today> Twyndyllyngs Chez Mosc
 Forum index » DIY Hardware and Software » Musical Interfaces
How to build a jammer
Page 1 of 2 [37 Posts]
MusicScienceGuy
PostPosted: Fri Jun 22, 2007 6:23 pm    Post subject: Info on Thummer and jammer
Subject description: A website/blog has started to discuss jammers and the Thummer.
If you are interested in the Thummer(tm) and the whole class of instruments called jammers, see http://musicscienceguy.vox.com/ for info on how jammers work and how to build one. Input is sincerely wanted.
MusicScienceGuy.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Jun 23, 2007 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi MusicScienceGuy
welcome to electro-music.com Very Happy
Thanks for posting the link to your site. very interesting Exclamation
MusicScienceGuy
PostPosted: Wed Jan 16, 2008 6:45 pm    Post subject: DIY Thummer / jammer
Subject description: Here's how to make your own Piano 2.0, a Jammer keyboard.
Hello good people.
I've built a couple of jammers like the Thummer that Jim P. is trying to get financing for. I've put on my blog reasonably detailed instructions on how to make a gig-grade jammer from a M-Audio 88es conventional keyboard. Cost is circa $400 plus 3 fairly solid weekends of work (possibly less). Naturally I'm a proud father and want to show it off and hope someone, somewhere finds it useful Smile .
Ken, MSG
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Feb 11, 2008 1:52 pm    Post subject: Re: DIY Thummer / jammer
now, that's intriguing Exclamation
I don't see anything resembling a 88es in your blog Shocked
MusicScienceGuy
PostPosted: Mon Feb 11, 2008 3:27 pm    Post subject: Re: DIY Thummer / jammer
look here, second page:
http://musicscienceguy.vox.com/library/post/how-to-build-a-jammer.html
Smile
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Feb 11, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
scary Exclamation
MusicScienceGuy
PostPosted: Tue Feb 12, 2008 11:50 am    Post subject: Hacking an conventional keyboard to make a jammer Reply with quote  Mark this post and the followings unread
seraph wrote:
scary Exclamation
The hardest part was cutting up that very nice m-audio keyboard - It's avery nice, solid unit.
However, it's an ideal keyboard to modify, because it it so well made.
ericcoleridge
PostPosted: Tue Feb 12, 2008 2:42 pm    Post subject: Re: Info on Thummer and jammer
MusicScienceGuy.
Hi, I really like the looks and ergonomics of your interface.
But--if you're interested in input--have you considered building/designing one without hacking an expensive commercial midi keyboard. i.e. just using reed switches or some other switch/pressure mechanism wired up to a circuit like this:
http://www.musicfromouterspace.com/analogsynth/SINGLEBUSSKEYBOARD2007/SINGLEBUSSKEYBOARD2007.php
or here:
http://www.cyndustries.com/synapse/synapse.cfm?pc=43&folder=march1977&pic=31
or similar to:
http://www.musicfromouterspace.com/analogsynth/MFOSMINICONTROLLER/MFOSMINICONTROLLER.php
or as described here:
http://www.cyndustries.com/synapse/synapse.cfm?pc=39&folder=jan1979&pic=36
There may be other people here, like me, who would be just as (if not more!) excited about a Control Voltage key/note interface for their analog synths as they would for another type of Midi controller. Or maybe not...
But, I was very intrigued when I saw the picture (shapes! colors!), but honestly, the amount of work and devestation involved was a little off-puting to me. Of course, that's just me. However, it seems like it could(?) be a less demanding (and more accessible) project to create it as an analog controller, from scratch even, with switches or peizios, etc.
will you sell me a kit like that?
MusicScienceGuy
PostPosted: Tue Feb 12, 2008 8:51 pm    Post subject: Re: Info on Thummer and jammer
ericcoleridge wrote:
... But, I was very intrigued when I saw the picture (shapes! colors!), but honestly, the amount of work and devestation involved was a little off-puting to me. Of course, that's just me. However, it seems like it could(?) be a less demanding (and more accessible) project to create it as an analog controller, from scratch even, with switches or peizios, etc.
Hi Eric,
Thanks for the interesting links. I really appreciate them.
In my case, the objective was a little different: I wanted:
1. Something anyone could make, cheaply, in terms of time and money. $300 ($175 on e-bay) for a keyboard is cheap.
Even more important is time: the readers of this forum, I hope, want to quickly get a playable instrument.
2. An expressive keyboard with pianoforte and potential to grow.
Just wait until I add the thumb-controls - then I'll indeed have an expressive instrument - see thummer.com 's demos.
3. A solid instrument that will go a gig, get plugged in and work. It's not a real instrument until you can focus on the music.
A neat example of a home-made concertina for you to try is here.
Note also that my first version was a little lighter - I wear it like a guitar.
Here's a scary picture of me.
jjj
PostPosted: Sat May 31, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I just had another bright idea: How about using ordinary buttons, tailors use for clothing, as key tops? For instance, you could choose the right button; i.e. convex shaped and round-edged, so that one can slight the finger along the keys. Buttons come in all sizes, shapes and colors. Even the sewing holes don't interfere and there exist also buttons without holes. Otherwise it might be even more costly to manufacture a special batch of such buttons.
MusicScienceGuy
PostPosted: Sat May 31, 2008 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant idea. I'll check it out.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat May 31, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
be prepared to discuss this matter with female jammer player regarding color and shape of those buttons Twisted Evil
jjj
PostPosted: Tue Jun 03, 2008 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
...have you considered building/designing one without hacking an expensive commercial midi keyboard...?
I agree with that, but the problem is that most Synths come with two switches per key (the second switch is for touch velocity).
Hence, since the mechanically based Jammer's idea is to avoid electronics, the best mechanical solution, which covers your concerns as well, would be
an adapter (in a light alu frame) put over the top over the zebra piano keyboard to fit any Synth! This frame then can be attached to left & right side of any Synth.
Felt bits glued to the bottom of each adapter key allow for noise-free action.
I cannot imagine a more desirable mechanical solution, can you?
Electronically viewed: Is there a way of activating the two switches via one switch? One way I imagine is via using a delayed switching circuit for the velocity switch. Another way is to use the ready-made touch sensitive keyboard encoder from Pedkov or Sowa and create a separate MIDI port plug-in Kbd; i.e. eliminating the need for a expensive commercial midi keyboard.
jjj
PostPosted: Tue Jun 03, 2008 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
http://musicscienceguy.vox.com/library/post/what-the-heck-is-a-zipex-jammer.html
You look incredibly sexy (dare I say it?) ..."with that enormous musical extension!" Smile
MusicScienceGuy
PostPosted: Tue Jun 03, 2008 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the laugh!
Every morning I get up, and witness a miracle - it's a miracle the glass in my bathroom mirror does not break. Surprised
Ken.
jjj
PostPosted: Tue Jun 03, 2008 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
attach a joystick to the keyboard
Normally, your both hands are busy playing the keyboard. So, there wouldn't be much of a chance to control expression etc. with the left hand.
Yamaha Tyros2 (for example) offers players one finger accompaniment control and thus, they have more opportunities to control/handle other settings.
Live-Styler.de offers the same for only US 51.18
Then you can mount ten more controls on top of the Synth. Smile
MusicScienceGuy
PostPosted: Tue Jun 03, 2008 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
<ahem>
To get back on topic, what do you think of the option to attach a joystick to the keyboard? if mounted on the hand, thumb, foot or mouth, ti would give 2 extra dimensions of expression. They are cheap too, about $7.00 each.
Ken.
jjj
PostPosted: Tue Jun 03, 2008 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your Joystick question is answered above (in this string).
I'm fond of that Tyros 2 Synth, but I would have a problem to benefit from its "super articulation", because it's controlled by key pressure/ velocity.
In that case I would have to settle for a Janko adapter (the same I built on my Roland Synth) or using Yamaha's BC3 breath controller with a plug-in keyboard.
Of course the next one I build will have slightly convex-shaped keys with rounded edges; similar to professional button accordions.
It would be great if they could be made hexagonal to avoid empty spaces, but then again, it doesn't bother button accordion players. Maybe their key-down depth is less than (that of my Synth) 10mm ?
More important is that the bottom of the key tops is almost bellow the key-down level of adjacent keys. I don't think yours are, Ken. That's when your fingers might get hooked underneath adjacent key tops and that's why all the corner sides should be rounded. The thickness of the keys should be about 6 to 7mm. Here's how the keys should be shaped to allow the finger to slide over it:
 Filesize:  18.99 KB
 Viewed:  24171 Time(s)
MusicScienceGuy
PostPosted: Tue Jun 03, 2008 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rounding the keys - good idea
Actually, my keys have rounded edges and rounded corners. It was a true pain to make them so, but would have been more painful yet to have left them square - they'd be pretty sharp to play.
Rounding the keys was very labour intensive. - 130 or so keys, most with 6 sides, and most with 6 corners to round.
The underside was not rounded. I have definitely not found that to be problem.
On a better design and mount for the mod wheels
Mounting a 2 big pitch bend/mod wheels on the end of the keyboard, as is standard design is just plain silly - and marks them as design afterthoughts. Much worse is that it's hard to integrate using the wheels with using the keys. So the wheels are used as gimmicks, gimmicks that one can use only one at a time.
So how about if we replace the mod wheels with one or 2 joysticks, and put them in the center, or even mount them on a glove you can wear? Then you can adjust your pitches and timbre as you play.
What do you think?
Ken.
jjj
PostPosted: Wed Jun 04, 2008 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
how about if we replace the mod wheels with one or 2 joysticks...
As mentioned, the problem is that both hands are busy to create the melody and its accompaniment.
Additional controls used to be done with foot pedal or knee lever.
The advanced idea is to free the left hand by an intelligent, automatic accompaniment, such as Yamaha-Styles or Live-Styler offers, to control additional functions.
Even then, the left hand can only be used intermittently; i.e. it cannot be continuously applied as required for volume and tremolo variations.
Accordions/ bandoneons control volume and tremolo variations perfectly via bellow movements, whereas foot or knee control of the same is inaccurate.
That's why a MIDI breath controller, such as Yamaha's BC3 offers far better control.
As it turns out, we lack a third hand to control the joysticks! Sad
MusicScienceGuy
PostPosted: Wed Jun 04, 2008 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, but as Jim Plamondon points out, we do have thumbs.
Ken.
jjj
PostPosted: Wed Jun 04, 2008 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
But that only works with Wicky... and even there it might be pretty difficult to vary tremolo/ volume (like with accordion) changes and at the same time playing melody or manual bass/chord accompaniment.
That's why I planed to use an old 120-button accordion bass box for manual and automatic (Live-Styler) accompaniment, suspend this box onto springs, (mounted in a frame) so that (similar to bellow movements) I can easily & precisely shake the whole box and so, induce volume/ tremolo variations. This ingenious arrangement even works with BC3 without using breath from my mouth, but rather a self-made Mini air-bellow attached to a lever.
Since your design doesn't offer any of these possibilities, I'm afraid you'll have to go without it! ...Unless of course you come up with an equally ingenious device idea (of which I didn't think yet), which successfully resolves this dilemma.
Think hard and harder, for the success of your project is all yours!
Obviously, for your project the simplest solution is to advice buyers to use apply the BC3 breath controller for effective volume & tremolo variations.
jjj
PostPosted: Wed Jun 04, 2008 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
That how th BC3 breath controller works: move the slider 69% forwards... that you hear the Sax.
http://www.youtube.com/watch?v=qksKsEnsxpU
The BC3 requires a separate MIDI interface box, unless the Synth has an input for it.
Breathalizer:
http://www.synthony.com/vintage/midisolutions.html
Can you please see how much this one cost, because here (in Chile) the price isn't shown They explain that they ship only to US & Canada.
MusicScienceGuy
PostPosted: Wed Jun 04, 2008 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
That link gives me no information - it just dies when I link to it.
Ken.
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Jun 04, 2008 11:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
jjj wrote:
Breathalizer
http://electro-music.com/forum/topic-15357.html
