2Qs: trace module? recording seq triggers?
Page 1 of 1 [5 Posts]
ripe909
PostPosted: Mon May 19, 2008 5:29 am    Post subject: 2Qs: trace module? recording seq triggers? Reply with quote  Mark this post and the followings unread
Hello,
I just jumped on the G2 engine bandwagon ($799 from MF!).
I have two quick questions...
* Is there a trace module within the patch editor? I would like to see what some values are as they change. I have been using an A/D module, but it's not the friendliest way to read a value Wink
* Is there a way to record incoming triggers to a Note Seq? I want the triggers to be recorded at the same time as values from incoming MIDI notes... so far I could only see controlling them manually with a pushbutton.
cheers
ripe
Fozzie
G2 patch files: 49
PostPosted: Mon May 19, 2008 7:47 am    Post subject: Re: 2Qs: trace module? recording seq triggers? Reply with quote  Mark this post and the followings unread
Cool that you got an engine!! Get ready for sleep deprivation, stroopwafels and pure patching bliss Wink
About a trace module; there isn't one (to the regret of many users), however for quick visual reference you can use this hack: feed the signal you want to visualize into a midi CTRL send module (CC value input), set to an unused CC# and the midi channel to "slot A" (assuming you are patching and reading out in slot A; do not use "this slot"). Now insert a Constant module (level group) somewhere in your patch, right-click to assign a midi cc to it and select the same midi CC# as you assigned to the midi ctrl send module.
Works quick 'n dirty, since resolution is low and only works on 0-64 without scaling or other adaptations, but gives a quick visual reference. Quick example attached (didn't try it, but should work).
Other quick reference is putting the signal into a mixer with VU meter, such as the mixer 4-1b. They are slooowwwww however.
visual reference.pch2
 Filename:  visual reference.pch2
 Filesize:  902 Bytes
 Downloaded:  1675 Time(s)
ripe909
PostPosted: Mon May 19, 2008 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tips... I guess I will continue to use the A/D it's not that bad to read the value from, but it doesn't have a history.
Something that graphed an input against time would be awesome, but I can't sacrifice the patch load to do it via controllers.
cheers
ripe
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon May 19, 2008 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is one more hidden trick, you can assign the VU meters of the 4 stereo mixer, or output modules (output 2 and output 4), etc to the g2 panel (right click over the vu level and assign it to a knob), it's a peak hold assignment, not the accurate solution that Fozzie recommended (the best option as far as I know), aaaand can assign to the panel are the output gate indicator of LFO A & B.
I don't know if there are others.
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Tue May 20, 2008 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
If you wanted to see the control data (dial movement/motion) recorded, graph style, over time.
You could use the ctrl send trick and just record the controller data into as DAW, like Ableton/Cubase etc..
Also i don't think the ctrl send modules use very much dsp power.
iP (Ross)
