Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
Posted: Sat Apr 05, 2008 12:40 pm Post subject:
Added the latter as an external jar as well, and then I have one problem left :
Project nomad is missing required javea project "nmlibs", seems like a misconfiguration? _________________ Jan
Posted: Sat Apr 05, 2008 12:47 pm Post subject:
I just removed nmlibs from the projects tab in the java build path thingy .... andthen I get another error :
the project wa not built since its build path is incomplete. Cannot find the class file for java.lang.Object that seems a fundamental thing wrong in my setup  _________________ Jan
chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Sat Apr 05, 2008 12:51 pm Post subject:
| Blue Hell wrote: |
the project wa not built since its build path is incomplete. Cannot find the class file for java.lang.Object that seems a fundamental thing wrong in my setup  |
Go to Nomad project properties -> java build path -> libraries
There should be an entry like for example
JRE System Library [sun-jdk-1.6.0]
If the entry is either wrong or missing klick on the "Add Library..." button,
choose JRE System Library and choose one of the provided options (Usually this is the Workspace default JRE Option). Make sure to pick a version >=1.5 _________________ ----------------------
http://nmedit.sf.net |
Posted: Sat Apr 05, 2008 1:05 pm Post subject:
Told you it was a fundametal thingie
Ok, now I got 134 warnings ... that'better ... now when I try to run it's complaining about /nomad/nomad-source/net.sf.nmedit.nomad.boot.splash/dist/lib/nomad-splash.jar it is said to not exist ... but it is present and just sitting there smiling at me  _________________ Jan
chresan
Posted: Sat Apr 05, 2008 1:11 pm Post subject:
The warnings can be ignored - I have them too.
As for the nomad-splash.jar problem try Project->Clean and/or right click on Project-> Refresh and the run Nomad again. By the way, is the error in the console tab ? (Then show me the output) _________________ ----------------------
Posted: Sat Apr 05, 2008 1:14 pm Post subject:
It runs  _________________ Jan
Posted: Sat Apr 05, 2008 1:23 pm Post subject:
And it debugs
Right ... now I better start to understand what's going on, I looked at it a couple of years ago, it was pretty complicated and it looks like it still is ...
Thank you Christian, this would have takemn me a week without your help. _________________ Jan
chresan
Posted: Sat Apr 05, 2008 1:27 pm Post subject:
| Blue Hell wrote: | It runs  |
Great
Yes, the configuration takes a while - I plan to simplify some things to make this easier in the future.
As I mentioned before, when you modify one of the libraries in libs/ you have to run ant configure afterwards to copy the changes into the plugin directories. But since you are using eclipse there is a way avoiding the ant configure step.
For example if you want to modify the jpdl2 library then lookup the appropriate plugin.xml file - in this case
nomad/nomad-source/plugins/net.sf.nmedit.jpdl2/plugin.xml
The file contains the reference to the jar file copied by "ant configure" but you can use relative paths and point directly to the appropriate bin directory.
I am sorry but I can give you no example since this forum messes up the xml code. But most of the plugin.xml files contain both references to the jar files and to the relative bin/ location (one of both is commented out). _________________ ----------------------
Posted: Sat Apr 05, 2008 1:34 pm Post subject:
| chresan wrote: | | this forum messes up the xml code. |
Even when you disable HTML for your post? _________________ Jan
chresan
Posted: Sat Apr 05, 2008 1:35 pm Post subject:
| Blue Hell wrote: | | Even when you disable HTML for your post? |
Oops, I missed this option. It works fine when html is disabled. _________________ ----------------------
Posted: Sat Apr 05, 2008 1:42 pm Post subject:
One more question for now .. how do I continue debugging after an exception stopped execution? _________________ Jan
chresan
Posted: Sat Apr 05, 2008 1:43 pm Post subject:
| Blue Hell wrote: | | ... Thank you Christian, this would have taken me a week without your help. |
You are welcome. Also I am verry happy to have more helping hands in the nomad project.
At this point I think I should explain you the libraries so you get a basic understanding where to find things.
First, the project is highly modular. In fact you can use the libraries (jpdl nordmodular, jtheme, jpatch, ...) as standalone libs - they don't depend on the nomad application. (this is why they are separated from the nomad project)
Here is a short overview of the libraries:
jsynth - API to create a representation of synthesizer, ports (midi ports), slots, banks
jpatch - API to implement custom patch format + simple implementation + modules can be defined using xml
jtheme - swing classes for Knobs, Buttons, Displays, ... + builder to create user interfaces from XML files
nmutils - mixed/shared stuff required by these libraries
patchmodifier - randomizer, patch mutator
jpdl2 - protocol definition language
codecs - contains the midi.pdl2, patch.pdl2 protocol definition files
jnmprotocol - nordmodular message classes, communication stuff
nordmodular -
This library contains implementations of jsynth/jpatch for the nord modular synth. It uses jtheme to create the patch user interface. _________________ ----------------------
chresan
Posted: Sat Apr 05, 2008 2:04 pm Post subject:
Yes I'm using the debug view, I looked in the wrong toolbar, I remember the icons now from a previous time I used Eclipse, for some reason I did not see them but I had been looking in the run menu and that one ha them as well now ... don't know what went wrong before then, I started the debug in a different way ...
are all timeout in ms?
I get a value of 120 742 860 496 when I break in SchedulingProtocol( ).heartbeatImpl() which seems a bit much ... like uninitialized (which should not be the case, the constructor sets it to zero) ... _________________ Jan
chresan
Posted: Sat Apr 05, 2008 2:14 pm Post subject:
The timeout is thrown in the method heartbeatImpl() (in class net.sf.nmedit.jnmprotocol2.NmProtocol )
The timeout value in the exception in fact is the threshold when a timeout occurs. The value is in milliseconds and is initialised using System.currentTimeMillis() + TIMEOUT_INTERVAL.
I believe on windows the system.currentTimeMillis returns the time in milliseconds since the os was started. _________________ ----------------------
Posted: Sat Apr 05, 2008 3:08 pm Post subject:
A thing that seems note worthy is that while the program is waiting for a reply in the connect method only light messages are coming in from the synth and not the expected message type, so this may be an issue with a patch that is "too complicated" _________________ Jan
chresan
Posted: Sat Apr 05, 2008 3:17 pm Post subject:
Which messages are sent to the synth before the exception occurs ?
Perhaps modify the method void send(MidiMessage midiMessage) throws MidiException in class AbstractNmProtocol:
| Code: | public void send(MidiMessage midiMessage) throws MidiException
System.out.println("send: "+midiMessage);
BitStream stream = midiMessage.getBitStream();
and show me a copy of the console output. _________________ ----------------------
chresan
Posted: Sat Apr 05, 2008 3:22 pm Post subject:
By the way, in class AbstractNmProtocol is a method
byte[] getNextReceivedSysexBytes() which tries to fix some sysex problems and might contain a bug.
Also the method MidiMessage.create() calls the method BitStream ensureIsValidSysex(BitStream stream) . Try to check if the method returns null at some point. Then the method is either buggy or the midi message is invalid. _________________ ----------------------
Posted: Sat Apr 05, 2008 3:28 pm Post subject:
Hmm, yes will do that, but meanwhile I made an empty patch to make things simpler, and the light message are gone and still things time out, so the lights are not the issue.
Is there a good point to set a similar log on reception? Preferrably beforethe bytes have been assembled into messages. _________________ Jan
Posted: Sat Apr 05, 2008 3:31 pm Post subject:
It sends one IAmMessage now and then it times out. _________________ Jan
chresan
Posted: Sat Apr 05, 2008 3:38 pm Post subject:
The class AbstractNmProtocol contains the method
| Code: | | protected void received(byte[] data) |
The method is called each time the synth sends messages, the argument contains the message in its raw (unmodified) form.
To print the hex dump modify it:
| Code: | protected void received(byte[] data)
System.out.println("received (raw): "+PDLUtils.toHexadecimal(data));
synchronized (receiveLock)
receivedQueue.offer(data);
activity();
Later the jnmprotocol messages are created in MidiMessage.create(BitStream) where the BitStream argument contains the raw message (or the modified message). _________________ ----------------------
chresan
Posted: Sat Apr 05, 2008 3:49 pm Post subject:
Hm, interesting that the problem happens directly after the IAMmessage was sent.
The application flow is when Nordmodular.connect() is called it sends an IAMMessage (which identifies the editor) - then as reply the synth must send an IAMMessage to identifying itself.
This means that
- the IAM from the editor is sent but discarded somewhere between JDK->Vista (this is the most unlikely case in my opinion) since the synth does not receive the IAM message it does not send an reply
- the synth sends no IAM reply (also unlikely, otherwise the clavia editor would not work)
- the synth sends an IAM reply which is not supported by the protocol or is corrupted at some point
My tip is the last point, to debug this look especially in the MidiMessage.create method what happens. Does it throw an exception, is it even called ? _________________ ----------------------
Posted: Sat Apr 05, 2008 3:57 pm Post subject:
I must import something to be able to use PDLUtils I guess, but I used a simple "received: <something>" printout instead to see if I get any reception at all.
And indeed I do not receive anything at all.
I'm pretty sure though that I did have reception when I had the complicated patch loaded, so apparently the IAmMessage gets lost or something, or the reply on it of course .. but that seems less likely. _________________ Jan
Posted: Sat Apr 05, 2008 4:02 pm Post subject:
Ok, I can confirm that reception is possible, I loaded a complicated patch again and now I get the "recv : <something>" message printing and also the accept() method in NmMessageAcceptor.java (where I had a breakpoint) was hit.
Edit : in NmMessageAcceptor.accept() I mean.
Edit : fixed some typos _________________ Jan
chresan
Posted: Sat Apr 05, 2008 4:11 pm Post subject:
| Blue Hell wrote: | | I must import something to be able to use PDLUtils I guess, but I used a simple "received: <something>" printout instead to see if I get any reception at all. |
You can set the cursor behind PDLUtils and then press CTRL+Space - this will show the autocompletition window. Or just add the import statement manually
| Code: | | import net.sf.nmedit.jpdl2.utils.PDLUtils; |
| Quote: | And indeed I do not receive anything at all.
I'm pretty sure though that I did have reception when I had the complicated patch loaded, so apparently the IAmMessage gets lost or something, or the reply on it of course .. but that seems less likely. |
| Quote: | | Ok, I can confirm that reception is possible, I loaded a complicated patch again and now I get the "recv : <somthing>" message printing and alos the accept() method in NmMessageAcceptor.jave (where I had a breakpoint) was hit. |
That's good to hear. Otherwise it would be a bug in the Java midi code. But store the empty patch in the synth again so you have not too much "junk" messages.
Then take a look at the inner class ProtocolReceiver in AbstractNmProtocol. This class implements the Receiver interface from javax.sound. This is the lowest level we can observe.
What happens in
public void send(javax.sound.midi.MidiMessage message, long timeStamp) ?
- Is the method invoked
- Is there an exception:
you can wrap the whole method body like this
try
... method body...
} catch (Throwable t)
t.printStackTrace();
And also interesting to know would be if
public void close()
is called at some point. This should not happen, but when it does then send() will not be called anymore. _________________ ----------------------
