Buffer Override on a G2?
Page 1 of 1 [8 Posts]
kcinsu
G2 patch files: 6
PostPosted: Sat Mar 22, 2008 8:33 pm    Post subject: Buffer Override on a G2?
Subject description: anyone done one?
I was wondering if anyone has tried to recreate the bufferoverride plugin on the G2. Is it even possible?
I think it's a bit beyond my skills at the moment, but I'd love to have that functionality on my G2. Apparently the new Virus TI update will have something called the Access Atomizor, which is basically a buffer override built into the TI.
Anyone?
cappy2112
PostPosted: Sat Mar 22, 2008 11:46 pm    Post subject: Re: Buffer Override on a G2?
Anyone?
Would you post an mp3 of what the buffer override sounds like?
The term is not apparent to me.
kcinsu
G2 patch files: 6
PostPosted: Sun Mar 23, 2008 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
http://destroyfx.smartelectronix.com/
dl the plugin here, and check it out.
astroid power-up!
PostPosted: Tue Mar 25, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's a germ of an idea on how to do this
buffer effect.pch2
 Filename:  buffer effect.pch2
 Filesize:  1.7 KB
 Downloaded:  1657 Time(s)
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
astroid power-up!
PostPosted: Tue Mar 25, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
with timing and gating.
buffer effect timed.pch2
 Filename:  buffer effect timed.pch2
 Filesize:  2.01 KB
 Downloaded:  1651 Time(s)
astroid power-up!
PostPosted: Tue Mar 25, 2008 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
incrementally more musical version, optimized for drum loops (the input peaks trigger the delays)
bufferperf.prf2
 Filename:  bufferperf.prf2
 Filesize:  6.45 KB
 Downloaded:  1581 Time(s)
astroid power-up!
PostPosted: Tue Mar 25, 2008 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
this starts to approach music with some verbings and filterings
bufferperf2.prf2
 Filename:  bufferperf2.prf2
 Filesize:  7.18 KB
 Downloaded:  1751 Time(s)
Audio files: 320
PostPosted: Tue Mar 25, 2008 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice chopper, that last one Cool
