Amount of reverb modulation
Page 1 of 1 [3 Posts]
heid'
PostPosted: Sat May 17, 2008 9:30 am    Post subject: Amount of reverb modulation Reply with quote  Mark this post and the followings unread
Hi',
I am trying to modulate the amount of reverb by an LFO.... and .... I don't find the patch. Embarassed If you have an idea, thank you Wink
Kees
PostPosted: Sat May 17, 2008 10:37 am    Post subject: Re: Amount of reverb modulation Reply with quote  Mark this post and the followings unread
heid' wrote:
Hi',
You can connect an LFO to a MIDI control send module.
Then assign this MIDI controller (in this case controller 20) to the Dry/Wet parameter of the reverb module and there you go!
Greetings,
Kees.
RevAmountModulat.pch2
 Filename:  RevAmountModulat.pch2
 Filesize:  1.31 KB
 Downloaded:  1250 Time(s)
heid'
PostPosted: Sat May 17, 2008 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much Kees; I have learned something today : how to assign parameter to midi controller with modulation. Great ! Cool
