? Convolution reverb ?
Page 1 of 1 [18 Posts]
bachus
PostPosted: Thu Mar 27, 2008 1:09 pm    Post subject: ? Convolution reverb ? Reply with quote  Mark this post and the followings unread
Recommendations for a cheep one appreciated!
PostPosted: Thu Mar 27, 2008 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.soundonsound.com/sos/jul04/articles/pcmusician.htm
SIR?
Flickr
PostPosted: Thu Mar 27, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.knufinke.de/sir/
Flickr
PostPosted: Thu Mar 27, 2008 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheap?
The full SIR2+extra IR files etc. is 300 USD. Altiverb 6 is 530 USD.
Flickr
PostPosted: Thu Mar 27, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Altiverb comes with these IR files:
http://www.audioease.com/IR/
Flickr
bachus
PostPosted: Thu Mar 27, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks but uh ... still not cheap enough -- sigh --
PostPosted: Thu Mar 27, 2008 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
SIR 1 is free?? Used to be free?
Flickr
bachus
PostPosted: Thu Mar 27, 2008 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah SIR one is priced right. Very Happy
bachus
PostPosted: Thu Mar 27, 2008 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep still is!
bachus
PostPosted: Thu Mar 27, 2008 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
much thanks
PostPosted: Thu Mar 27, 2008 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
bachus wrote:
Yep still is!
OK.. I´m slowly learning here. Free equals rather cheap? Shocked Laughing
Flickr
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Mar 27, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is one built into the Nero 8 wave editor. You just need to find your own Impulse files.
PostPosted: Thu Mar 27, 2008 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW..
Slamming one reverb on top of a full virtual orchestra is usually what people do, but it also sounds rather gloriously crappy.
Consider that an orchestra ( or a smaller ensemble for that sake ) is spread out on the stage. Even though that the main point is not to make it sound realistic, but "good" and hopefully convincing.. paying some attention to how we actually hear the noise of an orchestra is what I call a good thing. - In the same league as the single malts actually..
So.. in order to make the reverb sound good, please consider processing each instrument group or even each instrument.
Convolution reverb is excellent, but you might want to do some hard thinking re how to actually use it in a way that makes sense to you.
Flickr
bachus
PostPosted: Thu Mar 27, 2008 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
BTW..
Right I would do it on a track by track basis for a final mix for sure.
Actually at this point it's for an ambience system for the sound room. I still haven't decided how to handle the sound stage and want to experiment with ambiophonics first.
bachus
PostPosted: Sat Mar 29, 2008 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Reflect by VirSyn looks like what I need. Anybody here have any experience with this?
Grizzle
PostPosted: Sat Mar 29, 2008 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
You can get loads of IRs from Noisevault.com
A cheap convolution is Voxengo's Pristine space... $120. If that's too rich there's another free one called Red State Sound RevolVerb Lite.
It is supposed to be latency free whereas with SIR your host sequencer has to have automatic delay compensation or you have to manually compensate for delay.
www.myspace.com/grizzlemusic
bachus
PostPosted: Sat Mar 29, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks looks interesting.
While poking aruond for that I found some more here
http://www.softplatz.com/software/reverb/
Problem is I need at least 8 channels. May wait till I upgrade the puter to a mulit core to see how they or multiple instances of them run.
ar2jr
PostPosted: Thu Apr 17, 2008 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you get logic you get space designer which sounds 'expensive' Smile
