 Forum index » Clavia Nord Modular » G2 Performances - Completed
sample and hold
Page 1 of 1 [4 Posts]
chucknorris
PostPosted: Tue Apr 08, 2008 11:53 pm    Post subject: sample and hold Reply with quote  Mark this post and the followings unread
hey i just wanted to post this to see if i did anything wrong (if you can be wrong in this type of thing) really what i want to know is if you guys have any suggestions or want to upload your tinkered version of this patch. oh the bell is kinda of annoying right????
april 6 S&Hfinal.prf2
 Filename:  april 6 S&Hfinal.prf2
 Filesize:  9.45 KB
 Downloaded:  1911 Time(s)
Audio files: 317
PostPosted: Wed Apr 09, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe not what you meant, but ... I got inspired a bit by the sounds ... and made it into a sort of a weird choir Shocked
april_6_sandh-choir.prf2
modded a patch by chucknorris
 Filename:  april_6_sandh-choir.prf2
 Filesize:  9.79 KB
 Downloaded:  2981 Time(s)
chucknorris
PostPosted: Wed Apr 09, 2008 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have never used the pitch tracker module before. what does it do and what is it doing in this patch. I really really like it by the way and i have only listened to slot A since i have only the demo on my computer.
Audio files: 317
PostPosted: Wed Apr 09, 2008 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
What you put performances together with the demo Shocked Cool
I'll tape a bit and attach it, its pretty nuts Laughing
The pitch follower follows pitch ... that is it looks at the incoming audio signal and tries to make a control signal out of that which when fed into the frequency control input of an oscillator should reproduce the pitch of the incoming signal. For simple sounds this works OK, but for complex sounds, like here, it does weird stuff as it doesn't understand the signal always .. sometimes that's fun.
sand-choir.mp3
A minute recorded from april_6_sandh-choir.prf2
 Filename:  sand-choir.mp3
 Filesize:  1.02 MB
 Downloaded:  2586 Time(s)
