Markov chains
Page 1 of 1 [21 Posts]
Rix
G2 patch files: 25
PostPosted: Mon Aug 09, 2004 3:55 am    Post subject: Markov chains Reply with quote  Mark this post and the followings unread
Has anyone ideas how to implement a Markov Shocked chain with the G2?
These are ideal for generation of musical patterns (rythm, note or chord sequences) based on simple statistics.
Take for instance 3 notes, c, d e. The system can be in any of these 'states', (c, d or e).
The chances of going from one state to the other are :
c -> c : 0.3 (from c to c: 30% chance..)
c -> d : 0.4
c -> e : 0.3
d -> d : 0.2
d -> e : 0.5
etc...
It is often depicted in a Markov diagram showing the states as circles and arrows pointing at the other (or same) state with the chances alongside it.
Markov chains (from communications theory) are also an excellent tool to analyse music. E.g. you could feed a Markov system with Bach and Prince pieces, and out comes a Bach/Prince composition!
But back to simple basics:
How would we do this in the G2?
We would need variable chances depending on the current state we are in.
Richard
egw
G2 patch files: 8
PostPosted: Mon Aug 09, 2004 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I did a markov chain on the classic NM. It would play a chord sequence and transition between states based on a probability matrix. The logic was quite convoluted, but it should be much easier on a G2.
Rix
G2 patch files: 25
PostPosted: Mon Aug 09, 2004 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Heey .. great!
Would you still have the NM patch as a reference?
Richard
Audio files: 229
PostPosted: Mon Aug 09, 2004 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not trying to discourage anyone from doing anything experimental things on the G2, but my take on these complex copositional algorithms is that it is more productive to use a computer program that is designed for this purpose. I use Keykit which is free and quite fantastic. It was written by Tim Thompson, AKA TJT, a memeber of the electro-music.com forum. There are other possibilities like MAX and ArtWonk, http://algoart.com/artwonk.htm. If an all-in-one system is desired, the Kyma system might be a better choice. http://www.symbolicsound.com/cgi-bin/bin/view/Company/WebHome
The are many more.
You can probably build a house with a Swiss Army Knife, or even a G2 for that matter, but there is something to be said about the right tool for the right job.
That said, let's see what the G2 can do with Markov chains.
BTW, I've heard lots of Markov chains music, but not much sounds very good to me. Intellecturally this stuff if facinating, but it doesn't seem to pan out. I would love to be proven wrong.
egw
G2 patch files: 8
PostPosted: Mon Aug 09, 2004 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I still have the patch. If you want to contact me off-line I'll send it to you. It might even be in the NM archive, it's called "progger."
But I'm not sure it's worth the effort to study (unless you're highly motivated) due to it's complexity. It uses a set of S&H modules for each bit of the state register. And a bunch of compare modules to encode the probability matrix. The more sophisticated logic modules, flip-flops, controlled switches, A/D converters etc. will make this much easier on the G2. Unfortunately it will be a few weeks before I have a chance to do any G2 programming.
Anyway I agree with Howard that the results of this sort of thing are often less than satisfying. Now I mostly use pseudo-random patterns, you can specify the length you want, then just dial through them until you find one that sounds good. It's alot easier (and more fun) than entering sequences one note at a time.
Rix
G2 patch files: 25
PostPosted: Mon Aug 09, 2004 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys.
Mosc, you are probably right: it is far more easy to do Markov chains in a programming language than on a modular system. I might write some Delphi midi code for that, when I have time...
BTW, interesting links about these music systems!
Is this Kyma system and the hardware box represented in Europe?
Richard
Audio files: 299
PostPosted: Mon Aug 09, 2004 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Rix wrote:
TIs this Kyma system and the hardware box represented in Europe?
It never was, all transaction went with Symbolic Sound corporation directly, and I don't think this changed as it seems to be their way of doing bussiness. But from what I heard I think they are very friendly and helpfull people to deal with.
Jan.
Audio files: 229
PostPosted: Mon Aug 09, 2004 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
There are many Kyma systems in Europe, but I'm not sure if there is a dealer or representative. I think Jan is right. I have one and am ashamed I've never gotten much done with it. The people at Kyma are the best. Customer support is as good as it can get. The only problem with Kyma is that the system is pretty expensive, and the learning curve is steep. It's very open too. I have used it for auto panning in surround sound. Kyma is used by sound designers and producers for major Hollywood movies and commericals. Also, game designers are big into Kyma.
pstnotpd
G2 patch files: 5
PostPosted: Mon Aug 09, 2004 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, have you got the Kyma X software up already? I was asking around here but it's pretty well unknown over here.
Patrick
Audio files: 229
PostPosted: Mon Aug 09, 2004 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I have Kyma X.
Audio files: 299
PostPosted: Tue Aug 10, 2004 11:29 am    Post subject: Re: Markov chains Reply with quote  Mark this post and the followings unread
Rix wrote:
Has anyone ideas how to implement a Markov :shock: chain with the G2?
I'd try something along the lines in the patch attached. It's not correct now as a state currently is made up four states and the sum of the transition probabilities is not enforced to add up to 1.
And it's limited to only eight states, which sounds pretty boring still to me
Jan.
mkv_try.pch2
an idea for Markov chains
 Filename:  mkv_try.pch2
 Filesize:  6.39 KB
 Downloaded:  2939 Time(s)
Rix
G2 patch files: 25
PostPosted: Tue Aug 10, 2004 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey ... nice!
kind of minimal music indeed.
Richard
Audio files: 229
PostPosted: Tue Aug 10, 2004 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It certainly sounds Markovian, but yikes, it's not really intuitive looking at your patch. Laughing
Audio files: 299
PostPosted: Tue Aug 10, 2004 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
... and it should be more complex even ... to account for note length, tempo & all those other interesting details.
Instead of more of the same complexity I added some different semi-random treatments, it might end up as a noodle some day.
Jan.
(Who couldn't find the magic Bach setting for the knobs)
Audio files: 299
PostPosted: Sun Aug 06, 2006 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
To answer a question raised in http://electro-music.com/forum/topic-12698.html
I think I'd do it a bit different nowadays, the synching seemed wrong.
mkv_try_2.pch2
Another go at Markov chains, well not that different really, just fixed some synching.
 Filename:  mkv_try_2.pch2
 Filesize:  6.95 KB
 Downloaded:  2655 Time(s)
Audio files: 299
PostPosted: Mon Aug 07, 2006 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
And another go, the cheapest one I could come up with, and it may be the most correct as well.
It is assumed that the speed osc and the select osc run asynchronously, so that the zero crossing of the speed osc can be used to take a sample at a time that can be considered to be randomly distributed.
Meanwhile the select osc is speed modulated by the sequencers such that a low current setting of a sequencer step will make the select osc run slower, which corsesponds to a higher chance that an asynchronous zero crossing on the speed osc will select that step as the new state.
So remember: a low setting for a sequencer setting corresponds to a high chance.
A chance can not however be set to "1", for that to happen the select-osc should be linearly speed modulated, using the shape LFO (speed modulating it on it's dir input) should make that possible, but more expensive and possibly too slow. Maybe a PM audio osc ?
mkv_try_3.pch2
Yet another go at the Markov thing
 Filename:  mkv_try_3.pch2
 Filesize:  4.52 KB
 Downloaded:  2619 Time(s)
astroid power-up!
PostPosted: Mon Aug 07, 2006 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
whoa. that is really cheap. looks good.
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Aug 08, 2006 11:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is an expensive way to implement a Markov chain, so zero page hungry that I can only get a 6 state example into one slot Sad
The variations are setup as follows…
    1.Each state has equal probability, just random.
    2.Each state gives 100% probability to next state, simple forward sequence.
    3.Varying probabilities including repeating same state for timing variation.
    4.Same state is zero probability, no note repeat. Spare percentage is given to next state in sequence so it is twice as likely as others
sixstate.pch2
6X6 state matrix
 Filename:  sixstate.pch2
 Filesize:  5.71 KB
 Downloaded:  1946 Time(s)
PostPosted: Wed Aug 09, 2006 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I know one shop that used to sell Kyma's, not sure they still do.
For just doing a markov chain and sending notes over MIDI I think it's a bit overkill I'd go with PureData, SupperCollider or ChucK; all of those are very good at that sort of thing and are free. Doesn't need to be hard on the cpu either.
Just write the chance stuff as a function, then loop over alplying that function to the curent note and sending the note over MIDI.
lamarcph
G2 patch files: 4
PostPosted: Wed Aug 09, 2006 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am supposed to be studying dynamic/linear programming (as in tabular method, not writing code), I passed last weekend deep into numeric methods for a exam on monday. For five minutes, I am taking a break from all this non-sense, escaping the reality of the summers final exams and what are we talking about?
Markov chains...
Rolling Eyes
Ok, maybe I started an engineering degree to understand all this. But, now that I do start to understand, my G2 is collecting dust.
Patching season resumes friday 11th, 1:30pm.
astroid power-up!
PostPosted: Wed Aug 09, 2006 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
hahaha!
sorry about that
