 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
MIDI Connection problem
Page 1 of 1 [11 Posts]
Ka5par
PostPosted: Tue Apr 08, 2008 10:39 am    Post subject: MIDI Connection problem Reply with quote  Mark this post and the followings unread
Hi!
I would like to say that I'm very impressed with what I saw in the demo video.
Because of this, it saddens me even more, that I'm unable to use your fabulous editor. Sad
OS - WinXPSP2
MIDI - M-Audio Audiophile 2496 and Soundblaster Live.
When I try to connect to my NM rack, after a while I get the following message:
net.sf.nmedit.jsynth.SynthException: javax.sound.midi.MidiUnavailableException: This function is not supported. Use the Capabilities function to determine which functions and messages the driver supports.
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:324)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: javax.sound.midi.MidiUnavailableException: This function is not supported. Use the Capabilities function to determine which functions and messages the driver supports.
at com.sun.media.sound.MidiInDevice.nOpen(Native Method)
at com.sun.media.sound.MidiInDevice.implOpen(Unknown Source)
at com.sun.media.sound.AbstractMidiDevice.doOpen(Unknown Source)
at com.sun.media.sound.AbstractMidiDevice.open(Unknown Source)
at net.sf.nmedit.jnmprotocol2.MidiDriver.connect(MidiDriver.java:79)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:320)
... 10 more
I hope there's an easy solution and the problem is caused by my ignorance Smile
julien
PostPosted: Tue Apr 08, 2008 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Which version of Java are you using? You should use at least Java 1.5 . Which card are you using to connect to your nord, the maudio or the sound blaster ? M-audio cards seem to work well with nomad, at least the midisport series.
Ka5par
PostPosted: Tue Apr 08, 2008 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Java is jre1.5.0_06.
I tried both cards with the same result.
julien
PostPosted: Tue Apr 08, 2008 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try to upgrade to java 6.
Ka5par
PostPosted: Tue Apr 08, 2008 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks, I'll try that.
In the meantime I tried a 0.2.1 version of Nomad - it works...
Ka5par
PostPosted: Tue Apr 08, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Upgraded java to v6, but still the same problem.
Has NET framework got any relevance to how java works?
I have v3.5 BTW.
Is it possible to find an answer through the differences of 0.2 and 0.3 versions of Nomad, why one works and not the other?
Ka5par
PostPosted: Wed Apr 09, 2008 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
With java 6, the error looks like this:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 11 more
http://www.kaspartorn.eu
Ka5par
PostPosted: Wed Apr 09, 2008 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Looked at the logfile of Nomad and here are the last 2 lines (maybe of relevance):
WARN : unknown listener org.java.plugin.standard.StandardPluginManager$1@856d3b
INFO : shutdown done
julien
PostPosted: Wed Apr 09, 2008 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
From the faq:
I get Midi timeouts.
Try disabling external midi clock on the synthesizer using the Clavia editor, then try Nomad again.
The library jnmprotocol was updated between the two versions. That's the reason.
Ka5par
PostPosted: Wed Apr 09, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
This is strange! Thanks!
I had MIDI clock set to "Internal" and had to change it to "External" instead.
With this setting Nomad connects to NM, but I wonder what happens to patches that use MIDI clock?
julien
PostPosted: Wed Apr 09, 2008 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad it works now.
I would say this is a temporary work around. There will be a bug fix in the end.
