How do you ramp a gain?
Page 1 of 1 [9 Posts]
Acoustic Interloper
Audio files: 89
PostPosted: Sat Jun 14, 2008 9:16 am    Post subject: How do you ramp a gain?
Subject description: Going from current to desired gain in 100 ms . . .
I am attaching my first attempt at modifying a ChucK program, and I have hit a snag. (Thanks to Inventor for drafting an initial version, which I have now messed up!) The program is attached, but maybe you don't have to read it.
There is a Python program sending lists of
bank(i), oscillatorNumber(i), freq(f), phase(f), leftampl(f), rightampl(f)
to ChucK via OSC. I want to use the left and right amplitude numbers 0.0 .. 1.0 to set gain, but I want to ramp it so gain doesn't change immediately, but rather ramps in 100 msec. I am trying to port a patch from MSP.
I am using an Envelope to ramp the changes in gain, and the Envelope .target is being set corretcty, but the .value() never goes anywhere but 0. Any suggestions?
Thanks.
chesstones.ck
 Filename:  chesstones.ck
 Filesize:  10.03 KB
 Downloaded:  328 Time(s)
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Frostburn
Audio files: 9
PostPosted: Sat Jun 14, 2008 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you just forgot to chuck your Envelopes to a blackhole.
Everything in ChucK needs to be sample sucked to work.
To boldly go where no man has bothered to go before.
Acoustic Interloper
Audio files: 89
PostPosted: Sat Jun 14, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That helped, thanks!
Inventor
Audio files: 267
PostPosted: Sat Jun 14, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tell you what, AI, one little trick I like to use in my programs is a "running average". Maybe someone else like Frostburn knows the real name for it, but what you do is this:
You have a running average value A that you would like to gradually approach some new value B. You make a varible tau which is a float and usually has a value of 0.99 or 0.995, something like that. Then you do this:
Code:
tau * A + (1.0 - tau) * B => A;
A will exponentially approach the value of B over time.
In your case for a smoothly varying amplitude normalizer, I'd just make a Gain element and a shred spinning on say 10::ms that changes the gain from A to B all the time.
And it's OK if B suddenly changes course at any time, it will just start up a new exponential approach.
Hope that helps. Now on to the rest of my Budweiser!
Kassen
PostPosted: Sat Jun 14, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
A Sttep followed by a LPF set to something really low will get you the same kind of thing, without the shred, as this can be chucked straight into a Gain set to multiply.
Cheers.
Kassen
Inventor
Audio files: 267
PostPosted: Sat Jun 14, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers.
Oh, man, I like my tau thingie! But you're right, that would be better.
Kassen
PostPosted: Sun Jun 15, 2008 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, but your "tau thingie" is a simple LPF as well, I think it's a OnePole. I think that if you use the OnePole with the .pole() function for setting the coefficients you end up with exactly what you have now, except at sample-rate and optimised in C++.
Kassen
Frostburn
Audio files: 9
PostPosted: Sun Jun 15, 2008 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Inventor wrote:
Maybe someone else like Frostburn knows the real name for it...
That tau thingie is called leaky integrator. I like to use two in a row to get smooth results even with sudden changes in the input.
A running average is a filter that takes the average over a finite number of samples and moves the window as it goes.
Code:
input => OnePole average => blackhole;
input => Delay averageDelay => average;
1.0 => amplitude.b0;
-1.0 => amplitude.a1;
10::ms => dur averageDur => averageDelay.max => averageDelay.delay;
-1.0 => averageDelay.gain;
samp/averageDelay.delay() => average.gain; //normalize
That patch adds the input samples to an accumulator and subtracts them off after some time has passed.
Inventor
Audio files: 267
PostPosted: Sun Jun 15, 2008 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys, you be edgeukatin' me brain again!
