ThruZeroVCOPCBproject
Page 1 of 3 [61 Posts]
Goto page: 1, 2, 3 Next
toppobrillo
PostPosted: Tue Mar 04, 2008 7:16 pm    Post subject: ThruZeroVCOPCBproject Reply with quote  Mark this post and the followings unread
so i now intend to pursue this PCB as my next project. since the core is based on the EN129, i will seek the appropriate permissions as randal did. this is a pretty big project- user input would be helpful and appreciated in order to finalize the design. if anyone is interested in collaborating on this, let me know...
this would entail building the circuit, at least temporarily, and putting it through it's paces- making appropriate measurements and criticisms and hopefully contributing ideas. you could even help with the PCB layout if you want to. so, you should have some test/synth gear and experience with this stuff.
alrighty right then...
edit: hope it is ok to start a new thread as this is a new project.
toppobrillo
PostPosted: Wed Mar 05, 2008 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
urrrggghhh.... Eagle is not happenin'!
Coriolis
PostPosted: Wed Mar 05, 2008 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Huh?
C
toppobrillo
PostPosted: Wed Mar 05, 2008 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Huh?
oh, i just mean that Eagle is really frustrating to use. counterintuitive and clunky. what are the hot-keys? are there any????
PostPosted: Wed Mar 05, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
yeah- that's why I too ditched it! The library wasn't that hot either, but I don't know about now Confused
Is PCBexpress not good enough?
ACHTUNG!
toppobrillo
PostPosted: Wed Mar 05, 2008 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, i haven't tried PCB express, because you can only use their service with that software correct? i haven't checked lately, but i seem to remember not being too hot on their service- quick turnaround but really expensive [especially since we are trying to pay the PCB orders up front] and i seem to remember that the boards in my price range didn't even have soldermask? maybe i'm wrong.
i will double check.
toppobrillo
PostPosted: Wed Mar 05, 2008 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, i checked. too expensive, and not all that impressive. good for a one-off proto type of service i suppose.
the software i used for the 281 was Diptrace, and it is really awesome! it's just that it's limited to 250 pins per project in the free version. i forget how much it costs to register, but it's more than i got right now, for sure.
maybe there's a way to split the cost of registry up if you do a multiple licensing, like what an academic institution would use, for instance.
i encourage everyone interested in PCB and schematic layout to at least try this software and experience how easy it is to use.
PostPosted: Wed Mar 05, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay then Josh, howabout QCad?
check QCad out. It's a bargain!
www.ribbonsoft.com
Basically QCad works rather like AutoCAD- but is more GUI driven rather than command-line driven (although that is there if you need it). It also has a vast dxf based library (free- including electronic symbols). Best of all (apart from it working on Linux, OSX and Windows), is that it only costs $26!
(No- I'm not on commission- but I really believe in this software Very Happy )
Oh yes, I should also mention that not only can you design PC boards with QCad, but you can also design the case and the front panels- in fact, because it's CAD, you can design almost anything you can think of!
Tom Smile
ACHTUNG!
frijitz
Audio files: 54
PostPosted: Wed Mar 05, 2008 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might also look at freepcb and tinycad.
Ian
toppobrillo
PostPosted: Wed Mar 05, 2008 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the tips ian. freepcb looks good.
Coriolis
PostPosted: Thu Mar 06, 2008 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I use this:
http://www.abacom-online.de/uk/html/sprint-layout.html
Easy to use, exports to gerbers, gif's and such. Coolest thing is, you can IMPORT a bitmap of an existing layout, scale it, draw on top of it, etc.
Great for touching up something if you think it's a bit to fine-lined for press and peel, or if you want to mod an existing design...
Oh, and you can actually print from it, to scale...not like expressPCB!
No limits on pins or anything either.
C
PostPosted: Thu Mar 06, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
....and then there is always Lochmaster. Andrew "Unkle Krunkus" uses this. Veroboard is cheap and easy to use too.
http://www.abacom-online.de/uk/html/lochmaster.html
ACHTUNG!
Clack
PostPosted: Thu Mar 06, 2008 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Well if you need help doing the layout in eagle i'd be glad to help - even if its to draw the initial schematic and do the monotonous parts
Clacktronics.co.uk
numbernone
PostPosted: Thu Mar 06, 2008 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Sprint looks like a winner to me. I get the feeling it is much less dense than Eagle which has stumped me every time I have loaded it up. But still closer to PCB express, which is where I learned to layout a board, and has subsequently come to the end of its usefullness due to its limitations.
I may be the only one, but I love drawing PCBs by hand, can be very challenging and keeps my brain pumping.
PostPosted: Thu Mar 06, 2008 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
you can do it with expressPCB (JFYI). i did it.
Tim Servo
PostPosted: Thu Mar 06, 2008 9:31 am    Post subject: ThruZeroVCOPCBproject Reply with quote  Mark this post and the followings unread
Couple o' observations / questions here:
QCad looks like an interesting program, but will it export Gerber files? This is a MUST if you're going to have professional PCBs manufactured. Also, since it's not really a PCB design program, you would be missing features like netlist import (allows you to relate the PCB design to the schematic, and makes sure that all parts and connections in the schematic are present on the PCB). I've designed PCBs in CAD, and it is okay for simple stuff like power distribution boards, but I would hesitate to lay out a complex project (like a VCO) without the features a PCB design program offers.
Sprint looks like a very capable program, but it also looks like it doesn't have any schematic layout capabilities. There are other ways to create a schematic and generate a netlist, but the sPlan schematic editor is another $60 (39euro). Still, you could get both Sprint and sPlan for about $120, and that's not bad. Looks like Sprint is set up only for single or double-sided boards, but that fits the bill for 99.9% of DIY boards.
I may have to look at Sprint, but the program I currently use includes schematic design, PCB layout, and even a Gerber viewer (so you can double-check those files before sending them off to be fabbed), AND it's free:
http://www.lis.inpg.fr/realise_au_lis/kicad/
It has a few quirks to be sure, and I've had to create my own schematic components for things like the 8038 chip, but the price is right and it gets the job done!
And with that, I'll now shut up and go back to my morning coffee. Smile
Tim (CAD geek at his Day Job) Servo
PostPosted: Thu Mar 06, 2008 10:08 am    Post subject: Re: ThruZeroVCOPCBproject Reply with quote  Mark this post and the followings unread
2nd CAD geek here Very Happy
Wise man speaks a lot of truth!
Gerber files? Ooo-er... Embarassed Laughing
DXF and SVG?- I spend much time hunting down ways of converting all these files! Shocked
ExpressPCB may be expensive in the long run, but it don't half make good PCB's- Just look at those Klee boards! Very Happy (I think it also outputs other types of files?).
And you're right Tim. QCad isn't all that great for PCB's- but check it out anyway, because it's great for doing all those things that would normally take four times as long in AutoCAD Cool
ACHTUNG!
Scott Stites
Audio files: 96
PostPosted: Thu Mar 06, 2008 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Express PCB makes excellent boards. Proto is expensive, but once you get to a decent number of boards (100 or above), the price drops drastically. It is a bitch that you're locked into using their service, though.
My Site
etaoin
PostPosted: Thu Mar 06, 2008 12:22 pm    Post subject: Re: ThruZeroVCOPCBproject Reply with quote  Mark this post and the followings unread
Maybe I'm old school, but I just go straight into the PCB design from a print-out of the schematic. I wouldn't even know how to use a netlist Very Happy
http://www.casia.org/modular/
toppobrillo
PostPosted: Thu Mar 06, 2008 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
i always of course sketch out a general idea before i start in software.
that is how i have operated too in the past. i am used to using illustrator and another similar program for PCBs. but now it is time to step it up!
eagle, yeck. alot of moving the cursor all the way across the screen. and the tools, like the 'delete' tool, the 'move' tool... what the..??? i am used to the delete tool being my delete key, and the move being my cursor.
having a schematic to correlate to your layout is really helpful though. that's what i was trying to accomplish. the schematic i've basically finished with the Diptrace software. so we'll see.
anyway, i am leaving now for a Death Valley "spring break" Wink weekend. back at it on monday...
thanks for the discussion.
josh
toppobrillo
PostPosted: Mon Mar 17, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
so got the go-ahead from Mr. Hutchins so.. uh... here i go.
ericcoleridge
PostPosted: Mon Mar 17, 2008 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a good thread or website describing the uses/benefits of thru-zero oscillator, that someone could post a link to?
Is there a special sound that they produce, or is it their functionality that is desired? I believe they produce a quadrature function, but then, it seems like there are cheaper/less complex circuits for quadrature functions (thomas henry, etc).
So, I was wondering what it is they do, and haven't found a good explination.
widdly
PostPosted: Tue Mar 18, 2008 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think the EN-129 oscillator being discussed here is a quadrature oscillator.
You can find the original article and schematic at electronotes here.. http://electronotes.netfirms.com/EN129.pdf
..it has some discussion of the benefits of zero-thru FM. The gist of it is that you can do deeper linear frequency modulation.
I'm looking forward to this one.
fluxmonkey
PostPosted: Tue Mar 18, 2008 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
th Zeroscillator from cyndustries is a thru-zero design (and i believe the only currently available in modular format, tho doepfer may have one forthcoming). it also has quadrature outputs, which the EN design planned here does not have.
cynthia has a general descpription of her oscillator here, and a patch diagram that focuses more ideas for the quadrature function than th thru-FM.
the big draw of thru-zero in general, and the cyndustries module in particular, would be the ability to do Chowning-style fm synthesis a la the yamaha DX7 et al... that's the first patch in the diagram, and what sets this module apart from others. from what i've read this requires both thru-zero modulation capabilities and a extreme frequency stability... that will be the real design challenge with this project.
b
toppobrillo
PostPosted: Tue Mar 18, 2008 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
you should read through the original TZO thread if you haven't already- i haven't ever used a dx-7 type of synth but i have heard alot of sound samples that are really amazing; experimented with FM synthesis in the G2 demo a bit [my PCs little bit of memory can only take so much!]. i can *try* to record some sound samples that may give an idea of how Linear TZ FM sounds as compared to not. try to post something later.
josh
