FM with triangle-core VCOs
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
cbm
PostPosted: Thu May 22, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it's this one:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id33.html
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
ryktnk
PostPosted: Thu May 22, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Yes, it is the Thomas Henry VCO1.
Sorry for the confusion.
-ryktnk
Peake
PostPosted: Thu May 22, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoops.. Thank you for the redirect and for the soundbites. Is there a chance to hear a similar expo patch? Sorry for asking so much, but obviously I'm not going to do a build or two if it's not what I'm after. Thanks!
PostPosted: Thu May 22, 2008 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a connection between tri core / saw core and lin / exp FM?
cbm
PostPosted: Thu May 22, 2008 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not really. Both lin and exp modulation can be implemented in either a saw core or tri core oscillator.
-C
Chris Muir
Peake
PostPosted: Thu May 22, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
If people are using their TH VCO1s, I'm sure not finding many soundbites around the web.
PostPosted: Thu May 22, 2008 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks.
Some posts in this thread seemed to suggest a connection between the phenomena and I didn't quite understand that.
Peake
PostPosted: Thu May 22, 2008 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is, but it's "negative space", not positive. Expo saw FM isn't very interesting. Expo triangle core FM is extremely interesting.
Few seem to be exploring it, however, hence this thread.
PostPosted: Thu May 22, 2008 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
I also discovered that this little VCO was a virtual powerhouse - I told Thomas later I felt like Isao Tomita playing that circuit I had on the breadboard. It's stable, responsive, very accurate and sounds absolutely marvelous - especially through the Mankato filter Thomas designed a few summers back. I was literally bowled over with how well it worked and how *good* it sounded. Perhaps a VCO is just a VCO, but I certainly felt inspired playing this one.
Exactly what I thought when I heard this circuit (Tomita plays Debussy). Very sweet sounding- and 'warm' too.
ACHTUNG!
PostPosted: Thu May 22, 2008 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peake wrote:
There is, but it's "negative space", not positive. Expo saw FM isn't very interesting. Expo triangle core FM is extremely interesting..
Is this an observation you made, or do you have some reasoning ... I just reread you starting message, and I can't think of a "why" and this makes me curious ... I mean, FM on a saw may be a bit wild, but when the saw is converted to a triangle ... hmmm maybe it's not so linear and the order of operations makes a difference?
Peake
PostPosted: Thu May 22, 2008 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Listen to my example and then tell us which oscillators will do that. Plan B aside, which is in the ballpark... I know that I'm nearly alone regarding such concerns, so please bear with me. If I get my answers, I'll go off and work Laughing
PostPosted: Thu May 22, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Personally I'd also like to hear what the TH oscillator sounds like with a spot of linear FM too Very Happy
Scott?
ACHTUNG!
PostPosted: Thu May 22, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did, and I liked it, but I don't know Wink
I'm trying to make some models, but that ain't helping a bit yet ... the tri core emulation runs twice as slow as the saw core, so that's good, but all modulations fail so far, less good Crying or Very sad
frijitz
Audio files: 54
PostPosted: Thu May 22, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, absolutely not. The FM is implemented in the expo/current source and it makes no difference what the core design is. (Very confusing thread, this.)
Ian
Peake
PostPosted: Thu May 22, 2008 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just ignore the tangents and will eventually get the answers.
Peake
PostPosted: Fri May 23, 2008 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Suddenly no interest in exponential triangle-core FM? I'll just go and investigate the options I'd already sourced prior to initially posting. Thanks!
frijitz
Audio files: 54
PostPosted: Fri May 23, 2008 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Again, it's quite difficult to follow your posts. I really like your demo, but without knowing what patches and settings you used it would be quite difficult to try to reproduce your results.
Ian
Peake
PostPosted: Fri May 23, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I've described everything, so don't worry.
Everyone enjoying the rising price of gas and everything dependent upon oil and gas? Laughing
mono-poly
PostPosted: Fri May 23, 2008 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was picking up some stuff today at my technican.
And he said that the biggest problem was to keep the vco in tune at high exp fm input.
PostPosted: Fri May 23, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thinking about it, I would tend to agree more with Ian now. The sample on Scott's site imo, is more representative of the Mankato filter than the oscillator I would imagine. Because at the part where the filter 'opens up', the oscillator, well just sounds like any old oscillator.
It's that filter that sounds so lush Cool
ACHTUNG!
Peake
PostPosted: Fri May 23, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Everyone enjoying the rising price of gas and everything dependent upon oil and gas? Laughing "
I know that I won't get a straight answer to this question either- yet it remains. All bullshit contributes to the overall state. I wonder when people might finally get that, and understand their contribution, to their own situation? I'm willing to wait and see.
usw
PostPosted: Sat May 24, 2008 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
hello,
I'm not sure I understand what this thread really is about, since I don't get this triangle/saw core distinction...
I'm no electronic engineer either, but I've read that only triangle core vco's can go "thru zero" (?)
Assuming this may be the only difference between those two designs (subsequent waveshapers, accuracy/stability issues...let aside), the capability for an oscillator to reverse its phase when given a negative frequency (which is all that "thru zero" means, 0hz "freezes" the oscillator, inducing a dc offset that depends on its current phase and waveform), would obviously apply both to the so-called "exponential" and the linear fm input (even if the resulting spectrum is different).
Question
Is this what you mean peake ? thru-zero exp-fm ?
edit : negative frequencies are of course impossible with exponential frequency modulation, +0 is the limit...
ryktnk
PostPosted: Sat May 24, 2008 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I think Mr Peake is talking about cross-modulation between
two oscillators with expo FM, as in the case of the Buchla 258 which
has two oscillators with expo FM.
[Please correct me if I am misunderstanding]
I have tried this on the Roland System 100m which only
has expo FM, using two oscillators set up in cross-modulation.
Although the Roland oscillators do not have sine wave, so I use
the nearest thing [!] - triangle wave.
The results do indeed become almost white noise at some points,
and also strange rhythmic beating.
Here is a clip of this patch, with just some slow changes of FM depth
and modulation frequency, creating dramatic changes in the sound, although not nearly as musical or subtle as Peake's music !!
PS. 100m oscillators are not tirangle-core, so slightly OT.
-ryktnk
100m_CrossMod_FM.mp3
 Filename:  100m_CrossMod_FM.mp3
 Filesize:  968.16 KB
 Downloaded:  1256 Time(s)
bryan
PostPosted: Wed Jun 25, 2008 12:00 am    Post subject: Re: FM with triangle-core VCOs Reply with quote  Mark this post and the followings unread
Peake wrote:
The Plan B's FM index isn't as deep, but could probably easily be modified.
(sorry I'm a noob..) Would this be as simple as decreasing the resistance on the FM input?
I've done a couple simple mods to the Plan B VCO and something like getting more depth out of the exp. FM definitely floats my boat. It doesn't go far enough.
Nice track(s) Peake, BTW.
