keyboardsplit
Page 1 of 1 [25 Posts]
nathan
PostPosted: Thu Mar 06, 2008 2:31 pm    Post subject: keyboardsplit Reply with quote  Mark this post and the followings unread
i just got a tiny midikeyboard and am trying to use it only as notecontroller of the oscs while audioinput gates the envelopes.
i would like to be able to control both oscs independently with this one keyboard. but it doesnt work.
 Filesize:  423 KB
 Viewed:  233 Time(s)
nathan
PostPosted: Thu Mar 06, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
with "it's not working" i mean;
everything is working ok in the patch, but the keyboardsplitmodule is not filtering the keys within the stated range (which is really (too) low in the pictured patch, but changed that and still nothing)
in other words; it's following all the keys all the time on both oscs/audioinputsignals.
PostPosted: Thu Mar 06, 2008 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've got KBT tracking on on the OSCs, that will make them track the keyboard, and then you add your split signal to it so for every note up in the split bit it will go two notes up instead & weirdness like that.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Mar 06, 2008 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the example given both ranges also 'share' C1.
Wout
nathan
PostPosted: Fri Mar 07, 2008 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
i changed that to c3-b4 and c4-c5. i have a 25key keyboard.
still every note controls every frequency (of the left and the right incoming signal) at the same time.
now i think; maybe it's some global notemessages i have to turn off somewhere?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 07, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
As Jan showed you, the Oscillators get two kinds of Pitch information... If you set the Pitch Tracking on the Oscillators to 'off' they will only react to the KeyboardSplit modules.
Wout
nathan
PostPosted: Fri Mar 07, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
offcourse. Embarassed
(i allso totally missed Jan's reply.)
argh
tanks! and sorry to take up your time.
never thought of the KBT though. (firsttimer in midikeyboardusage)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 07, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Dutch, aren't you Wink "Ober, rondje van Nathan!"
first timer in midi key board usage)
Nah, first timer in Nord Modular usage! Smile
Wout
PostPosted: Fri Mar 07, 2008 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah well at times I don't read too good either Laughing
So it works now?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 07, 2008 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW completely a Dutch thread Very Happy
Electro80 Break it!
Wout
nathan
PostPosted: Fri Mar 07, 2008 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, quite weird to talk english to an hagenees.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Mar 07, 2008 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the same as to a Dikkertje Dap Wink
Wout
nathan
PostPosted: Fri Mar 07, 2008 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, allso firsttimer with nordmodular. Laughing
because, it's still not working;
(dikkertje dap heb ik meer n artisgevoel bij.) Wink
 Filesize:  431.47 KB
 Viewed:  197 Time(s)
nathan
PostPosted: Fri Mar 07, 2008 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
now the keyboard is doing nothing at all.
PostPosted: Fri Mar 07, 2008 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
From the help file Laughing
Keyb Split
Keyboard split gives you the possibility to create split sounds using only one patch. It functions as a “key filter” in which you set the limits for the key range that should pass through.
Lower
Here you set the lower limit of the keyboard range. The limit note is displayed in the display boxe. Only notes played above the set limit will pass through to the output(s). Range: C-1 to G9.
Upper
Here you set the upper limit of the keyboard range. The limit note is displayed in the display boxe. Only notes played below the set limit will pass through to the output(s). Range: C-1 to G9.
Note, Gate, Vel inputs
‘Note’ is the note control signal input. Patch the Note output of the Keyboard Patch or Keyboard Voice module to this input. ‘Gate’ is the logic gate input. This input must always receive a high logic gate signal to activate the module. Connect it to the Gate output of the Keyboard Patch or Keyboard Voice module, for instance. ‘Vel’ is the velocity control signal input. If a gate signal and a note control signal that lies within the Lower and Upper limits are received, the velocity value of the ‘Vel’ input will be transmitted to the ‘Vel’ output.
Note, Gate, Vel outputs
These are the outputs for the note, gate and velocity signals.
Note signal: Bipolar
Gate signal: Logic
Velocity signal: Unipolar
nathan
PostPosted: Fri Mar 07, 2008 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
haha,ok. frkn amateur i am.
i read the manual, but thought gate in always needs gate out, but offcourse not.
you guys are great! thanks, it's working!
 Filesize:  432.72 KB
 Viewed:  154 Time(s)
PostPosted: Fri Mar 07, 2008 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
PostPosted: Fri Mar 07, 2008 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
But we need an mp3 as proof Laughing
weim
PostPosted: Sun Mar 09, 2008 3:04 am    Post subject:   Reply with quote  Mark this post and the followings unread
oooh... i read this topic 2 times, but i have patch where envelope generators must trig by a gate signal from keybsplit. but only one env gen trigs, another one stays down. Rolling Eyes
whats wrong with it? Question
 Filesize:  131.31 KB
 Viewed:  156 Time(s)
some kitchen live videos
PostPosted: Sun Mar 09, 2008 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The split modules get no note input so they don't know what to split. The default value an unconnected input has is 64 (or E4 I think), so the left splitter will be active here and the right one will not.
Connect the note output from a keyboard module to the note inputs of the splitters, that should do the trick.
And welcome weim.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 09, 2008 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wonder...
Why does everybody send in *.jpg instead of *.pch or *.pch2?
Can't load these into the synth, so what's wrong? The wrong File Type Very Happy
Wout
weim
PostPosted: Sun Mar 09, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
wooohoooooo guys! thanks a lot)
tnxs to Blue Hell - you were right - i must connect note trig and all become well)
thank you for such a warm reception, it is pleased for me)
and special for Wout Blommers - im upload a patch file
it is very simple sound, but im newbie in modular so be patient for me)
and also a work about it and i hope it became sounds better)
Wink
patch.pch
 Filename:  patch.pch
 Filesize:  1.72 KB
 Downloaded:  163 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 10, 2008 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
If we can load the Patch into the synth, it's much more easy to detect the troubles, if there's more then one.
Wout
nathan
PostPosted: Mon Mar 10, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i started it.
Twisted Evil Laughing
PostPosted: Mon Mar 10, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's OK, saved me the trouble of having to fire up the editor Laughing
