AbjectEvolution
ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Feb 29, 2008 10:45 pm Post subject:
The dimmer packs are redundant unless you get 16 conventional spotlights or cans.
The Led Lights will respond directly to DMX commands to vary brightness so do not require dimmers.
Unless the DMX controller can output more than 16 channels (bank switching?) you will probably come up a bit short. Are you planning to have someone operate the controller in real time? In the hands of a good operator, it could still do some pretty good stuff. The midi to DMX feature might be worth looking into if you use midi sequencing and want complete synchronized automation. |
AbjectEvolution
Posted: Fri Feb 29, 2008 10:48 pm Post subject:
Alright, that's fine I didn't really pay for the dimmers... they came with the controller. I'm sure I will use them at some point though because I want more lights later on down the road.
As far as I can tell, the controller only has one DMX IN and one OUT. Does this mean I can only hook one light up to it?
I was planning on automating the the lights so that no one has to controll them in real time. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Mar 01, 2008 12:31 am Post subject:
derekmecca wrote: | As far as I can tell, the controller only has one DMX IN and one OUT. Does this mean I can only hook one light up to it?
You can chain dmx devices, connect the out of the 1st light to the in of the 2nd, and so on. Each device can be set to respond to a range of controllers so they are independent. |
AbjectEvolution
Posted: Sat Mar 01, 2008 9:31 am Post subject:
Alright. I hooked one of the lights into the "out" on the back of the controller. I plugged in the light and it immediatly turned on. I then turned on the controller and messed around to see if I could controll the light. Nothing seems to be working. I'm going to read through the manuals again... I think I read something about having to set an address for the light or something. |
AbjectEvolution
Posted: Sat Mar 01, 2008 5:25 pm Post subject:
I am so lost.
I hooked one light into the DMX controller and chained the light into the other one. They are both on the same address because I'm pretty sure I want them to both do the same thing. I set the modes on the lights to DMX so now they stay off unless I mess with the controller, which is good.
The thing is, I cannot figure out this controller for the life of me. I have messed with every fader and button that I can, and I can't seem to get the lights to do anything. If I press the "full on" button then both of them turn on with all the LEDs displaying one color... yet I cannot change the color or do anything at all. I'm sure I am missing something very important here. |
EdisonRex
Audio files: 172
Posted: Sat Mar 01, 2008 6:08 pm Post subject:
derekmecca wrote: | I am so lost.
DMX is MIDI for lighting. Really, it is.
Each DMX device has to be set up with a unique address, and the controller then needs to address it. It's simple in concept but in implementation, it can be complex if you aren't systematic about your setup.
But DMX is really MIDI for lighting. Look at how easily they translate.
Assign each DMX device a number. Any multi channel DMX device, give each channel a number. Then tell the mixer those numbers.
Good luck. I have a DMX system at my place of work. I had to suss it out too. _________________ Garret: It's so retro.
AbjectEvolution
Posted: Sat Mar 01, 2008 6:17 pm Post subject:
Well I assigned the lights to an address... the address is "1". The DMX controller does see it and I can kinda do some things like press the "full on" button and it will make the light do something. But that's it. I don't know how to controll the individual color of each LED's, I don't know how to create patterns, I don't know how to chose wether it fades or strobes or whatever. |
EdisonRex
Audio files: 172
Posted: Sat Mar 01, 2008 6:18 pm Post subject:
each colour is a channel. That's what I was trying to say earlier.
in more complicated lighting instruments, each function is a channel. You have to set these up. _________________ Garret: It's so retro.
AbjectEvolution
Posted: Sun Mar 02, 2008 8:38 am Post subject:
It just doesn't seem like there is any way to set anything up on this controller. Maybe I'm just being stupid.
Can anyone recomend a good forum that revolves around DMX lighting? Somewhere devoted to this sort of thing so I can get some help?
I have figured out a few more things. If I chose bump button one, both lights will come on. I am guessing this is because I have the addresses on the lights set to one. In the X faders, I can move the first 3 or 4 up and down and they will cause the lights to do things... but only those first few faders. I would think that all 16 faders would affect the lights. So far, it is very limiting as to what I can do with the light. None of the sliders change the colors, they just chose different designs... and they are very sensitive. |
ian-s
Audio files: 42
G2 patch files: 626
AbjectEvolution
Posted: Mon Mar 03, 2008 12:11 pm Post subject:
Ok... I have an update. Problems abound.
I found out through someone on another forum that if I set fader 1 to 85 and fader 2 to max, that it will enable the sound activated mode. So I do this... and nothing happens. Now there are these buttons at the bottom called "bump" buttons that are under each set of faders so if I press bump buttons 1 and 2 to corespond with the faders and I hold the bump buttons down... the lights go into sound activated mode. This only works if I hold the buttons down though. If I let them go, the lights just sit there doing nothing.
Ok so I sit back down to my computer to read some stuff, and bam... out of no where, the lights start flashing to the music on their own. That's strange. Does this mean that it takes a few min for the mode to kick in or something? So they start working, yet I notice that they aren't in sync. They are chained together and are both set to the same adress and they are both moving to the music, but they aren't doing the same thing. Each of them has a different pattern and a different color. I could have sworn I set them up correctly to work together and do the same thing in sync.
I leave them on and do some interent stuff and about 10 min later or so... they just stop working. They stop responding to the music. I didn't press anything on the controller or anything, they just stopped responding to the music. I went over and held the bump buttons down, and like before... they only work with the buttons held down.
I'm not very familure with this stuff, but something tells me that my controller is screwed up or something. I would think that simply pressing the bump buttons once would activate the faders and make the lights work. They shouldn't just randomly start and stop on their own, right? And how come when they DO work, they aren't in sync? |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Mon Mar 03, 2008 1:36 pm Post subject:
derekmecca wrote: | And how come when they DO work, they aren't in sync? |
I think I read that the lights can operate in master/slave mode. If they are both set to master then they will just do their own thing. Set the second light to slave and you should get sync.
Sounds like you have a lot of reading to do, are the manuals not very good? |
AbjectEvolution
Posted: Mon Mar 03, 2008 1:38 pm Post subject:
Yeah there is a master/slave mode but I think those modes are for when you aren't using the lights with a DMX controller. There is a seperate mode especialy for DMX use which is what I am using them for.
I really need someone to read my last message and tell me wether or not you think my controller is defective. I'm leaving soon and will be able to take it back and replace it if that's the case. |
EdisonRex
Audio files: 172
Posted: Mon Mar 03, 2008 5:20 pm Post subject:
I don't have enough data to determine if your board is faulty.
The way to determine if it is faulty is to understand how it works and then to test it using known parameters, against devices that you understand the parameters of as well.
I am afraid I don't see that this is the case.
If we know more, we can help. Increasing frustration is likely if we don't know more info (well, probably increased frustration has already occurred). _________________ Garret: It's so retro.
AbjectEvolution
Posted: Mon Mar 03, 2008 5:39 pm Post subject:
I can't think of any more info to give other than the stuff I've said.
I talked to a friend about all of this and he convinced me to try programming the lights via midi since my board can use it. I have a dealing that it will be rather complicated because these lights can do so much, but hey if it works then I am Definatly willing to do it that way. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Mon Mar 03, 2008 5:44 pm Post subject:
Why not go to guitar center and see if they can help you figure this out? You might get lucky and find someone there who has received vendor training or has experience using these type of systems. Then, you could verify that your systems are operating properly, or if more reading / customer training is required. It is sometimes amazing how much help you can get when a retailer is looking at the prospect of product returns. It costs them too much not to take the time with you to make sure the equipment works. |
AbjectEvolution
Posted: Mon Mar 03, 2008 8:10 pm Post subject:
Tried that. Apparently out of all the people that work at Guitar Center, only one person understands DMX lighting, and wont be in until Wed. They are more willing to simply replace it without even knowing if it's defective than they are willing to help me figure this out. |
Danno Gee Ray
Posted: Mon Mar 03, 2008 8:17 pm Post subject:
That is sad. |
soundwave106
Joined: Nov 24, 2004 Posts: 331 Location: Elmo's Mud Wrestling Club
Posted: Tue Mar 04, 2008 6:22 am Post subject:
Danno Gee Ray wrote: | That is sad. |
That is Guitar Center. Don't expect the dollar-an-hour type people to be very good in tech stuff.
Just reading the manual (I know nothing about lighting), it sounds like maybe you are attempting to run both lights in stand-alone mode. Since you have a controller you really want to run the lights in DMX mode only. The DMX controller can then be used to set the auto-sound mode if you wish (by sending the right value over channel 1), but it's a completely different mode than stand-alone. DMX is an address based system so you should be able to set both lights to the same address value and control them simultaneously. (FYI DMX is a 512 channel based system, this system maxes at 27, so if you wanted to control each one individually you'd want to get out your binary calculator and make sure your addresses are at least 27 channels apart).
There is also the option of stand-alone master/slave; I would expect that one controller as master, and one as slave, would synchronize their auto-sound. I'm a bit leary though of auto-sound modes to begin with, so... |
Joined: Apr 03, 2004 Posts: 24373 Location: The Netherlands, Enschede
Audio files: 296
