loss1234
ericcoleridge
Posted: Wed Jun 11, 2008 3:13 pm Post subject:
Loss,
This reminds me of something I was hoping to get people talking about in the Ken Stone/CGS forum.
I had been looking at Buchla Source of Uncertainty schematics (there is a model 265, 266, and now 266e), parts of which use shift registers, feedback, EXOR gates, etc. to provide various 'random' cvs. One thing that I really like about the Buchla circuits however, that may be exclusive to buchla, is that they give some control over the randomness of their outputs. They provide some selection over various voltage ranges, and time ranges.
Theres some description in the first link, and more schems in the second (also Doepher and Buchla both currently offer versions of the SOU, with good descriptions on the respective sites):
http://www.simple-answer.com/DIY.html
and
http://www.musicsynthesizer.com/Buchla/source_of_uncertainty.htm
Anyways, there are also a few Ken Stone designs, that aren't necessarily described as such, but may be similar to these buchla circuits, and other shift register based 'random' voltage circuits:
Infinite Melody, Gated Comparator, and Digital Noise
You may be interested in taking a look at some of this stuff, if you haven't already. It's been peeking my interest lately.
I hope this reply isn't too off topic/forum. I apologize if so. Last edited by ericcoleridge on Thu Jun 12, 2008 8:10 am; edited 1 time in total |
loss1234
Posted: Wed Jun 11, 2008 4:47 pm Post subject:
you know i have also been looking into these things. ITS JUST THE BUCHLA SCHEMATICS TERRIFY ME!!
i wish they were more modern looking, easier to read.
and btw, the lunetta area just feels right for some of these topics. non-traditional synth circuits that use lots of logic?? or am i wrong.
thanks for the links
id love to flesh this out some more maybe tomorrow
you know we STILL Need to hang out..we live close by! _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
ericcoleridge
Posted: Thu Jun 12, 2008 8:07 am Post subject:
loss1234 wrote: | you know i have also been looking into these things. ITS JUST THE BUCHLA SCHEMATICS TERRIFY ME!!
Absolutely. But, Marc Verbos, on his DIY website, cleans a few of these particular schems up and seperates them into less complicated parts. Once I looked at his schem versions, I was able to see what what happening a bit more.
Of course, it's still very confusing though. For one, because Buchla seemed to recycle names of modules, while changing circuitry. So it's sometimes difficult to know exactly which "stored random voltage" you're looking at.
I have also been building a lot of Ken Stone stuff, who also uses a lot of CMOS stuff in many of his circuits, and I start seeing some parallels.
They use the same shift registers and exor gates and other chips, in similar arrangements. What interests me, is trying to get to the Buchla circuits, maybe starting from the Ken stone pcbs. Or perhaps ending at an acceptable somewhere else. |
loss1234
ericcoleridge
Posted: Sat Jun 14, 2008 6:06 pm Post subject:
The ones I linked to above are the ones I was talking about
The CGS Infinite Melody is already kinda close to the "Stored Random Voltage" section of the Buchla 266. Both use a series of shift registers (4015), with a feedback scheme going through an EXOR gate (4030). They both take a clock input and a CV input. What is generated, in both circuits, is a bunch of random numbers, or random voltage levels on each of a dozen or so register locations. These voltages are summed and sent to outputs.
One output is a purely random voltage, the other, more interesting output is random, but where the 'distribution' or range of voltage steps is, quoting Ken Stone, "inversely related to the frequency at which it will occur". It's 1 over F. The greater the pitch step, the less likely it is to occur.
In the CGS circuit, at least, this is done with a 4024 frequency divider, dividing down the clock rate of the shift registers. The shift register receiving the slowest frequency division, from a 4024 output, outputs the largest pitch steps, but less frequently. Each individual register output is limited by resistors, so, I think, the shift register chip clocked at the slowest rate has the smallest resistors, and therefore is allowed to output the largest voltages.
Anyways, in the Buchla 'Stored Random Voltage' section, there is also VC over this 'distribution'. On the CGS, I think there's just the two outputs without control over distribution.
Now, the other section of the Buchla 266, called "Quantized Random Voltage" is also done with a shift register (again, 4015s), and EXOR feedback. Again, the random voltages coming from each register location, are limited by certain resistor values, and then summed. One output, using resistors of equal value, gives a random, but equal distribution of "quantized" notes (sent to a VCO). The other output, the resistors again limit the output voltages to specific "quantized" levels, creating 64 possible voltage steps. You can then control the range of randomness by limiting the number of possible steps. This is done with another EXOR gate, and an input voltage.
The CGS module that could possibly be adapted to the Quantized Random Voltage circuit is the CGS Gated Comparator. On the CGS circuit, the shift register positions can be summed, but call for different resistor values before summing. Then it would be a matter of gating the output again. Or maybe not. There's probably more to it, but it seems like these circuits are pretty close to the Buchla circuits.
[/b] |
Scott Stites
Audio files: 96
Posted: Sat Jun 14, 2008 9:02 pm Post subject:
Actually the 266 SOU Quantized Random Voltage uses the CD4006, though CD4015s could be adapted for use by it.
Jeff Pontius and I went on a 266 SOU kick back in 2004. I breadboarded all of the circuits from it - what a power packed module. My two favorite functions from it were the Fluctuating Random Voltage and that funky, funky sample and hold. All of the functions were pretty cool though. Jeff actually built a module based off of it. I got sidetracked on the Quantized Random Voltage (the project turned into the first Klee sequencer, which is based off of it and Ken's Gated Comparator).
There's another very very, very spiffy 4015/3900 based random voltage function on the 208/Music Easel - I'm not sure if it's actually called it (it may be), but I refer to it as the "Uncorrelated Random Voltage" function - four outputs, each generating a different random voltage with each incoming clock pulse. Very cool, and very easy to build, once it's isolated from the 208 module.
Cheerios,
loss1234
Scott Stites
Audio files: 96
Scott Stites
Audio files: 96
Posted: Sun Jun 15, 2008 9:27 am Post subject:
Probably not the right thread, let alone forum, but WTH. Here's my redraw of the absolute coolest S&H I've ever worked with - the one from the 266 SOU. Now, as with all Buchla CVs, it only handles positive voltages, but, my my - how it handles them!
It takes a single sample input, and outputs each sample out on the CV output (like a "normal" sample and hold). It has two additional CV outputs that alternate between samples - sample 1 goes out CV1, sample 2 goes out CV2, sample 3 goes out CV1, sample 4 goes out CV2, and so on. Plus, it provides alternating pulse outputs for these two CVs. I can't begin to describe the bug (and non-bug) music I've made just using this bad boy as a controller.
One of my favorite circuits of all time......
Cheerios,
Scott
Description: |
Redrawn Buchla 266 SOU S&H Function |
Filesize: |
43.27 KB |
Viewed: |
1191 Time(s) |
Scott Stites
Audio files: 96
Posted: Sun Jun 15, 2008 10:28 am Post subject:
My redraws of the Quantized Random Voltage and Stored Random Voltage functions from the SOU. I noticed on my redraw of the SRV, the reset pins of the CD4015s were left floating (pins not shown on the original Buchla schematic). Pretty sure they should be grounded, so I grounded them.
I redrew the schematics in an attempt to better understand them and breadboard from them. The functions are so complex (at least to me) I'm not sure a redraw makes anything any more clear. They are masterworks of randomness with the tools at hand at the time, IMHO. They really make one think.
I've got the fluctating random voltage and voltage controlled integrator around somewhere, I believe. In the case of the fluctuating random voltage, I did modify the circuit to eliminate the hard-to-find MM device used for digital noise. I also added droopy S&H outputs to the FRV. Mebbe someday I'll dig them up.
Cheerios,
Scott
Description: |
Redrawn Quantized Random Voltage from Buchla 266 SOU |
Filesize: |
72.24 KB |
Viewed: |
997 Time(s) |
Description: |
Redrawn Stored Random Voltage function from the Buchla 266 SOU |
Filesize: |
66.47 KB |
Viewed: |
994 Time(s) |
loss1234
CJ Miller
Posted: Sun Jun 15, 2008 7:30 pm Post subject:
I can entirely relate to being overwhelmed by Buchla's schematics, and ideas. I can hardly understand more pedestrian electronics, nevermind this...
I am on a big "stepped and smooth" kick right now, making my first Lunetta and also starting a portable synth. This is just the sort of stuff I was just dreaming about. I haven't even begun to try looking at the Easel schematics yet. Did you ever see the giant day-glo poster they did of the "Easel Weasel"?
I'm off to try getting some actual work/play done. Thank you so much for your redraws and ideas, Scott! |
loss1234
loss1234
loss1234
Scott Stites
Audio files: 96
Posted: Sun Jun 15, 2008 9:03 pm Post subject:
"Random Pulse In" is just a label - the pulse itself need not be random - it's literally "pulse to generate the next random voltage".
Good question on the levels though - the Buchla idea of pulse levels and the Moog or Electronotes idea are quite divergent. You'll want to have pulses well in excess of 10V - I'm thinking at least 12V(?) to get some of these circuits to do their thang, unless you modify.
I've found my redraws of the Fluctuating Random Voltage function, but they're not in any shape for posting right now - they were a series of exchanges I had back and forth with Jeff when he was building his SOU adaptation. As I mentioned before, I modified a what now appears to me to be crude (but quite functional) replacement of the MM noise device used. I used transistor noise into a comparator to emulate the digital levels of the circuit. It looks goofy now, but the results were quite good. There are several add-ons I did at the time (S&H and trigger outputs for it) that I would be loathe to do now. I guess I've moved past "guilding the lily" . Still, the additions did work out quite well for me. I'll try to see if I can organize them before next week (I'll be out of country between June 23 and July 25).
Back to the RFV - what a cool, cool function. I think the Woggle is something like it. In the 266, it uses noise to frequency modulate a slow triangle wave (IIRC, the 265 used a sawtooth and transistor noise??). Anyway, the signal is applied as the input to a simple sample and hold circuit within the RFV function. The really cool thing is what Mr. Buchla did with the sample and hold output - he slewed it, but he devised the time constant of the slew to be directly tied to the time constant of the clock.
With a "normal" sample and hold lagged output, the time constant is fixed. So, if you set it for a high slew rate, the range of voltages it will cover are reduced by the frequency of the clock, more or less. In other words, if you were sampling the same signal with a high slew rate at a low sample rate, the slew would allow enough time for the output to rise to highest and lowest voltages. As the clock signal is increased, the voltage range becomes constricted - there isn't enough time to, say, go from a high sampled voltage to a subsequently low sampled voltage before the next sample comes through. At a low slew rate with a slow clock, the sample will "jump" from sample to sample - not abruptly, but not smoothly, either. It will linger at one level then "zoom" quickly to the next sampled level. The idea is that you want the slow rate (low probability of change) to be just as smooth in its rate of change as the fast rate (high probability of change), and vice-versa.
The FRV, however adjusts the slew rate along with the sample rate - these two parameters are what the "Probablity of Change" control effects. At low sample rates, the slew is set for a longer time constant - it will slowly glide from one sample to the next. At a high clock frequency, the slew rate is set for a shorter time constant, and proportionately glides quickly from one level to the next. The upshot is that the output is both smooth and non-restricted in the range it will fluctuate. It's a marvelous function.
Cheerios,
ericcoleridge
Posted: Sun Jun 15, 2008 10:21 pm Post subject:
Scott Stites wrote: | My two favorite functions from it were the Fluctuating Random Voltage and that funky, funky sample and hold. All of the functions were pretty cool though. |
I've been trying to base my DIY synth off a lot of Buchla stuff, in as much as I'm able to. So, I've got some CGS VCOs with wave-shaping, low pass gates, band pass filters, quad function gens, etc. Mostly stuff I've found here in these forums. But there are still a few other things I'd really like to reproduce, functionally at least... The SOU for one, and eventually, I'd love to do a Touch Plate Interface.
I've done a Wogglebug, which I'm really happy with, and feel like it's probably pretty close to the Fluctuating Random Voltage on the SOU--just comparing the schematics, seems to be doing a similar thing-- random changing voltage with correlation control.
But I don't have the skills to veroboard the other circuits on the SOU, so it occured to me that maybe I could appropriate and modify something close, like some of the CGS circuits.
Thanks a lot for posting your schematic re-draws, I'll print them out and study them on my lunch breaks this week. |
ericcoleridge
Posted: Sun Jun 15, 2008 10:49 pm Post subject:
Scott Stites wrote: | My redraws of the Quantized Random Voltage and Stored Random Voltage functions from the SOU...
I redrew the schematics in an attempt to better understand them and breadboard from them. The functions are so complex (at least to me) I'm not sure a redraw makes anything any more clear... |
Scott,
I was wondering, on the QRV, is the output actually 'quantized' in terms of voltages that will give specific semitones, or is it 'quantized' in a more general sense--like just voltage restricted to a specific range? |
yusynth
Posted: Mon Jun 16, 2008 4:08 am Post subject:
Hi Scott
Thanks for sharing your redrawing of these Buchla modules, it saves us a lot of headaches indeed.
This is very much appreciated.
Yves _________________ Yves |
loss1234
funkyfarm
Posted: Wed Aug 27, 2008 12:30 am Post subject:
Subject description: 266 integrator |
Scott Stites wrote: | Probably not the right thread, let alone forum |
What is the "integrator" at the top of B 266 ?
ff
Quote: | Buchla 266 - Source of Uncertainty
B2660-1 Quantized Random Voltage
B2660-2 Stored Random Voltage
B2660-3 Fluctuating Random Voltages
B2660-4 Integrator and Sample&Hold |
yusynth
Posted: Wed Aug 27, 2008 12:37 am Post subject:
funkyfarm wrote: |
Kind of a slew limiter I bet... _________________ Yves |
funkyfarm
Posted: Wed Aug 27, 2008 1:43 am Post subject:
oh yes, for sure.
thank you. (what a module !)
as my old Mac, i ran out of memory  |
