problem getting gates AND CV from 4017
Page 1 of 2 [47 Posts]
loss1234
PostPosted: Sun Mar 30, 2008 5:59 pm    Post subject: problem getting gates AND CV from 4017 Reply with quote  Mark this post and the followings unread
i have been trying to build a mini sequencer of sorts of based on the Baby 10 and a few other 4017 designs, but basically they all work in the same manner. However, here is the problem. I can only get the gate to trigger my Envelope on the start of each new cycle (so on a 4 step pattern, the gate only fires on the 1, not the 2, 3, and 4)
i am using a diode from each step, tied together into a jack for the gate out. for the cv, i am using a pot off of each step, with all the steps once again tied with diodes at the end to a jack. the cv works fine.
thanks
Joel
PostPosted: Sun Mar 30, 2008 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a look at building one a while ago, I think the problem is these tend to have "gate" out not "trigger" - ie. for each step, the gate output is high for the whole step. As the gap between steps is essentially nothing (except where the sequence loops back to the beginning), the gate output is constantly high so you only get one triggering event. Have a look around for a gate to trigger converter, think one was mentioned recently....
RF
Audio files: 28
PostPosted: Sun Mar 30, 2008 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've used this with 4017 seq's...
http://www.cgs.synth.net/modules/cgs24_gatetotrigger.html
Good Luck!
Bruce
PostPosted: Mon Mar 31, 2008 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
we would need a gate2trigger converter for each step before we mix the gates/triggers, don't we?
Joel
PostPosted: Mon Mar 31, 2008 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering, could you just tap off the 555 timer (presuming that is what is driving the sequencer) - as this goes hi-lo for each step of the sequence?
PostPosted: Mon Mar 31, 2008 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
sure, but using the input trigger won't enable you to switch on/off triggers for each step.
Clack
PostPosted: Mon Mar 31, 2008 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
you need to use a gate to trig for every step
econimically , you can use a 40106 (or any inverter or nand ) to create a trigger from a gate for each step, as bugbrand told me in a lunetta thread:-
You can use a 40106 gate to change pulse widths (ie make a trigger) - have a look at the osc schem I posted --- feed a regular sqr through a low value cap and then into a 40106 gate, plus a 22k resistor tied to ground or V+.
if that works, thats 8 gate to trigs a chip, i think it works by inverting a quikly rising slope - in inverse thats a quickly falling blip. cap size and resistor determins trigger length, you should try get it somewhere near 1msec ( I think this is electronotes standard, and a lot of circuits apply to that - not completely sure though ) .
Clacktronics.co.uk
richardc64
Audio files: 26
PostPosted: Mon Mar 31, 2008 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Mr Clack wrote:
econimically , you can use a 40106 (or any inverter or nand ) to create a trigger from a gate for each step...
Or, more economically:
eight AND gates, each with one input to a step output and all the other inputs to the 4017 clock in.
loss1234
PostPosted: Mon Mar 31, 2008 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
so if the gates out arent really very useful, i wonder what Mark verbos was triggering with them. in other words, fonik-your version has 2 gate outs. were you ever sucessful getting it to work as a gate source? is it possible that the gate out would work for "something"?
PostPosted: Mon Mar 31, 2008 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i use the gate outputs to gate ADSRs, VCAs and VCFs - no problem at all. the thing is: the "merge-mode" is always ON.
Clack
PostPosted: Mon Mar 31, 2008 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i think the baby 10 is a bit minimal , i think the advantage to it is you can have odd rhythems because the gates merge. you need to have switches to be able to turn off each step
(this?)
looks like it has an output jack per step and thats how it is done there. a gate to trigger per step shouldnt be to hard to implement if you want it
Clacktronics.co.uk
PostPosted: Mon Mar 31, 2008 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes. and i have a lot of fun out of it!
loss1234
PostPosted: Tue Apr 01, 2008 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
so i think what everyone is saying is this: the baby 10's gates merge, which means, unless i install some switches, i will always get a long gate?
thanks
PostPosted: Tue Apr 01, 2008 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
exactly. and as soon as you turn on two consecutive switches their gates will merge.
RF
Audio files: 28
PostPosted: Tue Apr 01, 2008 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
If I recall correctly, I used AND logic with the clock signal and the Gate from the 4017.
Sorry I don't have all the details on it - I recall I had to wrestle with it for a while til I got it to work.
bruce
richardc64
Audio files: 26
PostPosted: Tue Apr 01, 2008 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought I said that.
Try this. The "gate" will be the same length as the high portion of the clock -- half a step if the clock is a square-wave. If you want more control, add the - - - - circuit - - - - .
Didn't we already have this discussion?
 Filesize:  2.19 KB
 Viewed:  13864 Time(s)
PostPosted: Tue Apr 01, 2008 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
very elegant. i will have to implement this to my baby10. a very valuable upgrade.
loss1234
PostPosted: Tue Apr 01, 2008 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
richard thanks
it was mentioned earlier in the thread but NOT with that nice schematic!!
Smile
i will try this after work
loss1234
PostPosted: Tue Apr 01, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry for my ignorance but in that schematic are those tiny triangles backwards inverters or a switch?
(coming from the outs of the 4017)
Audio files: 316
PostPosted: Tue Apr 01, 2008 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Switches.
richardc64
Audio files: 26
PostPosted: Tue Apr 01, 2008 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
loss1234 wrote:
...are those tiny triangles backwards inverters or a switch?
Switches.
Yeah, I've been trying new symbols for my drawings. I should have left the arrowheads solid black and the switches open.
loss1234
PostPosted: Mon Apr 07, 2008 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
richard, i am going to build your mod today and i noticed that you have a cap going between the two triangles (gate length section)
any hints on cap size?
thanks
loss1234
PostPosted: Mon Apr 07, 2008 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
oops...sorry, i see a low value cap in the earlier reply.
richardc64
Audio files: 26
PostPosted: Mon Apr 07, 2008 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's something you'll have to experiment with, depending on how short and long you want your "gates" to be and the range, which will be determined by the value of the pot.
I dunno: 100K to 500K for the pot and .01 or .001 for the cap is where I'd start.
widdly
PostPosted: Mon Apr 07, 2008 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about 20 steps from a single 4017?
I think it would work. Needs a dual-gang pot though and the clock needs to be 50% duty cycle.
