G2-JARRE
Posted: Sat Aug 14, 2004 3:27 pm Post subject:
G2 sound-demos and Roland System 700 |
It could be great to hear some more sound-demos from G2.
Is it possible to make Roland System 700(maybe not the sound) but module for module will that take to much power. _________________ Morten |
Posted: Sat Aug 14, 2004 3:37 pm Post subject:
I don´t own a G2, but I have just started out with an NM1 ( classic ). You can get familiar Roland sounds.. like the SH-3 and 5, but also System 100 / 100m and 700 from it. No problem at all. I don´t really see the point of modelling the actual synths with the G2. In order to get the Roland sounds you would partly work this by ear and not by building.. say.. a system 100.
What I am using the NM1 for right now is building old style modular patches like what you would do on a Format, a system 100/ 100m or the System 700 .. some of the patches are for use in old style sequencer tunes. However. I cannot quite see why anyone would build a copy of a 700 in the G2 or classic.. a far better synth is in there already.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
G2-JARRE
G2-JARRE
Posted: Sat Aug 14, 2004 4:44 pm Post subject:
One the idea was to have a output from each waveform as on System700. _________________ Morten |
Joined: Jan 31, 2003 Posts: 18321 Location: Durham, NC
Audio files: 235
Posted: Sat Aug 14, 2004 5:21 pm Post subject:
| I don't know how you patched that up. It is to big for my G2, over 100% DSP. Nothing is connected up in your patch either, so it doesn't play. What's the point of posting this patch? Why not wait until you get your G2 and then post a patch that you can play? |
Posted: Sat Aug 14, 2004 5:43 pm Post subject:
G2-JARRE, I guess you just cannot wait until you get your hands on your G2!?
Many old synths had simultanous output of various waveforms from the same VCO. This one.. the CAT ( Octave Electronics ) had this too. It had a "waveform mixer" with sliders. The Octave Cat II/srm is a classic.
| Quote: | Octave released this analog classic - the Cat - during the era of the Minimoog and ARP Odyssey synthesizers. The Cat is actually very much like the ARP Odyssey, so much so that ARP had sued them in the late 1970's for cloning their designs. The Cat is a monophonic/duophonic analog synthesizer with 2 oscillators capable of square and sawtooth waveforms. VCO 1 also has a triangle waveform. Each of the waveforms can be played simultaneously and mixed together and there are additional sub-octave oscillators on each oscillator to blend new and interesting sounds.
The original Cats were purely monophonic, but then came the SRM update which added the duophonic (2-voice) capability. The Cat (SRM) has a 2-note sample-and-hold feature for each voice too! The Keyboard can be switched between 2-voice (poly) and 1-voice (mono) modes. In mono mode the 2 oscillators can be stacked for a rich mono-bass or mono-lead synth sound. Poly mode limits the richness of the sound because each VCO becomes a separate dedicated voice. In this mode you can create slightly more complex melodies with overlapping notes or very basic pads. The sub-osc plays at an octave below the actual note played which nicely adds some warmth or bottom to your sounds. |
Flickr |
G2 patch files: 626
Posted: Sat Aug 14, 2004 7:36 pm Post subject:
The Cat SRM, my first synthesiser, if you don’t count the piece of sh.t Hillwood I bought when I was 13.
Actually, mixing waveforms from the same oscillator is not as useful as it first appears, from a tonal point of view. When using the oscillator as an LFO however, mixing varying amounts of square and sub-octave created a rudimentary 4 note sequencer. The CAT was a lot of fun but I was never very happy with the sound. It was very inexpensive, compared to ARP, Moog and even Roland.
Re System 700, I would say you can’t really emulate a fully patchable synthesiser because it has no fixed configuration (just like the G2) an empty G2 patch is a perfect match for a system 700 with nothing connected . In terms of module count, at a guess, I would say the G2 was at least equivalent to between 2 and 3 complete System 700’s.
Varies a lot depending on exactly what you are doing.
Having said you can’t emulate a fully patchable synthesiser, I do have a half finished VCS3 complete with matrix patch panel, it works, but is a strange way of patching and I am not sure I will ever complete it. Maybe if future upgrades make the matrix a little less cumbersome. |
G2-JARRE
Posted: Sun Aug 15, 2004 2:07 am Post subject:
I have made a new one still like System700 but with 9 osc and not 36 as the other one and some other things but it look great and I will work on it when get my G2x.
And this time it is connected so it will sound now but I will wait to post it. _________________ Morten |
Posted: Sun Aug 15, 2004 3:54 am Post subject:
| g2ian wrote: | The Cat SRM, my first synthesiser, if you don’t count the piece of sh.t Hillwood I bought when I was 13.
Actually, mixing waveforms from the same oscillator is not as useful as it first appears, from a tonal point of view. When using the oscillator as an LFO however, mixing varying amounts of square and sub-octave created a rudimentary 4 note sequencer. The CAT was a lot of fun but I was never very happy with the sound. It was very inexpensive, compared to ARP, Moog and even Roland. |
I fully agree on the waveform mixing. It is OK to have it there, but it is not as useful as one might think.. but you can use it for some subtle variation. personally I found the CATII to have a magnificent sound and it many of the highprofiled models from wellknown brands were kind of disappointing after I got the CAT. however, my CAT was labelled CATII .. the srm was to be found on the backpanel. I have heard from others that the sound form the CAT actually could vary a lot .. so either they did small changes in the model without telling anyone.. or they had issues with the quality control during production. I thought I knew everything about this synth but now I am a bit confused about the distinctions between the CAT2/CATSRM/CATII/CATIIsrm.
And they could indeed sound different.
| g2ian wrote: | Re System 700, I would say you can’t really emulate a fully patchable synthesiser because it has no fixed configuration (just like the G2) an empty G2 patch is a perfect match for a system 700 with nothing connected . In terms of module count, at a guess, I would say the G2 was at least equivalent to between 2 and 3 complete System 700’s.
Varies a lot depending on exactly what you are doing. |
The 700 was a grand system... very kool.. but I would imagine the obvious way to "copy" sounds from the 700 would be to to go for the actual patch and signal path and then just ignore the rest not in use. That is at least what I am doing right now with the NM1. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 235
Posted: Sun Aug 15, 2004 9:54 am Post subject:
There was a CAT synthesizer at the NM Event in The Hague in July. I played it a while. I thought it a nice machine. I was surprized I hadn't run across them until 2004. I guess I've lived a sheltered life.
Anyway, I agree oscillator waveforms aren't where it's at. Changing oscillatore waveforms is what gives a sound its interest and personality.
Yes, mixing 3 LOF square waves makes a nifty 8 note sequencer, except that the triggers are missing. Still, in lots of applications that's not a big set back. The complexity of the melodic line is actually much more interesting that a continuously repeating 8 note sequence you'd get from a step sequencer, and the rhythms could be varied too. |
