generate 3*F sine
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Mar 03, 2008 5:21 pm    Post subject: generate 3*F sine Reply with quote  Mark this post and the followings unread
If you pass a sine wave through a shape Static module set to the 4th mode, then subtract the source sine from the result, you get a sine 3 times the input frequency (see yellow modules).
This patch amplitude modulates the sine*3 with the original sine (level shifted) to get vocal like formants. I have used the shape lfo's cosine bell which gives a sort of resonance/filter frequency sweep effect when the shape is modulated from sine to narrow bell.
CosBellResBass.pch2
example using sine frequency quadrupler
 Filename:  CosBellResBass.pch2
 Filesize:  1.25 KB
 Downloaded:  2131 Time(s)
PostPosted: Mon Mar 03, 2008 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting sounds, and dirt cheap Cool
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun Mar 16, 2008 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for any confusion, the multiplication factor is 3 not 4 as stated. I have updated the title and text of the original message.
Times 3 is much more useful Twisted Evil
