Page 1 of 1 [7 Posts]
seaweedfactory
PostPosted: Sat Jun 07, 2008 5:54 pm    Post subject:  . Reply with quote  Mark this post and the followings unread
Last edited by seaweedfactory on Sun Jul 06, 2014 7:29 pm; edited 2 times in total
Audio files: 297
PostPosted: Sat Jun 07, 2008 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Moved your message to the new CGS section (in the hope that the question will get better attention there Wink )
andrewF
PostPosted: Sat Jun 07, 2008 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the psu, I did it the way Paia does it for the Fatman and Tubehead pre-amp (although theirs is for 12V).
One output of the transformer is the power rail, the other to ground. Here's a very basic diagram, of course don't forgot all the caps, fuses and whatall.
Really it is worth trying to get your hands on a transformer that puts out 100-180V, a lot simpler. plenty on ebay.
It doesn't need to be big, tubes use very little 'high voltage' current .
The tube heaters are another story - expect 300mA per tube, so for say 10 tubes, you want a 6.3V 3A supply.(edit - crappy pre-coffee maths)
Keep in mind the caps will retain voltage for a long time after the PSU is turned off. originally mine still held 100V an hour after it was unplugged. You need to include bleeder resistors across the caps so they drain more quickly.
Keep one hand in your pocket.
Have a good look at Rene's neon VCO, very easy to build and sounds great...plus its V/Oct.
There are a lot of schematics in yahoo group - tubesynthdiy
that may or may not be useful Smile
 Filesize:  8.42 KB
 Viewed:  10730 Time(s)
otherunicorn
PostPosted: Sun Jun 08, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Basically What I did was to duplicate the positive section of the PSU, but with the diodes and capacitors reversed.
http://www.cgs.synth.net/
seaweedfactory
PostPosted: Sun Jun 08, 2008 9:19 am    Post subject: . Reply with quote  Mark this post and the followings unread
otherunicorn
PostPosted: Wed Jun 11, 2008 1:18 am    Post subject: Re: Something like this? Reply with quote  Mark this post and the followings unread
charles.brodeur wrote:
Otherunicorn, some thing like this? Or will I need another transformer?
The one transformer is all you need. Yes, this is the way to go about it. Note that I have NOT thoroughly checked your diagram.
otherunicorn
PostPosted: Wed Jun 11, 2008 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally found my dual PSU diagram.
use at own risk!
dual psu for tube circuits.
 Filesize:  31.59 KB
 Viewed:  548 Time(s)
