RSS Feeds
Page 1 of 2 [27 Posts]
BobTheDog
PostPosted: Sun Jun 08, 2008 12:25 pm    Post subject: RSS Feeds Reply with quote  Mark this post and the followings unread
Is there a way of getting the RSS feed to feed the last posted message rather than the first one in the thread?
Andy
cbm
PostPosted: Sun Jun 08, 2008 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
As long as were making RSS feed feature requests, a thing that I've always wanted in the RSS feeds is which sub-forum it's from.
-C
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
Audio files: 297
PostPosted: Sun Jun 08, 2008 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
What Howard wrote here suggest that the last topics are returned ... but erm .. I can't say anything sensible about the subject unfortunately.
BobTheDog
PostPosted: Sun Jun 08, 2008 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan,
I get the Thread title and an UPDATED date and the contents are always the first post in the thread.
Andy
Audio files: 297
PostPosted: Sun Jun 08, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks, looks not good then ... something for Howard to look into.
Audio files: 225
PostPosted: Tue Jun 10, 2008 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I just noticed this thread. Been busy here and haven't been able to keep up as much as I'd like.
I will look into hacking the rss.php code to do these things. Thanks for the feedback
Audio files: 225
PostPosted: Tue Jun 10, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made an adjustment to the rss feed program to jump to the last post instead of the first. It wasn't too hard to do, but since I didn't write the program in the first place, I'm not sure I didn't mess up anything in the process.
Please, rss users, give this a try.
http://electro-music.com/forum/rssx.php
Once I hear that it's ok, I'll replace the existing rss.php with this one.
Thanks...
cbm
PostPosted: Tue Jun 10, 2008 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
This doesn't fetch anything for me.
NetNewsWire 3.1.6
OS X 10.5.3
-C
Chris Muir
Audio files: 225
PostPosted: Wed Jun 11, 2008 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Chris. Doesn't work on my iPHone either. I can use that to test it. After I figure this out, I'll post an update to this topic. Andy, any luck with your reader. It seems to work fine here with the Mozilla reader.
As for the request to include the sub forum, I'll try to figure a way to do that, but if the reader doesn't print the fields, there isn't much I can do. Maybe the forum trail (Discussion >> Schmooze) could be put in the front of the text.
Any suggestions?
Audio files: 225
PostPosted: Wed Jun 11, 2008 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, seems that I've made a change to rssx.php that enables the iPhone to read the feed.
Chris, and others, please try again.
Audio files: 225
PostPosted: Wed Jun 11, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
This was a bit of a pain to test because the feeds are cached to prevent too much load on the server. So having a test version and a production version is a bit confusing since they write to the same cache.
Anyhow, I tested this with Firefox, Safari, and the iPhone. Seems to work so I replaced the standard rss.php
If anyone finds any problems, please let me know.
cbm
PostPosted: Wed Jun 11, 2008 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Mosc, it works for me, now.
As far as leaving "bread crumbs" for which forum a post came from, what do you mean when you say "if the reader doesn't print the fields"? Are you suggesting that they are already being sent, and that my RSS reader isn't showing them? If so, I'll try and figure out what I need to do with my RSS reader. If I misunderstood you, sorry for the noise.
-C
Chris Muir
Audio files: 225
PostPosted: Wed Jun 11, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, the feeds are coded in xml, each topic is one item. The rss reader reads the fields in the item and displays them as it chooses. Item's fields are:
title
link
description
author
publication date
If there was another field for like forum bread crumbs, no rss feeder would display it, so I'd have ot add it to the title or description.
At one time, I had the bread crumbs in front of the title, but people complained. Not sure why, but I don't use rss feeds myself, but I'm thinking I might start soon. Anyway, I hope this helps.
BobTheDog
PostPosted: Wed Jun 11, 2008 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Howard,
Sorry only just seen your posts.
I have added the rss feed you posted above into Safari and nothing has come through yet, its bed time now so I will check in the morning to see if the postman has been.
Thanks for looking into it.
Andy
Audio files: 225
PostPosted: Wed Jun 11, 2008 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't use the rssx link, use one of the links on the site's pages. I have it working on Safari here. Maybe you might have to clear your browser cache. Let me know how it goes.
BobTheDog
PostPosted: Thu Jun 12, 2008 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Howard,
It is working perfectly now, thanks for your help.
Andy
Johan Zwart
Audio files: 19
PostPosted: Fri Jun 13, 2008 12:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Works fine Howard.
At first I gat some errors this morning, but that must have being a glitch at the server.
phpBB : Critical Error
Error creating new session
Error clearing sessions table
Error doing DB query userdata row fetch
www.jzwart.eu; https://soundcloud.com/johan-zwart; https://www.facebook.com/JohanZwart.artistpage
Audio files: 297
PostPosted: Fri Jun 13, 2008 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the session table was hosed this morning - after another server outage Twisted Evil
Johan Zwart
Audio files: 19
PostPosted: Mon Jun 23, 2008 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Howard.
Maybe it is a bug in the latest Opera update (9.5), but now I do not see the feeds as discussions anymore but as individual messages.
It can be a bug because the spellcheck is not working to. But is dus in IE.
Audio files: 225
PostPosted: Mon Jun 23, 2008 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure I understand what you mean. Do the feeds work differently in IE and Opera? I did modify the feed program recently to point to the last post in the topic. This is what Bob The Dog requested. I find it more useful that way myself. You can scroll up if you want to catch earlier posts in the topic. If you think that isn't as useful, I can always hack the code to have an option to do it the original way.
Maybe I'll download the latest version of Opera and give it a try.
Thanks for the feedback.
Johan Zwart
Audio files: 19
PostPosted: Mon Jun 23, 2008 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what I mean.
 Filesize:  79.1 KB
 Viewed:  11025 Time(s)
 Filesize:  70.35 KB
 Viewed:  207 Time(s)
 Filesize:  30.39 KB
 Viewed:  209 Time(s)
Johan Zwart
Audio files: 19
PostPosted: Mon Jun 23, 2008 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
In RSS1 you see individual messages
and in 2 and 2a can see them as discussions.
2 is "better than myspace" an expanded thread/discussion
2a is "better than myspace"not expanded
The latter takes les space.
The feed pointing to the last post in the topic works fine for me too.
Johan Zwart
Audio files: 19
PostPosted: Wed Jun 25, 2008 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tryed the feeds in Widows Live Mail and there it works the showing as discussion. So it is a bug in the new Opera 9.5.
 Filesize:  8.05 KB
 Viewed:  10990 Time(s)
Audio files: 225
PostPosted: Thu Jun 26, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for taking the time to give us an update. Good to hear. That looks like a very nice rss reader nevertheless.
Johan Zwart
Audio files: 19
PostPosted: Sun Jul 06, 2008 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome.
Windows Live Mail is even better than the Opera reader.
It can show the webpage underneath the message line.
What brings me to my point.
If I look at a message from the "Dutch Synthforum" it shows the message on the web page, (that way you can brows the messages in the reader) but not so at electro-music.com.
Oke, it is not a must, but it would be nice if it did.
Another neat thing of WLM is that when you click on show online (online weergeven). It takes you not to the first or last message, but directly to the particular message/reply in the thread. Cool huh? Cool
 Filesize:  106.57 KB
 Viewed:  212 Time(s)
 Filesize:  156.05 KB
 Viewed:  212 Time(s)
