curetronic PCBs VCF Roland 100mSystem - Jen SX1000 ...
Page 1 of 3 [52 Posts]
Goto page: 1, 2, 3 Next
curetronic.com
PostPosted: Sun Jun 29, 2008 8:49 am    Post subject: curetronic PCBs VCF Roland 100mSystem - Jen SX1000 ...
Subject description: clones of earlier Modul/Syths for DIY
Hello, my name is Matthias Schmidt from curetronic.com.
Beside the curetronic modules recently I have offered layouts for
several people that are obtainable from me for 9 euros per item.
The first and the second pieces are vcfclones of roland 100m
system modul121 and of jen sx1000.
Silkscreen, layout and bom are in the pdf-file.
Then follow:
-roland 100m (modul 150) the ringmod, noise, s+h and clock
-phasershifter (modul 172)
-vco single (modul 112/110) with 726 replacement
Here is the link:http://www.curetronic.com/curetrbau/neubau/bau.htm
(Please bookmark this page, because it is not linked with the main
webpage of curetronic.com)
Possibly the reply to the inquiry takes a bit longer because my
English is not so good.
THX
yusynth
PostPosted: Sun Jun 29, 2008 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias
Thanks for making this cool stuff available.
Yves
etaoin
PostPosted: Mon Jun 30, 2008 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias,
A question about the 121 VCF doc. You mention there are two versions, depending on the VCA. Which version of the pcb is in the PDF?
[edit] think I already figured it out; it is the BA662 version.
http://www.casia.org/modular/
ericcoleridge
PostPosted: Mon Jun 30, 2008 1:54 pm    Post subject: Re: curetronic PCBs VCF Roland 100mSystem - Jen SX1000 ...
Is the VCO (w/726 replacement) a buchla or moog-like vco?
curetronic.com
PostPosted: Wed Jul 02, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
next PCB are ready: Ringmodulator, Noise, Sample + Hold und Clock of Roland 100m System Modul 150
@Etaoin
i think its moog like vco
Schematics:
http://sys100m.org[/url]
asafnetzer
PostPosted: Wed Jul 02, 2008 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Matthias,
Thanks for the offers, I think I'll just wait till the phaser is ready so I'll order a few together.
Best regards,
Asaf
etaoin
PostPosted: Fri Jul 04, 2008 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I got four BA6110 from Small Bear for the 121, but as a test, I also ordered a cheap 10-pack from Goodbuy711 (HKSS's twin ebay account). Some people claim all his semiconductors are either fakes or pulls, so I'm curious to see what I'll get...
bubblechamber
PostPosted: Fri Jul 04, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I was about to order a 10 pack, too. I'm looking forward to hearing back after you've had a chance to test them.
etaoin
PostPosted: Tue Jul 08, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
They are still untested. I hope to finish the PCB tonigh. But here's a first comparison.
The ones from Goodbuy711 came in a Hong Kong Superseller enveloppe (as expected). To the left the ones from Small Bear, right the Goodbuy711 ones. The ones from Goodbuy711 are obviously pulls, legs are bent and sanded down. Ink used for stamping them is responding quite differently to the flash on my camera, so they might even turn out to be fakes but I won't draw any conclusions about that untill I can test them.
BA6110. Right Small Bear ones. Left HKSS.
 Filesize:  419.49 KB
 Viewed:  435 Time(s)
etaoin
PostPosted: Wed Jul 09, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
For people who read the above, I swapped left and right by mistake. Fixed that now, but people might not notice. There are four from Small Bear and ten from Goodbuy711. Just to make it clear.
PCB mostly populated so tests are closing in...
Audio files: 297
PostPosted: Wed Jul 09, 2008 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It definitely makes more sense now Laughing
etaoin
PostPosted: Sun Jul 13, 2008 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, I finally got the 121 VCF in testable state. As far as I can tell, there is no difference between the Small Bear 6110's and the ones from Goodbuy711. So apart from them probably being pulls and not new (as claimed in the ad), they seem to be fine. No telling what someone else will get though, so I can only vouch for the ten I got.
bubblechamber
PostPosted: Sun Jul 13, 2008 8:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Etaoin, i'll grab a few and see if my luck holds. thanks for the update.
bubblechamber
PostPosted: Sun Jul 13, 2008 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
curetronic.com
PostPosted: Wed Jul 16, 2008 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
-finished PCBs now available
for example: Roland 100m system Ring/Noise/S+H/Clock for 39 euro+shipment
 Filesize:  44.24 KB
 Viewed:  404 Time(s)
etaoin
PostPosted: Thu Jul 17, 2008 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
To avoid even more confusion: my test-6110's came from eBay seller Goodbuy711 and not from HKSS. Even though I believe they are the same seller (they were shipped in an enveloppe with HKSS stamp on it), I can't be sure HKSS sells the same 6110's.
Dego
PostPosted: Fri Aug 08, 2008 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the vco on its way? Smile Really looking forward to that one Smile
/mr
PostPosted: Tue Aug 12, 2008 3:46 pm    Post subject: Re: curetronic PCBs VCF Roland 100mSystem - Jen SX1000 ...
Or even a Roland-like VCO? The horror! Laughing
ericcoleridge
PostPosted: Tue Aug 12, 2008 4:45 pm    Post subject: Re: curetronic PCBs VCF Roland 100mSystem - Jen SX1000 ...
well, I guess a roland vco wouldn't be too bad either.. Laughing
as long as it's a sys100 or sh7, that is. Smile
curetronic.com
PostPosted: Wed Aug 13, 2008 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
next PCB are ready:Roland 130 Dual-VCA
http://www.curetronic.com/curetrbau/neubau/130m.htm[/url]
etaoin
PostPosted: Wed Aug 13, 2008 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Neat. Something to use all those extra BA6110's in Very Happy
Now I only need to figure out how to fit these long pcb's in my Frac case.
3vcos
PostPosted: Sun Aug 24, 2008 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
These are very cool. I'm curious, how far along is the vco? when do you expect to have pcbs for it? Thanks.
curetronic.com
PostPosted: Wed Aug 27, 2008 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
and the next:
PHASE SHIFTER Roland 100m system Modul 172
link: http://www.curetronic.com/curetrbau/neubau/172ph.htm
rjd2
PostPosted: Wed Aug 27, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for doing this, matthias. i have a question-if if wait til the VCO is done, do you think you still will have vcf/vca boards left? got a backlog here, and would like to just pay shipping once. thanks.
/mr
PostPosted: Thu Sep 04, 2008 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Any more exciting modules planned after the remaining VCO?
My situation is almost the same as rjd2's above - I'm planning to buy the M-150 and 2 x M-121, but not the VCO, and I'm wondering if I should wait for some more goodies or just put my order and start soldering like crazy. Smile
Thanks for making these projects reality!
