today> Sorry, no show today/tonight Chez Mosc
CV Quantizer PCB Layouts
Page 3 of 7 [166 Posts]
loss1234
PostPosted: Wed Jun 04, 2008 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
i got mine for 12 from digikey
etaoin
PostPosted: Wed Jun 04, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Digikey price is not the issue, their shipping to Europe is.
http://www.casia.org/modular/
fluxmonkey
PostPosted: Wed Jun 04, 2008 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
guitarfool wrote:
ericcoleridge wrote:
However, I've recently discovered an option that I didn't previously know of. There is a quantizer built into the Blacet "Improbability Drive" module. The kit is $150 (which is still high, but much better that buying a doepfer quantizer for $250, and then putting it behind a new panel).
The quantizer on the Blacet has a switch for chromatic, major, minor and diminished. Plus the rest of the Improbability Drive looks pretty cool and useful. Similar to the Wogglebug or Buchla Source of Uncertainty. I'm leaning in this direction.
I have one. It works pretty good, but the scale is selected by a trimmer on the board. I plan on having this done from the panel.
He used a PIC, DAC0800 and a couple of op amps for it - pretty simple actually. You could petition John Blacet to produce a board with just his quantizer on it. Or at least the programmed PIC with a schematic. If there was enough interest, he might do it. Very Happy
i asked john about this when the Imp drive first came out... he said the resolution of the PIC as implemented was pretty low, not good enuf for a stand-alone quantizer. I did bring the scale selector pot to the front panel, tho... and I've seen other folks have modded theirs to accept an external signal into the quantizer.
I have 2 Miniwaves, both with ScaleQuantizer chips in the B ROM socket. Works great.
bbob
BananaPlug
PostPosted: Wed Jun 04, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a link to my post about the ID2510, including that mod. It really is a very nice module for a whole host of reasons. Perhaps not the ultimate in quantizer.
http://electro-music.com/forum/topic-25179.html
etaoin
PostPosted: Thu Jun 19, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been wondering; what is so special about the AD7245A that it can't be replaced? We are only using 7 of the 12 bits, we are not using the double buffer. One would say that any flash D/A with more than 7 bits would do.
zthee
PostPosted: Fri Jun 20, 2008 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I second that thought! Why does it have to be a AD7245?
I'm in "desperate" need of a quantizer. Even thought about learning to program AVR just to get one..
Clack
PostPosted: Fri Jun 20, 2008 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry about the layout thing - I still have it but I dont have a electronics space to work in at the moment wich has made me loose my enthusiasm for cad stuff - I also question the DAC but it has just been well tested and tweaked by scott sites - to do it properly somone should get into it and work it out with a cheaper IC - maybe a discrete one may be more universal!
i.e along the lines of - http://www.ucapps.de/mbhp_aout_lc.html
Im planning this summer to really get my head technically in gear ( I spend way to much time just copying schematics without understanding them ) and this may be one of the projects
Clacktronics.co.uk
etaoin
PostPosted: Fri Jun 20, 2008 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
One advantage of the AD7245A is of course that it generates it's own reference voltage. But that's nothing a seperate reference won't handle.
By the way, does someone know why Scott uses two 4516's instead of just a single 4024 or even a 4040?
Clack
PostPosted: Fri Jun 20, 2008 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I beleive he seperated parts of the schematic to go through different chips due to bleedthrough but im not sure if that applies to the cmos
Clacktronics.co.uk
bearblock
PostPosted: Fri Jun 20, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i did!: http://www.electro-music.com/forum/topic-26667.html
i found the a/d a bit glitchy though. maybe on a proper pcb with a ground plane it would be ok, but alls i have is stripboard....
funkyfarm
PostPosted: Sat Jul 19, 2008 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
looking at pin4 of DAC AD7245A highlights analog ground, represented by a white triangle and a capitol A next to it.
They are several points like this on scott stites' schematic.
I'm sure they have to be connected altogether, i guess the shortest/most meticulous to be required...
but I wonder about linking this analog network to main ground. the trick is to have only one common point between ground (zero/voltage reference) and analog ground ?
this is the way to avoid interference here ?
ff
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id15.html
 Filesize:  99.57 KB
 Viewed:  298 Time(s)
etaoin
PostPosted: Sat Jul 19, 2008 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, you need a single point where analog and digital ground come together and that point usually needs to be as close to the power supply as possible. So if you're building a module, the power connector would probably be the best point.
funkyfarm
PostPosted: Sat Jul 19, 2008 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thank for that prompt and clear explanation.
Farnell has 28 AD in stock...
edit : ooopps, now, only 26 left.
widdly
PostPosted: Sun Jul 20, 2008 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would have thought you could use a DAC08 instead. They are really cheap in my part of the world.
okvern
PostPosted: Sun Jul 20, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
widdly wrote: "I would have thought you could use a DAC08 instead. They are really cheap in my part of the world."
Agreed!
Actually, an R2/R ladder DAC works pretty well, too (at least as well as a DAC08/DAC0808 in my tests). For a *quantizer*, what I want are notes--not all of the voltages in between. So what I do is use the upper 6 bits of an 8-Bit DAC and 0-63 note values over a 5.229 volt range, adjusting the output amplifier for .083v per note. If I need to expand the range, I can go to 7 bits and 0-127 note values.
If I need better speed, I can use an AD558 or similar, again limiting the input to 6 bits. This is the approach used in the Pro-One--an early microcontroller synth design that is well worth studying. (That said, this DAC is a little more expensive than I like, at $10-12.)
The point is: for quantization, you do not need the accuracy of a 10, 12, or even 16 bit DAC. If you *do not care* about the voltage values in between--which is why you're building a quantizer in the first place--then why not create a DAC where every value in equals a note out in 1v/octave scaling?
If you attach this DAC to a microcontroller--my experiments have been with an Arduino, but just about any will work--you can limit the quantization to specific scales or modes, as well.
If what you need is continuous controller voltages--then, yes, higher resolution DACs are better. But I think we sometimes get hung up on the notion that more bits in a DAC will give us better accuracy, and end up spending *way* more than we need.
Thanks,
Ole
Rykhaard
PostPosted: Sun Jul 20, 2008 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
My current desires (with NO DAC experience period) are to have a sequencer where each step is controlled by a set of ON/OFF switches, acting literally, as BITS. Smile
Now - I DID verify a set of resistors to 1% for myself, to build an R-2R 'DAC' for 4 switches. With only 1 resistor (or pair of) being very close to 1% edge, did I have a slight tuning problem. Otherwise, the other 3 switches in the set of 4, did give me proper 1V/oct notes. Smile
Now my question is - whether to setup to 6 switches per step, for an 8 step sequencer, going with a DAC chip (using the 6 upper bits as you'd stated) or bring home a high resolution HP tester from work, to match myself 1% resistors to 0.1%.
Any thoughts on this? My only desires, are for the standard 1V/oct. notes, for the sequencer. All other aspects (pitch bend / etc.) are taken care of externally.
Thanks for any thoughts on this. Smile
BTW - if I'm going with a chip - what else do I have to worry about with using it? An external clock, if I'm not mistaken - anything else?
widdly
PostPosted: Mon Jul 21, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rykhaard,
You might want to check out Ken Stone's Diatonic Converter. It looks almost exactly like what you want.
It has 6 digital inputs, 3 bits for octave and 3 bits for notes. It outputs a v/oct signal.
here...
http://www.cgs.synth.net/modules/cgs41_diatonic_converter.html
Rykhaard
PostPosted: Mon Jul 21, 2008 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
widdly wrote:
Rykhaard,
here...
OMFG!!! Why the heck didn't _I_ think of that????? Embarassed Embarassed Thankee greatly for including the link, Widdly! I just went off and read the whole thing and sent a confirmation question about my idea and the Diatonic to Ken. I don't see a problem with it, but wish to read 'yes' from Ken before I order 1 or 2 of them.
THAT module could take care of all of my design troubles that I've had over the last couple of years! Very Happy
widdly
PostPosted: Mon Jul 21, 2008 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ken's site is like that. You think of some idea you think is cool and new. Then you check cat girl and Ken's built it already and made it more betterer.
Laughing
Rykhaard
PostPosted: Mon Jul 21, 2008 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Definitely! Ken was the first chap that I started buying from in late 2005 or early 2006. Smile I now only build basically, what I come up with myself, or a modified version of someone else's or something very simple. Otherwise, I'm now buying from Ken and Ray Wilson and happy as heck. Smile
Wondering whether to start expanding from my 4 channel MIDI to CV limitation of my Roland MPU-101. I'm going to need more channels eventually.
funkyfarm
PostPosted: Thu Aug 07, 2008 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Only minor error I've found in scott schems : with TL074, +input is pin 12, not pin 13... (see page 3of3, IC U11D, quantizer channel #4) Smile
philpeery
PostPosted: Sat Aug 09, 2008 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been looking at Scott's quantizer design since I am in need of a couple of quantizers, and don't want to go the whole miniwave or quantix route at this point. I really just need a couple of standalone quantizers to keep things simple. I've got too many irons in the fire right now with my modular so I don't want to go totally crazy here. As a side note, I am also working on a CNC panel engraving machine (wink, wink Wink ).
So my quesiton is, has anyone built Scott's design, on breadboard, stripboard, or pcb? I'd be curious about anyone's experiences with the circuit (since he designed it, I'd like to hear from Scott's too!). I see that the AD chip is available from digikey, and the other parts are already in my parts bin! It looked like there was some PCB design work going on from Mr Clack, has anyone else gotten anywhere with this other than him? If not, I might take a swing at a single sided PCB later in the summer.
Thanks for any input!
Phil
ALH84001
PostPosted: Tue Aug 12, 2008 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just scanning quickly thru this thread, I'd like to suggest the Texas Instruments TLC7524 8-bit multiplying DAC, about $4.50 from Mouser. I find them convenient to use.
If you're not using all 12 bits of the AD7245, you can save some $$.
Coriolis
PostPosted: Wed Aug 13, 2008 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
...which futurlec has for 1.90$... Cool
C
etaoin
PostPosted: Wed Aug 13, 2008 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Biggest difference seems to be that the 7524 doesn't provide it's own reference voltage, so it will require some extra circuitry if used in Scott's design.
