Schulte Compact A Phasing
Page 13 of 27 [660 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14, 15, ..., 25, 26, 27 Next
jhaible
PostPosted: Tue Mar 04, 2008 2:38 pm    Post subject: Re: 5w resistors Reply with quote  Mark this post and the followings unread
austrohungaro wrote:
I cant find 5W resistors Vertical Mount
I only found axial but leads are too short (or body too tall) to fin in the PCB
The one I used has axial leads, too. If yours aren't long enough, a short piece of wire will fix it.
Is is important to be exactly 5W??
The 5W are oversized, and you can probably use a lower power rating.
But that's on your own risk, i.e. you make sure that nothing gets too hot and burns.
JH.
morbank
PostPosted: Tue Mar 04, 2008 11:12 pm    Post subject: Ready to add juice! Reply with quote  Mark this post and the followings unread
I've got my pcb populated and I'm ready to try it out. But before I do I wanted to ask a few questions.
- What are the two jumper wires used for? Should I use both?
- I also noticed a few people are using small jumper on the amount connector, what is this accomplishing?
- What kind of led is needed?
Thanks to all that helped me get this far!
-Clay
jhaible
PostPosted: Wed Mar 05, 2008 12:32 am    Post subject: Re: Ready to add juice! Reply with quote  Mark this post and the followings unread
If you mean the 3 pins near R25: Either one or the other.
If you're using an ordinary log (audio taper) pot, you connect the wiper to the cw end of the pot, and label the knob "period"
If you have a -log (reverse audio) pot, you coonect the wiper to the cww end, and label the knob "Rate".
If you mean the two long ones near the Input connector: You need them both.
Depends on what colour and brightness you prefer. Can't really go wrong here.
JH.
whomper
PostPosted: Wed Mar 05, 2008 12:42 am    Post subject: 1458 -> 4558 Reply with quote  Mark this post and the followings unread
Is the 4558 a suitable replacement for the 1458?
I can not seem to track an 1458 down locally as well as 2 online ordering attempts from Futurelec rendered me a different component.
Whomper
jhaible
PostPosted: Wed Mar 05, 2008 12:46 am    Post subject: Re: 1458 -> 4558 Reply with quote  Mark this post and the followings unread
Whomper
Use a socket and try the 4558. You might need a bypass cap near this IC then.
Strange that the 1458 is so hard to get.
Anybody else has trouble getting this?
JH.
germaniac
PostPosted: Wed Mar 05, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
No trouble here. NJR/JRC still makes the NJM1458 (one of my all-round favorites), available at Mouser at least:
http://www.mouser.com/Search/ProductDetail.aspx?qs=CH5wpWWrn1PozvFdzYlxCg%3d%3d
Regards,
Joe
morbank
PostPosted: Wed Mar 05, 2008 3:31 pm    Post subject: Ready to add juice! Reply with quote  Mark this post and the followings unread
Using the 3 holes below the R25? Do I connect the center hole to the hole below the cw on the pot?
-Clay
morbank
PostPosted: Wed Mar 05, 2008 4:07 pm    Post subject: Jumper wire? Reply with quote  Mark this post and the followings unread
Jurgen, one of the phaser prototype photos (compact_clone_2007_prototype_3.jpg) from your compact phaser site shows a green jumper wire in the lower right hand corner. What is it for?
-Clay
etaoin
PostPosted: Wed Mar 05, 2008 11:34 pm    Post subject: Re: Jumper wire? Reply with quote  Mark this post and the followings unread
-Clay
I think that's just a patch on the prototype board. You'll notice the board is different in other areas as well.
http://www.casia.org/modular/
jhaible
PostPosted: Thu Mar 06, 2008 12:22 am    Post subject: Re: Jumper wire? Reply with quote  Mark this post and the followings unread
-Clay
That was the correction of a routing error in the first board.
On the boards I'm selling, this is fixed.
JH.
jhaible
PostPosted: Thu Mar 06, 2008 12:25 am    Post subject: Re: Ready to add juice! Reply with quote  Mark this post and the followings unread
-Clay
When you look where the copper traces go, that explains more than a hundred words ... the 3 pads are directly connected to the 3 pins of the pot.
JH.
morbank
PostPosted: Thu Mar 06, 2008 10:41 am    Post subject: Ready to add juice! Reply with quote  Mark this post and the followings unread
Ok, I get it now. Thanks.
-Clay
morbank
PostPosted: Fri Mar 07, 2008 11:33 pm    Post subject: My phaser lives! Reply with quote  Mark this post and the followings unread
I fired up my phaser today and aside from the relay everything seems to be functioning Tracking down some of the parts in the US was a bit challenging (for me anyway) but hearing this thing in action makes it all worth while! Thanks Jurgen for reviving this beast and thanks to everyone else on this list for helping me get mine up and running.
-Clay
I wasn't sure where to connect the bypass switch, could that be the reason I couldn't get the relay to work? I was using the Finder relay Tobias suggested from Banzaieffects.
jhaible
PostPosted: Sat Mar 08, 2008 1:19 am    Post subject: Re: My phaser lives! Reply with quote  Mark this post and the followings unread
The bypass switch goes to the connector labelled "SWITCH", right next to the output connectors.
You need a *momentary* action switch - the electronics do a latching function.
JH.
morbank
PostPosted: Sat Mar 08, 2008 9:23 am    Post subject: Bypass Switch Reply with quote  Mark this post and the followings unread
I wasn't sure if the "switch" connector was for the "remote switch" feature.
I'll put the relay back on and see what happens with the bypass switch connected.
-Clay
jhaible
PostPosted: Sat Mar 08, 2008 9:37 am    Post subject: Re: Bypass Switch Reply with quote  Mark this post and the followings unread
-Clay
It's for both, the front panel switch, and th eremote switch jack: They are connected in parallel.
(A brief shorting the two contacts will toggle the relay status.)
JH.
morbank
PostPosted: Sat Mar 08, 2008 12:03 pm    Post subject: Slower Oscillation Period? Reply with quote  Mark this post and the followings unread
I would love to be able to get slower / longer oscillation periods, could this be achieved using a potentiometer of a different value?
-Clay
jhaible
PostPosted: Sat Mar 08, 2008 12:52 pm    Post subject: Re: Slower Oscillation Period? Reply with quote  Mark this post and the followings unread
-Clay
Yes - larger pot for OSC_PERIOD should work.
100k log should double the sweep time at the slowest setting, without decreasing fastest sweep rate.
JH.
morbank
PostPosted: Sat Mar 08, 2008 3:16 pm    Post subject: Slower Oscillation Period? Reply with quote  Mark this post and the followings unread
Cool, I'll defiantly give this a try!
-Clay
morbank
PostPosted: Sat Mar 08, 2008 4:51 pm    Post subject: 18v AC Wallwart Adaptor Reply with quote  Mark this post and the followings unread
For anyone interested in using the 18v AC wallwart adaptor Jurgen suggested as an alternative to the recommended power supply I can say that it seems to be working for me!
-Clay
morbank
PostPosted: Sat Mar 08, 2008 5:26 pm    Post subject: Relay Reply with quote  Mark this post and the followings unread
I connected the bypass switch and reconnected the Finder relay but it still isn't working... Are relays easily damaged? Perhaps I cooked it trying to get it off and then back on again?
I have a Axicom relay, anyone have know if it would work here?
http://tinyurl.com/3y4k6l
-Clay
jhaible
PostPosted: Sun Mar 09, 2008 3:06 am    Post subject: Re: Relay Reply with quote  Mark this post and the followings unread
-Clay
Does the LED work? (Toggled on and off)
JH.
morbank
PostPosted: Sun Mar 09, 2008 4:55 pm    Post subject: Relay Reply with quote  Mark this post and the followings unread
The LED turned on the first time I tried it with the relay but it didn't toggle on and off. And now it doesn't turn on at all.
-Clay
jhaible
PostPosted: Tue Mar 11, 2008 1:07 am    Post subject: Re: Relay Reply with quote  Mark this post and the followings unread
-Clay
If the LED doesn't toggle when the "SWITCH" contacts are temorarily shorted, maybe there's a problem in the control circuit around the CD4007.
If it comes on "on" sometimes, and "off" some other times, that might mean the electronic latching function is working, but can't be controlled from the outside ...
To check this, take a look at the components from the SWITCH connector to the CD4007.
To test the relay in the circuit, temporartily short C to E of the relay driving transistor. That should turn the relay and the LED on.
JH.
morbank
PostPosted: Wed Mar 12, 2008 10:01 am    Post subject: Relay Reply with quote  Mark this post and the followings unread
If the LED doesn't toggle when the "SWITCH" contacts are temporarily shorted, maybe there's a problem in the control circuit around the CD4007.
The LED does not toggle when shorting the Switch contacts.
The LED isn't coming on at all. However it did light the very first time I connected the relay.
Soldering looks ok. Here are the specs for the parts I am using, could I be using the wrong parts?
100k - R79 = http://tinyurl.com/2k2fjt
1meg - R78 = http://tinyurl.com/2u2z5u
1n - C30 = http://tinyurl.com/yw8srn
To test the relay in the circuit, temporarily short C to E of the relay driving transistor. That should turn the relay and the LED on.
Shorting C to E, I can hear the relay switching but the led doesn't come on.
-Clay
