finished! - and beginning troubleshooting
Page 1 of 1 [18 Posts]
loopcycle
PostPosted: Sat Apr 19, 2008 4:55 pm    Post subject: finished! - and beginning troubleshooting Reply with quote  Mark this post and the followings unread
im only in the first stage of testing.
1. pattern A leds dont light up whatsoever.
(i will swap cd4034s to determine if this is the cause.)
2. pattern switches and led behavior work opposite as expected (stage 9-16). all leds on 9-16 are LIT when pattern switches are OFF and i manually load.
3. stage 14 led stays constantly lit. (the switch is fine.)
loopcycle
PostPosted: Sat Apr 19, 2008 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
answer=1. swapping cd4034s show one does not work. will replace.
answer=2. i assumed (NEVER ASSUME!) that the switch in "closed" position meant bit high. nope--the docs show closed being bit low. stupid me. ah well, at least i didnt label my panel yet Laughing
loopcycle
PostPosted: Sat Apr 19, 2008 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
4. have to troubleshoot the glide on channel A (a+b works fine).
5. range not working whatsoever. im a little stumped by this.
i tested the switch before soldering.
im stuck on an augmented fourth (diminished fifth?) interval for any range setting.
PostPosted: Mon Apr 21, 2008 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Dropped two "TI" CD4034 IC's in the mail yesterday for you. Give them about 3 to 5 days to get to California. Very Happy
Bill
Scott Stites
Audio files: 96
PostPosted: Mon Apr 21, 2008 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Loopcycle,
Sorry about the delay - I was gone all weekend camping in the wilds of Eastern Kansas.
Good to see you got a number of your problems solved.
For the Glide problem - does your A+B voltage come through, it's just not gliding? How about your B output - does it glide?
For the range problem: First of all, see if your switch voltages are getting to the CD4051 (U7). The switch voltages go to pins 9, 10, and 11.
With your range switch at the lowest range setting, pins 9, 10, and 11 should all be low (0V or so). That would be an easy enough test right there, actually.
If you want to test all of the ranges, the voltages would go as follows (0 being 0V and 1 being close to the positive rail):
Range Pin 9 (C) Pin 10 (B) Pin 11 (A)
1 0 0 0
2 0 0 1
3 0 1 0
4 0 1 1
5 1 0 0
6 1 0 1
7 1 1 0
8 1 1 1
Now, if these ranges aren't switching, the problem could be either the switch or a bad/reversed diode (IE, one of the switch diodes, D1 through D12). To check to see if it is the switch, you can disconnect the switch from J9 (if you used plugs) and test the switch positions one by one with with a volt meter. You could also visually eye your switch diodes to make sure they all have the cathode in the right spot, and also you could test the diodes themselves.
If things look like they're switching OK at U7, then make sure you have the trimmed voltages going to the inputs of U7 - pins 1, 2, 4, 5, 12, 13, 14, and 15 are the inputs - they should each have a different voltage on them coming from the trimposts. If *that* looks OK (you have different voltage levels on the input pins, and the control pins are switching), you should see the level changing on the ouput of U7, which is pin 3. If that is changing OK, then U7 and your switch and diodes are working correctly, if not, and the levels and switch voltages are OK, you may have a bad CD4051.
Pin 3, the output of U7 CD4051 feeds pin 3 of U6, a TL072 configured as a unity gain buffer. If the input pin 3 of U6 is changing, but the output (pin 1 of U6) is railed or unchanging, the problem would lie there.
In the meantime, try out the above measurements and tell me what you find.
Good luck and take care,
Scott
My Site
PostPosted: Mon Apr 21, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shit, Im stuck on figuring out what that really is .... I think I am having an augmented brain fart Shocked I have to get a formal musical education Wink
Bill
loopcycle
PostPosted: Wed Apr 23, 2008 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
got em! that was fast. and they work beautifully Smile thanks bill!
PostPosted: Wed Apr 23, 2008 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great news !!!! I did not want to dally on that one. I sold you a bad chip and I make good on my words .... Wink
OK, Klee away !!
BTW: I am using a picture of your Klee as one of my examples of panel designs for my talk Saturday .......
Bill
loopcycle
PostPosted: Wed Apr 23, 2008 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
uh oh, that crappy pic? ill post a MUCH better one in a few minutes right here.
EDIT: here.
loopcycle
PostPosted: Fri Apr 25, 2008 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
i made a couple videos over here.
http://loopcycle.blogspot.com
(i cant link to the actual post, since the url-title includes the terms "electro-music" and the forums auto-format these terms and break the link. Laughing )
Sound
PostPosted: Fri Apr 25, 2008 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy I like very much the klee-firstImpression2 video! Very Happy
Scott Stites
Audio files: 96
PostPosted: Fri Apr 25, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me, too!!!! Well done indeed Loopcycle!
Cool Cool Cool Cool Cool Cool Cool Cool Cool
My Site
loopcycle
PostPosted: Sat Jul 26, 2008 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
1 0 0 0
2 0 0 1
3 0 1 0
4 0 1 1
5 1 0 0
6 1 0 1
7 1 1 0
8 1 1 1
If things look like they're switching OK at U7...
switching at U7 is working perfectly--i measured all voltages at pins 9, 10, 11 for all eight switch positions.
...then make sure you have the trimmed voltages going to the inputs of U7 - pins 1, 2, 4, 5, 12, 13, 14, and 15 are the inputs - they should each have a different voltage on them coming from the trimposts. If *that* looks OK (you have different voltage levels on the input pins, and the control pins are switching), you should see the level changing on the ouput of U7, which is pin 3. If that is changing OK, then U7 and your switch and diodes are working correctly, if not, and the levels and switch voltages are OK, you may have a bad CD4051
here's where im stuck. if i tweak the trimmers, should i be seeing corresponding voltage changes at pins 1/2/4/5/12/13/14/15? i am not. no matter the switch position, voltages at those 8 pins on the cd4051 are fixed.
sorry for the delay here. i finally willed myself to get this done today instead of chasing down other projects. i really appreciate your help in getting this bit resolved Smile
Scott Stites
Audio files: 96
PostPosted: Sat Jul 26, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK. Make sure U5 (the 10V regulator) is supplying 10V to the tops of the divider resistors. I suppose checking any of these resistors (R26 through R32) would tell you that right away.
If that looks like it's OK, remove the CD4051 and check the input pins at the socket - if that makes the voltages work, then your CD4051 needs replaced.
If that doesn't work, make sure the bottom of each trimpot is connected to ground.
If all so far fails to provide an answer, let me know what voltage all the inputs to the CD4051 are fixed at.
Good luck!
Scott
My Site
loopcycle
PostPosted: Sat Jul 26, 2008 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good luck!
Scott
ok scott, you're gonna hate me for this. my cd4051 was upside down!
Rolling Eyes
wheres the emoticon that's smacking himself in the head?
so now thats taken care of Laughing
im moving through the range calibration. looking good so far, except im measuring 12.87V at pin 1 of U8 for ranges 5 and 7 only. ill have a look at the schematic to try and figure out whats going on.
PostPosted: Sat Jul 26, 2008 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
head banging monitor
I never D things upside out of course .. Rolling Eyes
Scott Stites
Audio files: 96
PostPosted: Sat Jul 26, 2008 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, don't fret...I'd be lying if I told you I'd never reversed an IC. As many ICs as are in this project just increases the odds of that happening Very Happy
12.78 Volts at ranges 5 and 7 - if you simply turned the CD4051 around, that might still be a bit suspect - it could have taken a hit from its reversal that's making it act oddly.
I suppose, check the output of the CD4051 then trace it through the circuit at those range settings - I bet you'll figure it out.
Take care,
Scott
My Site
loopcycle
PostPosted: Fri Oct 17, 2008 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, i done blowed up my 4051 by putting it in backwards.
with a new 4051 its working lovely. thanks for all your help scott Very Happy
