Posted: Sat Jul 05, 2008 9:03 am Post subject:
Audio clipping/ distortion removal software? Subject description: Any good ones out there? |
| I've got a rather lengthy track that has a bit of clipping on it (digital I'm afraid). Does anyone know of any good software that can take the clipping out (or at least help to remove it). I used to use Steinberg's noise and click removal VST plug in, and this was excellent for cleaning up stuff, but that was 10 years back. Can anyone recommend anything else? |
DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Sat Jul 05, 2008 11:48 am Post subject:
You may want to have a look at SeeDeClip by CuteStudio Ltd.. I've not tried it, but it was recommended by several people who ought to know. Cheap as chips too.
DJ
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Sat Jul 05, 2008 12:48 pm Post subject:
I edit clicks & clipping out manually mostly, cool edit does have some tools for it but I find it easier and faster to just redraw the wave forms manually ... as long as it's only a couple of spots of course. _________________ Jan
seraph
Editor
Audio files: 33
Posted: Sat Jul 05, 2008 1:09 pm Post subject:
| Blue Hell wrote: | | I edit clicks & clipping out manually mostly |
it is a risky business, you can easily destroy a waveform. _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Posted: Sat Jul 05, 2008 1:46 pm Post subject:
| seraph wrote: | | Blue Hell wrote: | | I edit clicks & clipping out manually mostly |
it is a risky business, you can easily destroy a waveform. |
Yes that's the point, to get the click or the distortion out  _________________ Jan
seraph
Editor
Audio files: 33
Posted: Sat Jul 05, 2008 2:30 pm Post subject:
| Blue Hell wrote: | | seraph wrote: | | Blue Hell wrote: | | I edit clicks & clipping out manually mostly |
Yes that's the point, to get the click or the distortion out  |
yes but the risk is "throwing the baby out with the bath water" and I am sure you know what I mean  _________________ homepage - blog - forum - youtube
Posted: Sat Jul 05, 2008 3:23 pm Post subject:
| seraph wrote: | yes but the risk is "throwing the baby out with the bath water" and I am sure you know what I mean  |
The risk is not that big, as you're editing small parts only. Just getting the sharp edges out will do, even when you silence the whole thing for a couple of samples you'll not hear it, provided the edges are smooth. _________________ Jan
Posted: Sat Jul 05, 2008 4:15 pm Post subject:
| Blue Hell wrote: | | The risk is not that big, as you're editing small parts only. Just getting the sharp edges out will do, even when you silence the whole thing for a couple of samples you'll not hear it, provided the edges are smooth. |
This is quite right. Manually editing the shit out is probably the best way.
I suggest making a duplicate track and work on that.. and then try crossfades around the problem sections. And if this doesn´t quite work then layering other shit in just in order to mask doctored spots might work. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sat Jul 05, 2008 4:35 pm Post subject:
What applications do you use for this kind of manual editing (Mac or Windows)?
Posted: Sat Jul 05, 2008 4:51 pm Post subject:
| DrJustice wrote: | You may want to have a look at SeeDeClip by CuteStudio Ltd.. I've not tried it, but it was recommended by several people who ought to know. Cheap as chips too.
Hey thanks DJ- it looks just the ticket, and a bargain too
(and I can tell you guys who recommend doing things manually don't have kids!! Shame on you! )
(fwiw, the clipping was not my fault. The Exchange mastering studio were to blame for initially fucking up the levels. ) |
Posted: Sat Jul 05, 2008 4:59 pm Post subject:
| Antimon wrote: | What applications do you use for this kind of manual editing (Mac or Windows)?
/Stefan |
Peak ( Mac ) is quite good!  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sat Jul 05, 2008 5:06 pm Post subject:
Cooledit, on windows, but audicity could do it too (although I can't quickly find a way to make my fav. envelope dip thingy there, but a fade-in fade-out is present and it does sample editing, those will do the trick).
Basically anything that will do sample editing, having some sort of a macro tool is pleasant, I mean something that will allow you make a custom fade curve). Sometimes it's useful to run a filter an a couple of samples, but I don't use that very often.
What Stein mentioned, masking, is useful as well, so cut copy paste is handy. For instance cut a bit of the left channel to repair the right, or borrow a couple of milli seconds here to past it there, you'll need to apply some envelope curves as well.
Oh and when it has cue marks .. I mean I just hit F8 in cooledit to set marks at spots where something is wrong while listening through the track once or twice. Audacity does not seem to do that, but I have an oldish version here. _________________ Jan
DrJustice
Posted: Sat Jul 05, 2008 5:42 pm Post subject:
Correcting a few pops and cliks manually is probably just fine. But a track that has been consistently clipped as a result of a too high level and has lost lots of information and dynamic range requires stronger medicine. This is where the fancy specialist software comes in, attempting to recover the full waveform and dynamic range of the material, not just softening the edges.
DJ
Posted: Sat Jul 05, 2008 5:51 pm Post subject:
| DrJustice wrote: | | [...]a track that has been consistently clipped as a result of a too high level and has lost lots of information and dynamic range requires stronger medicine. |
True of course. _________________ Jan
Jyoti
Posted: Sat Jul 05, 2008 7:05 pm Post subject:
This recently got a pretty good review in SOS:
http://www.izotope.com/products/audio/rx/
| Quote: | key features
a complete standalone application designed for audio restoration
suppress broadband and tonal noise without the harsh artifacts of other solutions
remove intermittent noises, corrupted intervals and gaps with Spectral Repair re-synthesis
eliminate overload distortion by automatically rebuilding clipped sections of audio
clean up hum and buzz caused by poor wiring and other electrical problems
remove impulse noises like clicks, crackles and pops, digital artifacts and more
see more detail with innovative metering and the most advanced spectrogram display available
select by time and frequency to isolate and repair noise with surgical precision
save time by processing multiple settings in parallel, and revert to earlier settings with an undo history view |
_________________ My music: here! |
Posted: Sun Jul 06, 2008 12:28 am Post subject:
| The only problem though with the Isotope stuff is that it tends to come with a hefty price tag- and for one personal job, it isn't worth the outlay. The software that dj suggested only costs a tenner. |
seraph
Editor
Audio files: 33
Posted: Sun Jul 06, 2008 1:54 am Post subject:
| Blue Hell wrote: | | DrJustice wrote: | | [...]a track that has been consistently clipped as a result of a too high level and has lost lots of information and dynamic range requires stronger medicine. |
True of course. |
that's what I meant
| Antimon wrote: | | What applications do you use for this kind of manual editing (Mac or Windows)? |
you can do it with Logic8 (Mac only). I have never tried it because my tracks simply don't clip but I remember something like that on older versions  _________________ homepage - blog - forum - youtube
Posted: Sun Jul 06, 2008 3:10 am Post subject:
The declipping tools in Logic are, well, crap. They are better suited towards being creatively used to make new sounds- honestly!- Because I have done precisely that with them!  |
Posted: Sun Jul 06, 2008 7:22 am Post subject:
In Soundforge you can do a search for events whose level is equal or greater than -.1db to find all your clippings, then you can highlight them and do a "smooth" tool on them which just carves the sharpness off the corners/spikes. You can also draw in new waves, but I must admit that I'd like it to zoom a bit closer for freehand wave drawing. It only goes down to 1:1 which I think means one sample per pixel. I'd prefer the option of 4 to 8 times more precision. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Jul 06, 2008 7:24 am Post subject:
| v-un-v wrote: | | The declipping tools in Logic are, well, crap. |
That's why I suggested to do it manually
Running around in circles  _________________ Jan
seraph
Editor
Audio files: 33
Posted: Sun Jul 06, 2008 9:01 am Post subject:
| Blue Hell wrote: | | v-un-v wrote: | | The declipping tools in Logic are, well, crap. |
Running around in circles  |
as far as I recall you can do it manually with Logic. _________________ homepage - blog - forum - youtube
Posted: Sun Jul 06, 2008 3:22 pm Post subject:
Like I said.... I can tell you don't have children  |
