today> Cancelled - Sorry Chez Mosc
Still yet another sample and hold
Page 1 of 1 [11 Posts]
frijitz
Audio files: 54
PostPosted: Tue May 08, 2007 2:09 pm    Post subject: Still yet another sample and hold Reply with quote  Mark this post and the followings unread
Here's a page describing a novel twist on the S/H concept. It's a two-part circuit: the first part fires gate and trigger signals whenever its input crosses a user-set (and voltage-controlled) threshold. The second part is a S/H fired by the trigger signal from the first part.
You can use it: (1) as a standard S/H by inputting a trigger pulse into the first section, (2) to derive gate and trigger signals from any analog signal, (3) to sample one signal based on the amplitude of another, (4) to generate randon/chaotic timing signals from continuous random/chaotic signals, (5) to generate random/chaotic voltage steps from the same, (6) to derive first return maps and Poincare sections of chaotic systems, .........
The S/H section is a high-performance design with under 5 mV/sec droop and a 30 usec charging time, allowing precise sampling at rates up to 5 kHz and more.
Circuit diagram, analysis and a demo with a chaos generator:
http://home.comcast.net/~ijfritz/ch_cir3.htm
(Apologies to Rene and his YASH circuit)
andrewF
PostPosted: Wed May 09, 2007 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Ian
thanks for sharing this one too.
Are you planning a PCB?
would a LM311 do for the comparator?
your sound sample sounds like those tibetan temple horns after a heady brew of the local datura tea Shocked good for scaring off demons...or was it for attracting them?? Confused
frijitz
Audio files: 54
PostPosted: Wed May 09, 2007 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
hi Ian
Andrew -- I would consider doing a board if there was enough interest. Perhaps people already have enough S/H's? I got a bit of flak before when I posted about this on sdiy.
Yeah, you could use LM311's, if you take proper care about decoupling and in/out isolation. I like the 2901/2903 because you get more than one on a chip, and according to National you don't even need decoupling caps.
The Tibetan horns would have sounded better if I actually used a patch instead of just raw VCO's. Confused
Scott Stites
Audio files: 96
PostPosted: Wed May 09, 2007 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
It attracted me Maybe it's a form of strange attracter? Very Happy
IMO It's certainly different enough from any sample and hold that I've ever had to fall out of the "Yet another" category - a board would be great in my book!
Scott
vtl5c3
PostPosted: Wed May 09, 2007 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The cv control over threshold is a great idea. Makes me want to revisit my old Electronotes S&Hs to see if I can modify them.
BTW, I like the pulse output too... Might be interesting if an inverted pulse out could be added for doing cascaded analog shift register type stuff, especially if you're thinking of doing a quad S&H.
Romeo
frijitz
Audio files: 54
PostPosted: Thu May 10, 2007 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Romeo
Could you expand on that a bit? You're talking about a negative-going pulse? Or maybe something like a pulse at the end of the gate?
vtl5c3
PostPosted: Fri May 11, 2007 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I got the idea from the S&H in Electronotes 61. You take several S&Hs in series. The signal to be processed goes from left to right, the triggers/gates go from right to left. I think that the triggers need to be inverted between stages to delay the previous stage from triggering at the same time as the next one. Sorry if I'm not explaining it well, I'm having a hard time putting it into words. Probably best if you pull out EN 61 and read the article.
frijitz wrote:
Romeo
Photon
PostPosted: Tue Apr 01, 2008 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I was recently building up the pcb for this one and found that all the through holes for the transistors were a bit undersized. None of my TO-92 style 2N3904s would fit. (the 3906's fit though. curious) I tried to gently open one of the holes using a miniature drill and a pin vise and managed to tear the trace off the board. I was able to repair it luckily. I ultimately solved the problem by using some transistor sockets that I had laying around. Did anyone else have this problem or did I get a bum pcb? Or maybe my NPNs had fat leads?
in any case, I'm looking forward to finishing this one up. Very Happy
peter
andrewF
PostPosted: Tue Apr 01, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same problem - fat trannie legs elephant
just soldered them onto the back of the board
frijitz
Audio files: 54
PostPosted: Tue Apr 01, 2008 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry about that -- totally my fault. I used the TO92 component out of my PCB layout program without checking the hole size. Turns out it is for devices with round leads. My suggestion is to use a fine file to reduce the lead size a bit. Another method would be to cut the leads off at a steep angle so the end fits into the hole. This error was corrected for the later runs of the board, so not everyone will have the problem.
Ian
Photon
PostPosted: Tue Apr 01, 2008 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem, Ian. Very Happy
The transistor sockets that I used have round leads.
