MIDI guitar and Nord modular G2
Page 1 of 1 [10 Posts]
kaaskop
PostPosted: Wed Feb 27, 2008 5:22 pm    Post subject: MIDI guitar and Nord modular G2 Reply with quote  Mark this post and the followings unread
Jan, not sure if this should be here or the G2 FAQ - you decide.
I noticed last year, when scanning the forum after I received my G2 Engine, that there appears to be a misconception that the G2 can't process the 6 guitar strings on 6 different midi channels.
I created a simple solution, but never posted it here.
Some questions on the midiguitar forum just reminded me, so I post it now.
Example:
Strings 1 - 6 = chan 1 - 6.
1 - 4 to slot A - D.
Use NoteZone (put in FX section) to transmit 5 to slot A and 6 to slot B. Slot A now has string 1 and 5, slot B 2 and 6.
If you want to keep processing completely separate for each string in slots A and B, use note ranges.
Udo
PostPosted: Wed Feb 27, 2008 5:34 pm    Post subject: Re: MIDI guitar and Nord modular G2 Reply with quote  Mark this post and the followings unread
I'll leave it to you or anyone having an opinion ...
This is a clever trick! Will remember it I hope when the issue comes up again, thanks Udo.
edit: I changed my mind, and moved this to the FAQ section, otherwise I'll never find it again Wink I left a link at the original location.
GovernorSilver
PostPosted: Thu Feb 28, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Udo!
Bob, you see this? Cool
Some old stuff on VIRB
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Feb 28, 2008 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
post your solution please (prf2).
if this is truly working (my 2 G2's are at a different location so I cannot test it out), and you do not get trigger interruptions, than this is golden.
Govn'r Silver (you must be a donkey and not an elephant, am I right), who is Bob? Do you mean Rob? Cool
/Dasz
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Feb 28, 2008 4:54 pm    Post subject: Re: MIDI guitar and Nord modular G2 Reply with quote  Mark this post and the followings unread
kaaskop wrote:
Example:
Udo
That is nice solution.
I am not a good guitar player so I have to ask, would it be a problem if bending string 1 or 2 also changed pitch of string 5 or 6?
GovernorSilver
PostPosted: Fri Feb 29, 2008 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Dasz
Yo Dasz... I mean the user "Bob The Dog" who asked way back whether the G2 was suitable for MIDI guitar, then said it can't take more than 4 MIDI channels, thus prompting Udo's response more than a year later Wink. I think his name is Andy.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Feb 29, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I know Andy. Met him at the European Modular Event. Nice chap.
/Dasz
Correct, haven't seen him in a while ... hope it's his business running well Very Happy
BobTheDog
PostPosted: Tue Apr 01, 2008 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm back, been sunning myself in India again, only lost 1 stone in weight this time, must be getting used to it!
I will give this idea a go and see what happens.
Andy
BobTheDog
PostPosted: Tue Apr 01, 2008 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I just read this thread again, I am pretty sure this will not work as g2ian states the string bending is going to muck things up.
