have experimented with and can reccomend?
I guess there is a level at which building a pre-amp can out cost its quality? much like the uselessnes of building your own mixing desk? _________________ Clacktronics.co.uk |
Posted: Tue Dec 18, 2007 4:13 pm Post subject:
I think this one based on the THAT 1510 is far better than the superduper lownoise stuff found in the low end Behringer mixers.
Five Fish Studios Pre-amp kit _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Tue Dec 18, 2007 4:26 pm Post subject:
Ah.. now the ESP page finally loaded. That one looks interesting as well. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Tue Dec 18, 2007 5:04 pm Post subject:
The ESP one works nicely. He makes some good points about the 78/79 series regulators too - no instrumentation engineer would give them house room.
Take a look at:
http://www.seventhcircleaudio.com/
These are better laid out than the FiveFish studios board, and their T15 is roughly the same device for $20 less. If you're not in the USA - bad news, they use UPS and their carriage costs to Europe are high, (like $105 for $160 worth of kits. This would average out on a large order though).
Another firm who's kits impress me are
http://www.jlmaudio.com/kits.htm
and with the Australian Dollar exchange rate you're winning too. _________________ Mike |
bearblock
Posted: Wed Dec 19, 2007 12:38 pm Post subject:
Seconded. the Baby Animal rules. |
Clack
Posted: Wed Dec 19, 2007 1:52 pm Post subject:
awsome, posh stuff .. thanks.  _________________ Clacktronics.co.uk |
julianw
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Thu Dec 20, 2007 11:12 am Post subject:
I built that ESP P66 preamp. Rod seems to be a good trader, board got here fairly fast (Australia to Denmark).
I power mine with 2 9V batteries and use it for fieldrecording with my minidisc. Put a TL072 in mine - no noise that I can hear. If you can lay out the board yourself, it is very cheap to build. THAT 1510 isn't exactly cheap...
Maybe try the Green Pre? Supposedly a clone of the Amek Mozart preamp, and reported to sound very good and have very low noise.
http://1176neve.tripod.com/id10.html
This guy is on prodigy-pro as well and sells boards at 10$ a piece for the Green.
C |
Funky40
G2 patch files: 5
Posted: Thu Dec 20, 2007 4:50 pm Post subject:
Thanks Julian for that post.
I'd planned in the past to go for seventh circle pres, but doe to high shippment costs and low budget i must change to this 5$ circuit.
It's perfect for now !
I'm not clear about the schematic:
The INA217 has two Resistors ( between In- and In+ ).
to which pins are those connected ?
Datasheet
The INA217 is Pincompatible with the SSM2019 what i see.
Can one just replace the INA217 with the SSM2019 without any changes ? |
bearblock
Posted: Fri Dec 21, 2007 7:29 am Post subject:
hi,
you are looking for pins 1 and 8. the resistance between these pins controls the gain of the amp. beware though - if you want it to behave like a standard 'volume knob' you will have to put a reverse-log potentiometer here.
you should be able to drop in a SSM2019 or THAT1510 here without having to make any other changes. |
Funky40
G2 patch files: 5
Posted: Fri Dec 21, 2007 2:05 pm Post subject:
| bearblock wrote: | hi,
you are looking for pins 1 and 8. the resistance between these pins controls the gain of the amp. beware though - if you want it to behave like a standard 'volume knob' you will have to put a reverse-log potentiometer here. |
thanks bear.
Yes, i'd like to have a standard Volume pot.
Hmmm... i think i will need some datailed expanations how to make this section with the pot between RG1 and RG2 of the IC.
and what value should i take for the Pot ? |
Funky40
G2 patch files: 5
Posted: Sat Dec 22, 2007 6:29 am Post subject:
| Funky40 wrote: | Hmmm... i think i will need some datailed expanations how to make this section with the pot between RG1 and RG2 of the IC.
stupid, i just can experiment, respectively i can anyway draw a board . |
bearblock
Posted: Sat Dec 22, 2007 6:59 am Post subject:
no problem
10k would probably be a good value to start with. as you say, you might need to experiment to get it spot on. http://www.musikding.de/ have a good range of reverse log pots for sale, amongst other things. |
Funky40
G2 patch files: 5
Posted: Wed Mar 26, 2008 5:20 am Post subject:
regarding to the 5$ Mic Pre
http://www.record-producer.com/i/ina217-large.gif
you are looking for pins 1 and 8. the resistance between these pins controls the gain of the amp. |
next open question:
to which one goes the Wiper of the pot, pin 1 or 8 ?
Cap 1 and 2 ( 47 µF ) should be non polar if phantom power is be turned off.
I think i take to electrolytics in serial, but which value ? 2x 22µF ?
I got boards, and they are ready to build, gonna test it out
( for wiring the Wiper i have both options, pin 1and pin 8 . SSM 2019 are here) |
sneakthief
sneakthief
