Franky
Joined: Dec 09, 2007 Posts: 57 Location: Grenoble - France
Posted: Sat May 03, 2008 10:29 am Post subject:
Arduino-based Sequencer Subject description: A polyvalent sequencer from an Arduino board |
Hi guys, I've bought an Arduino board (not exactly the real Arduino, a clone, but it's doing exactly the same stuff), and I had some toughts about a little (but powerfull) sequencer to do with.
Here's the thing:
8 steps
3 resets modes (4th ,6th or 8th step)
3 running modes: forward, reverse, pendullum (mirror mode)
Controls:
Frequency CV (0-5V range)
Gate Length CV (0-5V range)
Gate out - 5V
8 step-gates out (no CV, no pots)
Here's the code:
| Code: |
* ARDUINO SEQUENCER
* Source Code by: Franky
* Version: 0.1 beta
* License: Copyleft (free)
int i;
int freqPin = 0; // Analog freq control
int pwPin = 1; // Analog PW control (gate length)
int modePin1 = 8;
int modePin2 = 9;
int gatePin = 10;
int freq; // Frequency value
int gl; // Gate Lenght value
int uns; // Time Until NeXTStep
int resetPin1 = 11;
int resetPin2 = 12;
void blink(char nbre) {
char i;
for (i=0;i<nbre;i++) {
digitalWrite(ledPin, HIGH);
delay(500);
digitalWrite(ledPin, LOW);
delay(500);
void setup() {
pinMode(0, OUTPUT);
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(modePin1, INPUT);
pinMode(modePin2, INPUT);
pinMode(resetPin1, INPUT);
pinMode(restePin2, INPUT);
pinMode(gatePin, OUTPUT);
blink(3);
int moderead() {
int mode1;
int mode2;
mode1 = digitalRead(modePin1);
mode2 = digitalRead(modePin2);
if (mode1 == LOW && mode2 == HIGH) return 1;
if (mode2 == LOW && mode2 == LOW) return 2;
if (mode2 == HIGH && mode2 == LOW) return 3;
else return 0; /* Should never happen */
int resetpoint() {
int r1 = digitalRead(resetPin1);
int r2 = digitalRead(resetPin2);
if (r1 == LOW && r2 == HIGH) return 4;
if (r2 == LOW && r2 == LOW) return 6;
if (r2 == HIGH && r2 == LOW) return 8;
else return 8; /* Should never happen */
void loop() {
switch (moderead()) {
case 0:
break; /* Should never happen */
case 1: // Forward mode
for (i=0; i<resetpoint(); i++) {
freq = analogRead(freqPin);
gl = (analogRead(pwPin)*freq)/1024;
uns = freq-gl;
digitalWrite(i, HIGH);
digitalWrite(gatePin, HIGH);
delay(gl);
digitalWrite(i, LOW);
digitalWrite(gatePin, LOW);
delay(uns);
break;
case 2: // Mirror mode
for (i=0; i<resetpoint>0; i--) {
uns = freq-gl;
delay(gl);
delay(uns);
break;
case 3: // Reverse mode
for (i=(resetpoint()-1); i>=0; i--) {
uns = freq-gl;
delay(gl);
delay(uns);
break;
There are some pins available on the board, so it can be upgraded.
The code is free, you can do whatever you want with it.. _________________ Forty Seven Effects |
Joel
Posted: Sat May 03, 2008 11:08 am Post subject:
Looks great! I've got an Arduino somewhere, will have to dig it out and give this a go when I get a chance....
It uses some different methods, but have you seen the Arduino Punk Console?
p.s. what does polyvalent mean, in relation to a sequencer?
Thanks for posting, Joel |
Franky
Posted: Sat May 03, 2008 1:01 pm Post subject:
By polyvalent I mean it can run through several modes, where a classic "analog" sequencer can only go through one: forward. Here are 2 more running modes, allowing different sequences..
Wow, the punk console sounds great! Sounds like an old NES console lol..
Didn't try the audio possibilities of the Arduino so far, but i'm gonna give it a go.. _________________ Forty Seven Effects |
okvern
Joined: Feb 05, 2008 Posts: 78 Location: Seattle, Washington
Posted: Wed May 07, 2008 12:54 am Post subject:
Fellow Builders,
The Arduino is cool, definitely a platform to watch--take a look at the Arduino-related stuff at:
http://little-scale.blogspot.com/2008/02/simple-polyphonic-synth-with-just.html
I've gotten distracted by PICs lately because of a couple of projects, but I'll be going back to the Arduino soon.
re: the punk console
It's great that they used Visio for their panel layouts--I was Visio (pre-Microsoft) employee #11, title "Shapemaster," and they probably used shapes I wrote. I use it for all my panel layouts, and for some circuit board layouts.
Thanks,
Ole |
beavis
Posted: Wed May 07, 2008 8:27 am Post subject:
| okvern wrote: | Fellow Builders,
Thanks,
Ole |
I'm the guy who used visio for all that stuff
I've been around long enough to have used visio pre-MSFT, so its great to meet you!
I do schematics, enclosure layouts, drilling templates, build guides and even PCB layouts all in Visio. It simple rocks. _________________ www.beavisaudio.com |
Posted: Wed May 07, 2008 4:09 pm Post subject:
I've got a borrowed Arduino here now. I've only had it for a few days and didn't get round to it beyond a quick look at the syntax. Looks very accessible indeed, thanks for the nice links. _________________ Kassen |
okvern
Posted: Wed May 07, 2008 7:41 pm Post subject:
Hi Franky,
I think gremlins got at your code a bit in the posting process--which is pretty common when posting code on forums. This happens to me every time, and I *run* a forum! First, we're missing a define--add:
int ledPin = 13; // LED connected to digital pin 13
There's a typo in your setup function--"restePin2" should be "resetPin2".
Next, I think that this:
Should probably be:
for (i=0; i < resetpoint() > 0; i--) {
(Even though it looks like you've surrounded your code with a <code> or <pre> element, it looks like the forum decided that "resetpoint" belonged in a tag.)
Once I made those changes, it seems to compile and download fine--now I have to set up a breadboard to attach the controls. I think I can deduce what everything is supposed to be, but if you have a chance to post a note about pots/switches we need to attach, that would be great.
Thanks for sharing this code!
Ole |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Thu May 08, 2008 1:57 am Post subject:
| okvern wrote: | | (Even though it looks like you've surrounded your code with a <code> or <pre> element, it looks like the forum decided that "resetpoint" belonged in a tag.) |
Note to code posters : using the "Disable HTML in this post" option helps. _________________ Jan
Posted: Thu May 08, 2008 2:54 am Post subject:
Also; using the code tag will preserve indentation and get you a monospaced font. If you don't use it all spaces and tabs at the start of lines will be removed.
Typically it's wise to disable smileys as well. _________________ Kassen |
Franky
Posted: Thu May 08, 2008 3:40 pm Post subject:
Damn it, you're right, and it seems that a big part of the code is missing: look at the Mirror mode, it only goes one way..
I'm not using the #define system to declare my pins, it didn't work at first, so I came up to declare this way.. Anyway it's the same..
About ledPin, i'm just using it to blink 3 times once the sketch is done uploading, you're not forced to use it.. It saves a pin moreover..
Thanks for the typo mistake, I didn't compile it so I could'nt know..
New try:
| Code: |
* ARDUINO SEQUENCER
* Version: 0.2b
int i;
int freqPin = 0; // Analog freq control (analog in)
int pwPin = 1; // Analog PW control (gate length) (analog in)
int modePin1 = 8; // Reading from mode switch (digital in)
int modePin2 = 9; // idem (digital in)
int resetPin1 = 10;// Reading reset switch (digital in)
int resetPin2 = 11;// idem (digital in)
int gatePin = 12; // Gate out pin (digital out)
int ledPin = 13; // Used for blink() function (digital out)
void blink(char nbr) {
for (i=0;i<nbr;i++) {
delay(500);
delay(500);
void setup() {
pinMode(0, OUTPUT); // Output pins, digital out
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(resetPin2, INPUT);
blink(3);
int moderead() {
int mode1;
int mode2;
int resetpoint() {
void loop() {
case 0:
uns = freq-gl;
delay(gl);
delay(uns);
break;
uns = freq-gl;
delay(gl);
delay(uns);
// Steps 1 & 8 are triggered in forward loop
// reverse loop does not repeat it at the ends
for (i=(resetpoint()-2); i>0; i--) {
uns = freq-gl;
delay(gl);
delay(uns);
break;
uns = freq-gl;
delay(gl);
delay(uns);
break;
About the hardware:
For the mode button, the best is a 3 position toggle switch, on-off-on, with the center pin connected to VCC, and the others to modePin1 & modePin2 with their pullup resistors. It's the same for the reset button, and it will reset on steps 4, 6 or 8.
Each output should be connected to a pot wired as a voltage divider, with a diode (1N4148 should do the job) in series with the cursor, then connect all the cathodes together so the current can't flow back to the Arduino. And you've got your sequencer..
I can post a schematic if you want, but it's a very basic workout..
Edit: I have some thoughts about a sequencer using only switches and a few pots, like the punk console, with rotary encoders to set the pitch and the same kind of sequence modes i've got here.. _________________ Forty Seven Effects |
XeroX
Posted: Tue Nov 24, 2009 9:47 pm Post subject:
this is an old thread, but i just bought an arduino
would be nice if you could post the schematic.
and maybe someone could give me some tips where to find more about arduino and sequencer. _________________ ﻫﻚ ॐ ™ |
acidblue
Joined: Jun 26, 2009 Posts: 226 Location: The Darkside
Posted: Fri Jun 18, 2010 10:51 am Post subject:
I second the posting of a schematic.
Would be great for us new guys.
Great job BTW. |
nerdware
Posted: Thu Jul 15, 2010 7:30 am Post subject:
This is a great sequencer example! Thanks.
However, the moderead function doesn't need the series of tests to do the job. Simply shift one of the inputs, say mode2, by 1 bit and binary OR it with the other input, mode1. It'll be easier to read and it'll run faster.
I'll leave the single line of code as an exercise, shall I?  _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
cappy2112
Joined: Dec 24, 2004 Posts: 2499 Location: San Jose, California
Posted: Fri Jul 16, 2010 11:07 am Post subject:
| Kassen wrote: | | I've got a borrowed Arduino here now. I've only had it for a few days and didn't get round to it beyond a quick look at the syntax. Looks very accessible indeed, thanks for the nice links. |
I've just read an article- about Parallel programming with Arduino's
Not quite what one would expect though, but nice idea.
http://tinyurl.com/298al2e _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
