today> Bill Fox solo tonight! Chez Mosc
Low level on sound card
Page 1 of 1 [18 Posts]
okan
PostPosted: Sat Feb 16, 2008 4:33 pm    Post subject: Low level on sound card Reply with quote  Mark this post and the followings unread
i've got a G2 engine and RME multiface sound card. When i connect G2's outputs to RME's inputs, input signal level shows such low values around -28, -30 db. i've seen a maximum peak of -18 db in a patch. i am using balanced stereo cables. i expect normally -12 or -6 db including a headroom. -28 db is too much low i think.
Anyone has this issue? What about your peak levels?
Thx..
Okan
Audio files: 327
PostPosted: Sat Feb 16, 2008 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dunno .. I have a switch on my RME thingy that can be set at -10 dB, +4 dB or high gain. It is at +4dB currently and on average I get about the same readings you mention. Sometimes it's more though and the switch set to high gain will occasionally cause clipping, so I don't use that.
I use two G2s, one is playing patches and the other one conditions the signal of the first one, part of that conditioning is using two compressors, one set at medium compression that kicks in on not so loud signals and then another that compresses much more but kicks in at higher signal levels.
Without a compressor it depends very much on the patch used, some are very loud others are very soft, but on average the G2 is not very loud ... except on the damned headphones of course Twisted Evil
Anyway ... apparently I do really need to use 20 to 30 dB of headroom on the RME. And it's not really a problem I think, as it leaves me about 80 .. 90 dB of effective signal to noise margin, which is good enough for me ... well ... way better than I ever had before ... the USB sound interface I use (tascam us122) on my laptop can't even think of touching that.
So I don't really have an issue with it ...
BTW .. the G2 does not have balanced outputs, and I do not use balanced cables.
PostPosted: Sat Feb 16, 2008 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps this is offtopic, but here goes:
It is common to say that 0dbu on your analog console equals -18dBfs. You are supposed to be working with a lot of headroom when making digital recordings.
Anyways, I guess the table above kinda explains it . Be sure to know which scale you are referring to. That said, it is no disaster that you aren´t able to kick up the level close to 0 dBfs. Actually, it is rather a good thing. ( Uh.. and I´m on the EBU scale here myself. )
Jan, it sounds like you are working the right way. beer
Flickr
PostPosted: Sat Feb 16, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is as it should be and that is good enough for pros as well. You are doing this the right way. Be sure to work with 24bit instead of 16 bit samplesize when you can.
Another: beer
Flickr
PostPosted: Sat Feb 16, 2008 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW , I´m on RME as well. Brilliant gear.
Flickr
Audio files: 327
PostPosted: Sat Feb 16, 2008 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The RME has some nasty clipping when it clips, the US122 seems to have some soft clipping, as I can drive it hotter (not hot enough for it to be better than the RME though in S/N, not close even). Anyway, on the US122 I can work with a headroom of 12 dB, about the same figure I needed for the harddisk recorder I used to work with in the past (but that one had a better S/N margin than the us thing, like 95 dB or so I think) .. the RME needs more headroom, but it gives better results than stuff I've used before ... all in all that is .. and I prefer to not have soft clipping on the recorder, when I want distortion I can add it before .. or after .. but the recorder should be clean .. please Very Happy
PostPosted: Sat Feb 16, 2008 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even more offtopic:
It is well known and often hyped how various mythological pieces of analog hardware will introduce pleasing amounts of distortion to a signal when pushed hard.. running a bit on the hot side.. Yes, this is true but it is mindless to push everything way into the hot and spooky zone. The result will be a mix that is muddy and rather without detail. The weird thing here is however that people will for some reason translate the hot way of doing things in the analog domain into how they work with a digital signal. This is not good at all.
Flickr
Audio files: 327
PostPosted: Sat Feb 16, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
beer or rather today Wink
PostPosted: Sat Feb 16, 2008 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Digital clipping is nasty. There is no way around that. The RME lets it sound like it is.
It seems like that other device has some sort of near graceful distaster management. Shocked Laughing
Flickr
Same here.. or both.. and more.. Shocked Cool
Flickr
PostPosted: Sat Feb 16, 2008 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
( And now to ze helpful mode )
Anyways, it is quite easy to calibrate recording levels yourself if you know what levels tp aim for. I reckon noobies will appreciate knowing how this is supposed to work. DAWs and whatnot don´t really come with manuals that explain these basics.
Why don´t DAWs come with a 50 page PDF that explains project studio gain management and all things related. This is stuff that every owner of Cubase, Logic, Reason and what have you would really want to know when they start out.
Flickr
okan
PostPosted: Sun Feb 17, 2008 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the fast response time !!! especially electro80 and blue hell! This is my first topic. the graphic is the one i am looking for.
I guess i am also on the EBU scale. So i need some 12-18 dBfs gain. i dont have any good hardware comp yet.(sold a cheap alesis 3630 comp). i have to increase G2's volume in Logic 5.5 and Max/Msp. Vst gainers generally give about 12 db gain. What are you using for leveling?
Thanks again.
PostPosted: Sun Feb 17, 2008 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
What you could do is to get some sort of DI-line driver thingie that can throw in some additional gain. All of these devices will lift the signal to +4dBu balanced and the headroom is usually really good as well.
I think even Behringer still has some pretty decent devices. Shocked
If you take a look at that table above once again, you´ll see that you don´t want to amplify the signal too much. At 0db=-18dbfs you simply don´t need or want the signal to peak much above say -14 to -12 dbfs. And it is just as nice or possibly cooler to step back a few dbhfs as well.
Flickr
PostPosted: Sun Feb 17, 2008 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again.
You´ll see much less problems with gain if you simply invest in pro audio outboard that are balanced and at +4, like the Unversal Audio stuff. If you use DI/linedrivers for the unbalanced kiddie prosumer level synths ( this is so sad Sad ..why aren´t all synths equipped with pro audio levels and balanced outputs Shocked ) and then run everything from there at pro levels and then into the RME.
Also keep in mind that you can make the DAW recalculate a track in order to lift it some dBs. This is often called normalizing ( but that is another discussion). Anyways, this absolutely OK to do and in most cases you won´t be affecting the effective noisefloor much ( but that is another discussion altogether ).
Re normalizing:
The mistake many make is to lift absolutely every track in a project close to 0dbfs. This is not good.
Flickr
PostPosted: Sun Feb 17, 2008 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I should add that you might just as well lift the gain in the digital domain instead of using a less than great analog device.
Flickr
okan
PostPosted: Sun Feb 17, 2008 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes! Great help!
You are right. G2 has a lot of space until the the noise-floor.
i am going to use digital softwares to feed gain until i buy a good quality analog drive. i also have another 5-6 sound modules like monomachine, emu procussion...etc. i think to buy an Allen&Heath MixWizard mixer(for live PA, eq and gaining, and for grouping some channels to a sub channel before sending RME's inputs). dont have a mixer yet!
Universal Audio sounds a bit expensive but i'll buy it one day Smile
Thx again!!
Okan
very
PostPosted: Thu May 08, 2008 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow. this just explained a lot of things to me. Thanks for sharing this elektro80 !
PostPosted: Fri May 09, 2008 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
We aim to please! beer
BTW.. I mentioned a Behringer DI device in one of my previous posts.
Soon after writing that post I bought the Behringer ULTRA-DI PRO DI800. I needed more DI boxes and I figured since people have been praising the ULTRA-DI PRO DI800 then I could as well try one. I shouldn´t have done that. Sad It was awful.
The Behringer was not even close to something like this: http://www.radialeng.com/re-products.htm
The Radial stuff is good. The Behringer is an insult. I returned it.
I´ll look into some DIY DI stuff soon I guess. I need to set up some sort of balanced input for my dotcom synth.
Flickr
