Triangle to Saw waveshaper - anybody? hello?
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
bubblechamber
PostPosted: Thu Mar 13, 2008 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
that went faster than I expected. this is sort of a complicated design. it took me a couple of hours to get it working properly, but it's worth it. I've disconnected the Pulse out, but the PWM works great, on the SAW out. it modulates the 2 halves of the SAW wave separately. A pulse driving this instead of a SQUARE wave produces an asymmetric SAW, the join point is somewhere other than at 0v. And anything other than a perfectly symmetrical TRIANGLE causes a convex or concave ramp. A SINE really messes things up and for maximum chaos use waves from different, non sync'ed VCOs to drive it. When the TRI and SQR are out of phase + PWM all sorts of cool stuff starts happening. good luck. feel free to PM me if you run into problems
 Filesize:  119.02 KB
 Viewed:  470 Time(s)
sneakthief
PostPosted: Thu Mar 13, 2008 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you don't mind me asking, what FET did you use?
Sneak-Thief - raw electrofunk
bubblechamber
PostPosted: Thu Mar 13, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
MPF-102
sneakthief
PostPosted: Thu Mar 13, 2008 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank-you sir bubble!
bubblechamber
PostPosted: Thu Mar 13, 2008 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
no problem. this is a really cool waveshaper. I've been having a lot of fun with it today.
Tim Servo
PostPosted: Fri Mar 14, 2008 2:32 pm    Post subject: Triangle to Saw waveshaper - anybody? hello? Reply with quote  Mark this post and the followings unread
I'll have to try fiddling with this a little more. A very similar waveshaper is used on the Thomas Henry LM VCO, and on the Magic Smoke 566 VCO (also a TH design). Messing with the pulse width or driving it with different waves is something I've wondered about but never tried. Thanks for the inspiration!
Tim (fiddling with a fiddle) Servo
