Restoring/Modding Boss CE-300
Page 2 of 3 [72 Posts]
gavgomad
PostPosted: Fri Dec 28, 2007 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Germaniac! Thanks for the reply!
I'm thinking the dodgy fuse was clouding what I was getting on the scope.... I'll give it another hack this weekend.... I think I need a better meter with frequency on board, as my scope is definitely a single input.
BTW.... Germaniac (or anyone!).... Another stupid question.... When replacing the PS fuse, if I recall correctly, the key rating I should worry about is the amp rating? The schems call for a 125V/.5A fuse. All that seems to be local are 250V/.5A, but in my mind that shouldn't make a dif? Mains voltage around here is same as US, so 250V is really about double - odd that would be the standard....
Will get back to this on the weekend for sure (gotta sneak into work for a bit today! AAARGH! ;-P)
Gavin.
gavgomad
PostPosted: Sun Dec 30, 2007 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's an update for those following my trials and tribs.... Wink
Fuse replaced, and supply is purring again.
Modded the input resistors R2 and R4 to 10k, with noticeable drop in noise and "heat" on the inputs.
Eyed up the LFO waves, and basically found that when adjusting RT8, at some point the tri waves started bending awkwardly, so I backed off the trimmer until it was just clean again.
As for the clock, my DMM has a frequency setting, but I don't know how accurate it is. It would give repeatable results on the same output though, so once I set the benchmark frequency from the one set of BBDs (strangely mine came in at 116k - could be error between the DMMs?), I adjusted RT5 until I had the same reading. Germaniac - did you try and adjust this by ear afterward? The stereo chorus effect seems a bit narrower by comparison.... I might play around and see how the audio is actually affected by RT5....
That's it for now.... Quieter, but a bit narrower in the stereo field and less "lush".... I'm starting to find my way around the circuit now, though!
Will post anything new as I go.... I think that decoupling the ICs is next on the list, but dunno if I'll get to that this weekend! Wink
Happy New Year all!
Gavin.
johans121
PostPosted: Sun Dec 30, 2007 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Gavin, post your address and I'll send you a RedBull Mr. Green
Looking forward to your updates!
gavgomad
PostPosted: Sun Dec 30, 2007 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Johans121 'n all!
Thanks for the offer of Red Bull! If I can get rid of this blasted cold that hit me hard yesterday, I think I'll make a bit more progress! Razz
As for a "mini" update, I decided to take my scope and DMM into the studio, so I can measure AND ear what's going on. A few tweaks of RT5 to tighten things up even more (this DOES actually narrow the stereo field as, of course, the differential between delay lines is decreased - but seems critical in keeping that clean, not-washed-out chorus).
RT8 was a little out of adjustment, so a little tweak there got rid of the clipping (although as Germaniac noted, the tri doesn't seem as symmetrical as I'd like - will have to add his symmetry-adjust trimmer and see if I can fix that up a bit....)
I also scoped up a straight ol' saw, and adjusted the cancel trimmers for the least clock noise - it's a little tough to see on my scope, but the ends of the trimmers are really "dancy", and you can see a sweet spot in the middle where the waves look the cleanest).... The "hiss" I was referring to seems to be gone now, although I don't know if this is due to the other round of changes or not....
Really liking the new levels from the 10k resistors on the inputs. VERY manageable now....
Now, for decoupling, I don't have 2.2s, but I do have a bunch of .1s.... I've often seen smaller caps such as this for decoupling purposes, but I'm open to words from the gallery on this one! Wink
It's coming along quite nicely, I must say! Wink
Gavin
germaniac
PostPosted: Sun Dec 30, 2007 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear you're making progress Gav!
IIUC, RT8 adjusts the output of IC9a/TP8 so that it will match IC9b/TP9. It's TP8 that put out the clipped tri wave on my unit. More thoughts on this in a moment. . . .
A frequency reading of 116K sounds about right. As you say, there are probably slight tolerance differences between our DMM counters, but also I replaced my clock caps with polystyrenes, which maybe were of higher value than the original ceramic caps. (BTW, if you can get hold of some polystys, I highly recommend these for C27/C41. They make an audible difference in the smoothness of the BBD signals.) With a clock freq of 116K, a 1024-stage device like the 3007 with give you about 4.4ms of delay (which is bit short for a chorus unit, IMHO).
To answer your question, I did do some by-ear adjustments, but if some of this seem like too much information at this point in your experiments, I apologize! Nevertheless, the initial delay of the BBDs didn't concern me as much as what seemed the asymmetrical sweep of the LFO--the "zero" point between the peak and trough of the sweep seemed all lopsided to me. Here's what I did to try and fix that: temporarily put a 1M pot in place of the divider resistors R44/R69, R64/R65, run white noise through the CE300 and listen to each output with the DIRECT MUTE engaged. I tweaked the 1M pot so the sweep seemed to bend equally up and down. At that point I replaced the pot with resistors, 1M to ground and 200K in series on the "B" side, and the same for the "A" side except a 500K 10-turn trimmer for the series resistor. Then, listening to the outputs again with white noise and the DEPTH and RATE controls set to zero, I could tweak 500K trimmer until it sounded a lot like thru-zero flanging. I set the trimmer for the greatest cancellation effect. So, in essence, the two delay lines were virtually identical at rest. Whew!
ANYWAY, it's interesting you find the stereo image less wide after tweaking. My theory on this is that the original design depends on the flaws to give it "character." I personally didn't care for that "character," and once you start to fix the flaws, it's a bit of of an undertaking, but well worth it in the long haul. Regarding the aforementioned delay time fix, I think more delay will cure the lack of image width you're hearing. A chorus ought to be more in the range of 10ms or so. You could either bump the clock caps up to 100pf or (I suspect) change those 100k resistors in the VCO to 33k as is done in the Boss CE-2 (the very same VCO set-up as the CE-300 aside from that resistor). I have the head-cold thing going on too, but your experiments have nearly got me fired up to do that last mod. . . .
BTW, anything from .1 to 10uF will do for decoupling!
Thanks for the updates!
Regards,
Joe (sneeze)
gavgomad
PostPosted: Sun Dec 30, 2007 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe! Thanks for the additional info!
As for "too much info" for this stage of the proceedings.... PLEASE provide, and I will thank you much in advance and apologize upfront for my slow digestion! Frankly, it's nice to know that someone else is moving in the same direction on something and, hey, if you've started blazing that trail before me, I certainly don't mind benefiting from whatever knowledge you feel like sharing! Wink
I will have to dig around for the 'styrenes.... Those are small caps, to say the least!! I firmly believe that your symmetry mod is critical, though.... From what I can see of the tri's I'm getting, they're not clipping as yours were, but they definitely do NOT look like perfect symmetrical tri's....
Strange.... On my CE-300, I can drop the rate knob to minimum, and the box almost sounds like a comb (it sounds THAT narrow).... Give it just bit of rate, though, and crank the depth, and there's at least enough there that you can hear the sound start to "breathe" like the ol' Dim-D.... Not there yet, but I think following your lead will move in that direction! Wink
Methinks I'm due for a recap of all of the electros though.... I'm detecting some instabilities in the circuit that, short of aging electros and possibly ill NEs or Op Amps (I think the former more probable), I can't account for.... Plus, although much quieter than before, I still think the quiescent noise in this beast can be further silenced....
Oh well, I completely recapped and re-trimmered my OB-8, this should be a walk in the park, eh??? ;-PPP
Keep me posted on that VCO mod.... I am MUCHO interested in hearing your results, and will likewise keep all posted on my developments!
I shall sneeze along with you my friend, whilst the iron burns hot! Razz
Gavin
germaniac
PostPosted: Sun Dec 30, 2007 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, here's the result of some delay mods, and frankly I'm STOKED about this! My theory about the VCO resistors didn't play out, so I resorted to increasing the clock caps, C27 and C41. At first I tried 100pf which upped the delay to about 7ms, then I went to 220pf which I find ideal. The clock freqs are now about 33K, for about 14ms of delay. I didn't have any polysty in that value so I used polypro for the time being.
For these samples I used a sound with a little more teeth and harmonics in it than before. The first example is the dry uneffected sound.
The second example is my previous mods before the delay adjustment. It's pretty tame, and you can hear a bit of comb-filtering/flanging, just as you mentioned with yours Gav. FWIW, I don't care for that sound in a chorus.
The third example is with the same settings as the second, so it sounds rather exaggerated to make a point. But now it definitely sounds like a CHORUS. That's with the DEPTH control full CW, so there's lots of room to tame it down. But I really like having all that depth to spare because you never know how it might be useful in a mix somewhere.
On the fourth example, I start with the effect engaged but the DEPTH control at full CCW. I slowly raise the DEPTH control, then the RATE control, and then back it down to a reasonable speed.
As I say, I'm just about totally happy with the sound of this thing now--as far as I'm concerned it finally sounds the way I EXPECTED it to when I first got it! Let me know what your opinions are. . . .
Well, there's nothing like solder fumes to clear your sinuses. I'm beat for the day, so it's off to take a nap. . . .
Regards,
Joe (snooze)
CE-300 Delay Test 1.mp3
 Filename:  CE-300 Delay Test 1.mp3
 Filesize:  864.42 KB
 Downloaded:  1313 Time(s)
CE-300 Delay Test 2.mp3
 Filename:  CE-300 Delay Test 2.mp3
 Filesize:  491.06 KB
 Downloaded:  1177 Time(s)
gavgomad
PostPosted: Mon Dec 31, 2007 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Germaniac!
Thanks for the update! Sounds like I'm going to be on the hunt for some 220pfs myself, as that sounds MUCH better than the stock 300.... Way to go, man! Wink
I too dislike the "comb-filter" kind of sound - which is why initially I started to get concerned about the sound of mine after I locked up the two clock signals.... The sound seemed to have "thinned out". This is NOT the sound I had come to know from the likes of the Dim-D or even Dim-C, which was wide and lush, just without the "wash", if you will, of a typical chorus. If anything, it was adding a nasal quality to my nice fat Obie pads, which is NOT a pleasing addition!
I think you are dead on when you say that Boss/Roland seemed to rely on imperfections in the circuit, including variations between clocks, to obtain a stereo image on this box. The theory seems to have been that the more random differences between the left and right channel, the more likely the ear would pick it up as a stereo image.... Most distressing when all of the critical components for a really good chorus - quality companding etc. - were in the design from the start. Confused
In any event, it is clear that with a little work, this box can step into the shoes of a dimension chorus - but certainly NOT out of the box!
At work for a bit today, but may try and start bypassing those ICs today!
Question Joe, where did you decide the ideal spots were for decoupling the bias, vref and cancel supplies?
Gav.
germaniac
PostPosted: Mon Dec 31, 2007 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks! Those samples are a bit warped-sounding to me today. I guess my ears were plugged due to head-cold. I'll do some more dialed-in samples, hopefully later this week. BTW, Mouser's got 220pf polystys, but I don't know how do-able that is for you up there in Canadia Land. . . .
Totally agreed. Scott Stites even said, after he heard my samples of the stock unit, he imagined the Boss designers taking a listen to the finished product, then handing the head designer a sword and expecting him to "do the right thing." Laughing Normally, it's a pretty tall order to improve on anything Boss-designed. But something went awry with this one, and I'd be curious to know the history of why. All I know is, I used to see CE-300s piled three and four high in the used-gear shops in the late 80s to late 90s. Nobody wanted them, and I didn't either. Even now, there isn't much of a buzz about them on the web, so I figure the lackluster sounds we're hearing are not just imagination. OTOH, inside the ugly hag is a hot chick waiting to be set free. . . . Wink
Hm. I put the decouplers as close as possible to the relevant part of the circuit but BEFORE the voltage reached any passive or active components. If you mean where physically, it was just an opportunistic thing, wherever they would fit on the trace side of the PCB without threatening to short anywhere. You probably already know this, but overall, decoupling effectiveness is in proportion to the nearness of the cap to the relevant IC pin (or whatever). The decouple caps should be right on the IC pin, and if you must have a slight length of lead, it's better put the body of the cap nearest the IC pin and use the longer lead for your ground.
Hey, I'd sure like to hear some samples of that OB-8! Keep us posted. . . .
Happy New Year!
Joe drunken
gavgomad
PostPosted: Mon Dec 31, 2007 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe!
Thanks for the tips on decoupling.... What I was aiming for was the best spot on the overall bias, ref and cancel circuits - I know you need to get it as close as possible to the circuit your decoupling (easily spotted with an IC!), but I just wasn't sure of the best spot on those. Sounds like the best place to stick 'em is on the rail prior to the passive components in the circuits. Wink
I think I need to pay a bit more attention to Mouser - there was a time when they had a ridiculously high minimum order for shipments to Canada, but it looks like that is no longer the case? Will find out soon enough! Smile
The CE-300 is certainly a puzzle.... When I picked mine up, there was some scuttlebutt around on the net that it was a good sub for the Dim-C, and as I wasn't going to get around to building a clone any time soon, I thought I'd take a risk on the 300.... It seems so ridiculous that Boss went as far as they did with this design, only to drop the last 1% of the work and lose 90% of the benefit of what they actually did RIGHT in the design.... Oh well, keeps this piece of kit affordable for those of us who can tweak them to our benefit!!
I'll try and get some samples of my OB through the 300 in the next day or two - it will also show where my CE is at this point as well, in case someone hears something unexpectedly awry in there! Wink
Happy New Year!!
Gav.
wolzow
PostPosted: Sat Jan 05, 2008 4:39 pm    Post subject: Restoring/Modding Boss CE-300 Reply with quote  Mark this post and the followings unread
Hi germaniac,
I'm quite interested in the mods you made having just got hold of a beaten-up CE-300 myself. However, I'm a bit confused about the statement:
germaniac wrote:
INPUT LEVEL:
I reduced the input level by changing both R2 and R4 to 10K. With those values, you get unity gain at max, but if you're using line-level siganls like synths, you'll almost never need to boost the gain. Also, lowering those values to 10k lowers the input noise a little.
To my best understanding R2 and the DC filtering cap C1 in front of the input buffer effectively act as a high-pass RC filter with cut-off ('corner') frequency 1/(2*pi*R*C). R and C values are always carefully chosen by the designers so that the low frequencies would not be attenuated. Now, if one component of the formula is reduced dramatically (R2 from 1M to 10K) it should be compensated by increasing the other one (C1). At least that's what I've always done so far while converting high-Z input devices to low impedance for studio use.
You did not mention changing the cap. Is it really not necessary, didn't this mod affect the frequency response of the chorus, or you just did not bother to mention it as something too obvious?
Thanks for the information, and sorry for the long post.
--Margus
germaniac
PostPosted: Sat Jan 05, 2008 5:29 pm    Post subject: Re: Restoring/Modding Boss CE-300 Reply with quote  Mark this post and the followings unread
Hi Margus! welcome
wolzow wrote:
Hi germaniac,
germaniac wrote:
INPUT LEVEL:
--Margus
You are absolutely right about the designers' careful choosing of roll-off frequencies, and I see by your arithmetic, you're definitely in a position to tell ME what's what! Wink
I now see my mistake: on the schematic I've been using, the 100K feedback resistor around IC1b APPEARS to be designated "R2," but is probably/maybe R5? If you can read the designation of this resistor correctly (or we can all come to consensus as to what to call it), let me know and I'll adopt the correct term. In any case, it's this feedback resistor along with R4 that I advocate changing to 10K, not the actual "R2" which is a 1M, and sets the input impedance as you say. Sorry for any confusion this may have caused ( Embarassed ) and thanks for pointing this out!
And while we're on the topic of input impedance, I had a hunch all along that lowering R2/1M to 10K might also lower noise when used with line-level sources, but I didn't want to change C1 arbitrarily (there's that math thing) and upset the low-end response, since doing so may have adverse effects on the companding system and essentially do more harm than good. What would you suggest as the proper value for C1 if R2 were indeed lowered to 10K?
BTW, soon I'll have a bit more to report on my CE-300 mods when I have some more time. . . .
Regards,
Joe
EDIT:
Okay, on closer study, it looks like the 100K feedback resistor around IC1b is designated "R3." Is this correct? If so, would it be all right with everyone here if I go back and edit all my previous posts regarding this, so to avoid confusion for anyone else joining this discussion? Thanks.
wolzow
PostPosted: Sun Jan 06, 2008 6:43 am    Post subject: Restoring/Modding Boss CE-300 Reply with quote  Mark this post and the followings unread
So it's about changing the input gain to unity gain. Yes, the feedback resistor is actually R3. All clear. BTW, there a site (unfortunately in japanese!) with similar mod, plus the feedback resistors of outbut buffers are also changed.
http://www.n-tosch.com/tec/CE300/ce300.html
I'm definitely not an expert in audioelectronics. In my experience, at least in my effects devices I've studied and/or modded the roll-off frequency is between 1..10 Hz, and I've always tried to keep this ratio. If the resistance of R2 is reduced 100 times (from 1M to 10K) the capacity of C1 has to be increased with the same factor (from 0.047 to 4.7uF). Unfortunately capacitors of this range tend to be too large to fit in the original space, unless they are electros (and you probably don't want to add electros to the audio path).
So the combination I've been using is 47Kohm + 2.2uF. This brings the impedance down to 50K which is pretty common with studio equipment, and there's a WIMA polysomething cap that is small/cheap/good enough, and the roll-off frequency stays way below 20Hz. If you really want to go down to 10K you probably have to go higher with the cap. Some guys have suggested 10..50uF bipolar electros in this scenario.
Great, I'd like to keep my eye on those and follow the lead Smile
Regards,
Margus
germaniac
PostPosted: Sun Jan 06, 2008 4:47 pm    Post subject: Re: Restoring/Modding Boss CE-300 Reply with quote  Mark this post and the followings unread
Right, unity gain. All clear on R3, and I will update my previous posts to prevent confusion.
Thanks for the interesting link! Why he would want to increase the output level so much I don't quite get, but that's the beauty of DIY I guess. . . .
Thanks for the info. That seems an easy rule-of-thumb to follow: keep the C/R ratio the same and all is well. Your choice of 47K/2.2uF seems reasonable. FWIW, with op-amp line-level stuff, I wouldn't be too worried about electros in the audio path, especially since we're talking about a sound-effect after all. Wink But for the hard-core hi-fiers, the Panasonic FC series are quite good, and they can also be bypassed with a small film cap. Anyway, for the CE-300, the only place I'd be very particular about the cap material are those polystys for the clock chips. They really make a difference in the smoothness of the BBD outputs over the stock ceramic caps.
Regards,
Joe
germaniac
PostPosted: Sun Jan 06, 2008 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Gav and Jim and Others:
I want to offer a special apology for my mistake regarding the "R2" mix-up. All this time I've been meaning R3, NOT R2 for the input level reduction mod. So, to clarify once and for all, the input-level mod spoken of in this thread should be to reduce resistors R4 and R3 to 10K. All my previous posts have now been edited to reflect the correct designation.
As I mentioned previously, my schematic wasn't too clear, but I'm very sorry if this messed you guys up in any way! Embarassed My bad, and I'll try to be as clear and precise as possible from here out. I hope your mods are going well, and I'm sorry again if this mistake caused any trouble. . . .
Regards,
Joe
johans121
PostPosted: Sun Jan 06, 2008 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
germaniac wrote:
Hey Gav and Jim and Others.... I hope your mods are going well, and I'm sorry again if this mistake caused any trouble. . . .
Regards,
Joe
EARGH I HATE YOU!
Just kidding. I haven't started my ce300 mods yet. I'm waiting on a conclusion here first Wink
I've been working on several modules and have have a few more to work on after those are done. So... I'm in no rush!
Again, thanks for all of your detailed comments! I really am excited about your progress.
Regards,
Jim
germaniac
PostPosted: Sun Jan 06, 2008 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
johans121 wrote:
EARGH I HATE YOU!
Shocked Laughing
Cool! Hopefully this whole process will result in all the must-do mods being found here in one place for everybody to use. I'll be excited to know what you find when you start working on your CE-300 too. Keep us posted. . . .
Regards,
Joe
germaniac
PostPosted: Fri Jan 25, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's been quiet on this thread--hope you've all been busy with your mods. Just in case anybody's in the market:
http://cgi.ebay.com/BOSS-CE-300-Rack-Chorus . . . .
EDIT: Bidding ended, sold for $77.
I'm pretty much finished with all my mods, and will have a run-down of all of them in a while, as well as a few samples. . . .
Regards,
Joe
johans121
PostPosted: Fri Jan 25, 2008 9:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
*edited out ebay link*
Regards,
Joe
Howdy, I haven't started my mods yet. I actually have to purchase some more parts. Once you guys post your "final thoughts", I'll probably follow up with a few questions. After I'm satisfied with my direction I'll head on over to mouser Smile
In the mean time I've "working" on some tracks Wink
I'm anxious to see/hear the results of your efforts once you are done.
-Jim
germaniac
PostPosted: Sun Feb 03, 2008 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Folks,
Well, I've been using my modified CE-300 for several weeks now, and I'm pretty well satisfied with it.
Most of my mods have been posted previously in this thread, but I thought it might be helpful to have them here in one place. I should also mention here that the earlier problem I had with the LFO distortion seemed to have disappeared, so I undid all the changes relevant to that. I can't explain why this happened in the first place, though I do have the o-scope shots to prove it existed!
Anyway, without further ado, here's a run-down of all the modifications that I think helped move my CE-300 a little closer to the Dimension family tree. Attached is a color-coded schematic. Smile
INPUT LEVEL AND IMPEDANCE MODS:
The CE-300 originally may have been aimed at guitarists, and so there is a 1M input impedance. For synthesizers or general line-level use, R2 can be reduced to 10K for lower input impedance and less noise. To retain low frequency response, C1 should be increased to at least 4.7uF. (Thanks Margus for this info!) In my case, I used a 4.7uF Panasonic nonpolar electrolytic, along with the original .047 film cap bypassing it on the trace side of the PCB.
There's a fair amount of gain after the LEVEL control, and again for line-level use, this gain isn't necessary. Also the gain-setting resistors around IC1b don't need to be as high a value as they are, since input buffer IC1a can drive a fairly heavy load. Both R4 and R3 can be changed to 10K, which will give slightly lower noise and unity gain at full CW on the LEVEL control. With those values, a typical synth output should have no problem driving the level meter into the red even at 50% of the LEVEL control. If you want to keep the gain of the stock unit, the input noise still can be lowered by changing R4 to 10K and R3 to about 22K.
LFO SYMMETRY ADJUSTMENT:
Trimmer RT8 is for the purpose of matching the inverted and noninverted outputs of the LFO. This is important because a suitable "Dimension" effect requires fairly tight symmetry between the two BBD outputs. If you have an o-scope make sure the LFO outputs at TP8 and TP9 are as equal as possible before moving to the next mods. . . .
LFO SYMMETRY MODS:
Listening to the way the LFO modulated the clock and BBD on my CE-300, it seemed to me the sweep of the LFO was off-center in terms of rising and falling equally on either side of a "zero" point. The resistive dividers consisting of R44/R69 on the "A" side and R64/R65 on the "B" side serve the purpose of setting this "zero" point, as well as reducing the LFO level somewhat. For testing purposes, I tacked in a 1M pot in place of the "B" divider network and adjusted it for a more symmetrical-sounding LFO sweep, then measured the pot. The ratio was about 1-5, so I replaced R65 with a 200K and R64 with a 1M resistor. Because the symmetry was slightly different on the "A" side, there I replaced R44 with a 1M resistor and R69 with a 500K ten-turn trimmer and adjusted it to match the other side. (On my particular unit, after adjusting the trimmer by ear to match the sweep symmetry of the "B" side, the resistance measured about 235K.) This mod could also be done effectively by replacing both sets of resistor dividers with 1meg trimmers and adjusting to taste.
As a footnote here, the higher resistance of the dividers also seemed to reduce the PS fluctuations I noticed on the PS pins of the clock and BBD chips. Previously they were varying more than a volt in sync with the LFO, but now they were down to a couple hundred millivolts. Whether this has any effect on the overall sound is open to question, but it does seem like a strange design glitch.
DELAY TIME MODS:
The stock delay time is a bit on the short side for a chorus device in my opinion, somewhere in the range of 3 or 4 milliseconds on my unit. The clock caps C27 and C41 can be increased from 47pf to 100pf or even 220pf. I prefer the value of 220pf, which in my particular unit gave a clock frequency of about 33K, or about 15 ms. This gives plenty of range in the DEPTH control, everything from subtle to warped, and the longer delay also diminishes the flanger/comb-filter effect apparent in the CE-300, which I find inappropriate.
Polystyrene caps are recommended here for more accurate timing of the clock and hence smoother sampling in the BBD. To keep the delay times of the "A" and "B" sides equal, capacitors C27 and C41 should be matched as closely as possible, and then the frequency of the side "A" clock can be adjusted by RT5 so that both BBD delay times are identical.
A sidenote: any change in the 500K symmetry trimmer will slightly change the overall clock frequency of IC8. Therefore, a bit of recursive adjustment is necessary between the 500K trimmer and RT5, until the "A" side clock finally matches the "B" side clock.
OUTPUT LEVEL MOD:
It's easier to get a decent amount of input headroom if the output gain is increased a bit. With the all previous mods instituted, S/N for my CE-300 was measured at about 115dB with no effect, and about 100dB with effect. Substituting 200K metal films for R105/106 on IC13a/b boosted the output gain about 12dB over stock without adding too much extra noise. With those values in place, S/N with no effect was about 100dB, and with effect about 85dB. For my purposes, a worst case S/N of 85dB is nothing to worry about, and I think the improvement in ease of adjusting input level for max headroom while still having plenty of output gain is a worthwhile trade-off.
POWER SUPPLY DECOUPLING MODS:
Some extra PS decoupling is optional, but it never hurts, especially where spurious high frequency clock signals might dirty-up the PS lines. The CE-300 has a bare minimum of decoupling. The "digital" supply rail caps C12 and C22 can be increased to something like 470uF. On the trace side of the PCB, anything in the range of .1 to 10uF decoupling caps can be added to PS pins of all op amps, compander chips, BBDs, and clocks, as well as the BBD bias, Vref, and Cancel supplies. Some might call this overkill, but heavy PS decoupling always seems to makes op-amp circuits sound much smoother and cleaner to my ear.
That's all for now. Happy Modding! Very Happy
Joe
 Filesize:  472.28 KB
 Viewed:  1360 Time(s)
gavgomad
PostPosted: Sun Feb 10, 2008 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe, Jim and all!
Sorry for disappearing for awhile.... Then truth is, my CE remains "sans chassis" on my bench, as "work" has substantially impeded my progress....
That being said, I am excited to see the complete set of mods! Well done!!
If you get the time, a couple of samples showing off the finished article would, of course, be most welcome! Wink
I hope to get back on the mod wagon soon with my CE - I think I'm going to replace the electrolytics while I'm in there for "safety" sake, but I'm going to implement these mods for sure.... Almost time to put in a parts order, methinks! Wink
Gavin.
germaniac
PostPosted: Mon Feb 11, 2008 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Gav!
I missed you. Wink
Definitely sympathize with you as far as "works in progress" with all those JH PCBs sitting lonely on my shelf and still so many other projects to do. . . .
Thanks for props! As you can see by my touched-up schemo (my first foray into MSPaint, BTW), the actual mods don't look like much, but I guess most of the work was the R & D, so to speak.
I'd be happy to do some samples. I've been meaning to run some guitar through the CE-300, but other than that, is there anything particular you'd like to hear in terms of types of sounds or A/B comparisons, etc? Be as specific as you like, and I'll try to get something recorded that gives a clear idea of how this thing sounds now.
Hope you get some bench/fun time soon. . . .
Joe
gavgomad
PostPosted: Mon Feb 11, 2008 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joe! Wink
I too have a lot of projects on the shelf - JH Triple Chorus, JH Phaser on the way, MB6582 8-voice SID synth (got a tube of CEM 3372s awaiting me to design a dual Xpander filter board for this one, which I then gotta duplicate four times!), bits of a Moog Prodigy style synth, between 8-10 vcf modules for a processor controlled filter bank.... Then I have my repairs, my MKS-70, my buddy's Arp 2600, my CE....
PHEW!!!
The problem is I'm still wired on some of the new ideas coming down the line - JH's fixed filter bank, mebbe a real Dim-D clone.... It never ends!
For now, I'm settling with getting the CE modded and going, and fixing the crackly chorus in my MKS-70. The big stuff is just gonna have to wait.... Sad
In terms of A/B, I think some samples where the CE is cut in and out a couple times would be helpful. Guitar is a great source, as would be a softer pad type sound, that way you can get a sense of how the chorus behaves with swirling sounds as with percussives?
My CE is going to be used as a stereo treatment for my analogs, and in particular my beloved OB-8 - a very thick beast at times to say the least! ;-P
Given the thickness of something like the OB, I'd be very interested in how the modified CE handles complex "moving" sounds without adding the typical chorus "mud".... Might be a nice "stereo-izer" for the Triple Chorus, no? Wink
Whatever you can post to let us enjoy your work is most welcome!
Hopefully I'll have a report for you soon, then I can finally post those OB-8/CE sounds I promised! ;-P
Gav.
germaniac
PostPosted: Wed Feb 13, 2008 6:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
. . . . And now, Chapter 12, in which we find our Hero surrounded by the aboriginal peoples of the mysterious planet, and lacking any means of communication in their native tongue, he reaches for a portable music generator in his utility pack, and begins to improvise a tune to the wonderment of his hearers. . . .
. . . . A slight variety of samples with the modified CE-300. For reference sake, unless otherwise noted, all examples were done with the controls set at the exact middle of shaded areas on the CE-300's front panel.
PSS-480 PAD:
First few bars are dry mono, the remainder with stereo CE-300.
XP-60 STRINGS:
First figure is a dry saw wave mono. Next figure is the saw wave with mono "hex chorus," a Solina-like sound. Next is saw/hex chorus and stereo CE-300. Last is saw wave sans hex chorus with stereo CE-300.
ELECTRIC GUITAR:
First figure, dry guitar with very slight overdrive. Second figure, same guitar sound with stereo CE-300. Third figure, with stereo CE-300, but with controls adjusted for more DEPTH and slower RATE (which I prefer for this type of sound).
SK-1
This is a pipe from a pipe organ (blown into by mouth) sampled into the SK-1. The periodic glitches you may hear are the crude loop points. There are actually two tracks mixed together here, both with CE-300 set to almost full DEPTH and rather slow RATE.
A sidenote: I found recording through the CE-300 with a mic a bit touchy on the levels still. I now understand the argument for increasing the CE-300's output levels. This would allow a much better margin of headroom at the critical input, with make-up gain set to a fixed level at the output. A quick glance at the schemo and I would guess at raising R105/106 to 100K or so, if that didn't increase the noise too much. And I thought my mods on this thing were finished . . . a DIYer's work is never done!
Regards,
Joe
PSS-480 Pad & CE-300.mp3
 Filename:  PSS-480 Pad & CE-300.mp3
 Filesize:  788.06 KB
 Downloaded:  1124 Time(s)
XP-60 Strings & CE-300.mp3
 Filename:  XP-60 Strings & CE-300.mp3
 Filesize:  799.88 KB
 Downloaded:  1139 Time(s)
Electric Guitar & CE-300.mp3
 Filename:  Electric Guitar & CE-300.mp3
 Filesize:  635.34 KB
 Downloaded:  1163 Time(s)
SK-1 & CE-300.mp3
 Filename:  SK-1 & CE-300.mp3
 Filesize:  1.93 MB
 Downloaded:  1095 Time(s)
Audio files: 297
PostPosted: Wed Feb 13, 2008 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
germaniac wrote:
[...]he reaches for a portable music generator in his utility pack, and begins to improvise a tune to the wonderment of his hearers. . . .
I'm sure that would work, especially the treated organ pipe!
