HB3
Posted: Sun Jul 13, 2008 5:47 pm Post subject:
Old OS for Nord 3 |
| Does anyone have an older OS for the NL3? Something before they instigated the new arpeggiator. Thanks. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Jul 13, 2008 9:15 pm Post subject:
HB3
I think the chance getting it from other users is very low... There weren't that much updates and machines which were delivered containing that particular version, would be updated to V 2.0 without saving - I wouldn't even know how - the earlier OS to a computer.
I believe the only way to get it is by Clavia itself. Write to support and ask if maybe M Kjellander, the main designer of the synth, knows an old computer somewhere in the basement which has that OS still on its hard disk... I don't have much hope, but not trying...
On the other hand, why do you want to down grade? Maybe there is a work-around to get the same results?
Wout |
HB3
Posted: Sun Jul 13, 2008 9:28 pm Post subject:
Hey, thanks. I did write Clavia. Haven't heard anything yet.
I don't like the way the new arpeggiator responds to real-time playing -- there's something about the way the notes trigger when the arpeggiator is running that's different on the older OS. It's hard to explain -- like the notes don't play until the next tick of the clock, so sometimes you hit a note and there's a brief moment of silence, and then the note sounds on the beat of the clock. On the older OS, you'd hit the key and the note would sound immediately, no matter if it was in exact time w/ the clock or not. I thought the "key sync" feature would correct this, but it doesn't. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Jul 14, 2008 12:22 am Post subject:
Hmm...
I think it's time to dust off my NL3
Luckily I have a 7 weeks long holiday tomorrow, so I could make some time...
I don't remember the old situation, though, but maybe we can tackle the problem.
Can you send me the program/patch you're using in SysEx format? Then all parameters, even the Arpeggiator, are the same is both locations.
Wout |
Joined: Apr 03, 2004 Posts: 24498 Location: The Netherlands, Enschede
Posted: Mon Jul 14, 2008 6:10 am Post subject:
| HB3 wrote: | | Hey, thanks. I did write Clavia. Haven't heard anything yet. |
Clavia always used to shut down completely for a month somewhere during summer, it might be that time of the year. _________________ Jan
HB3
Posted: Mon Jul 14, 2008 6:43 am Post subject:
| Wout Blommers wrote: | Hmm...
Wout |
I dusted mine off, too, that's the problem.
I'll send you a file later today, but everything I'm doing is pretty stock. I think I was using the 1:60 Horner patch, but as long as it's something with good attack, it doesn't really matter. Set the arp running, turn on keyboard hold, and start playing random notes out of time. Despite keyboard hold, there will be gaps in the sound as you play notes.
Maybe I could send you a brief audio file as well. |
HB3
HB3
Posted: Thu Jul 17, 2008 9:57 am Post subject:
| Stumped? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jul 17, 2008 10:12 am Post subject:
No, to busy to do some serious listening at the moment. Next monday...
Wout |
HB3
Posted: Thu Jul 17, 2008 10:18 am Post subject:
| Cool, thanks. |
Alias
Posted: Wed Jul 23, 2008 4:54 pm Post subject:
My findings |
Here are my findings:
With arp rate at 70 I have the same stuttering effect you hear in the mp3. My first thought was to turn on KB Hold to remove any tiny gaps between played notes -- this had no effect. When I turned the rate way down (to 20ish) you can clearly hear [sic] the missing notes. Play two notes in quick succession (faster than the arp rate) and the second note will not be played until it's hit by the arpeggiator.
Then I turned KB Hold off -- now it works! Well, almost: If you play every note staccato you will hear every note, but if the keydown on the second note occurs before the keyup on the first note, clipping will occur.
Luckily there's a setting that only allows one note to be played at a time... I went to turn on Mono (actually it's already on in Moog Bass) -- no difference! By definition mono means only one note can be down at a time, but it seems the interval is too short (or the keyup/keydown events happen simultaneously) and the arpeggiator still drops notes. You can also hear this effect by playing one note very fast with KB Hold on.
Some of this makes sense: when playing a chord, only the first note should be played immediately. It also lets you modify a chord while the arpeggiator is running, and only hear the new notes when they are hit in sequence. But turning on Mono should have fixed this -- the user is explicitly stating that they only want to play one note at a time, and each keydown should result in a note played. |
HB3
Posted: Wed Jul 23, 2008 5:53 pm Post subject:
Interesting. I'll experiment with key hold off, but the whole idea was to sort of improv with it on...not sure if it will work. The old OS, before the new ARP, didn't stutter at all.
I heard from nord tech support and he confirmed the clavia guys are all on vacation. |
HB3
Posted: Wed Jul 23, 2008 11:13 pm Post subject:
| I tried turning off keyboard hold; it doesn't really change things that much, but I see what you mean. I was thinking the "Clock Key Sync" parameter under "Master Clock" might help, but it doesn't seem to make any difference whether it's on or off. |
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Thu Jul 24, 2008 2:46 am Post subject:
7 weeks of holiday (you are a teacher i guess) and a nl3 parked under a dust cover . . . good wetter, 2008 is gonna be a good holliday. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jul 24, 2008 6:03 am Post subject:
| W.T. wrote: | 7 weeks of holiday (you are a teacher i guess) and a nl3 parked under a dust cover . . . good wetter, 2008 is gonna be a good holliday. | Only 6 weeks and the weather (das Wetter is German, BTW well, my doctor just gave me a medicine which is forbidding me to stay longer then 10 minutes per day in the sun...
Wout |
W.T.
G2 patch files: 11
Posted: Thu Jul 24, 2008 11:16 am Post subject:
I have such a problem to, thanks to some auto autoimmune disease i cannot stay to long in the sunlicht..... i love the sun  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Aug 03, 2008 8:24 am Post subject:
I wasn't a big fan of the NordLead3 Arpeggiator (using most of the time the NordLead2 - that one has MidiOut, the NordLead3 hasn't - but now I would say it's a waste to create a knob for it
Over here it doesn't work either. KB Hold helps a little, but not the way I want it to play. (BTW Legato in this configuration is a real pain...)
I'm sorry, but I don't have any solution for the strange hick-ups...
Now I also understand why they left this concept when designing the G2, which has NordLead2 like Arpeggiators.
Wout |
HB3
Posted: Sun Aug 03, 2008 11:31 am Post subject:
| Still waiting to hear back from Clavia.... |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Aug 03, 2008 11:45 am Post subject:
| HB3 wrote: | | Still waiting to hear back from Clavia.... | Not before thuesday, I think...
Anyway, beware that the Patches in the Archive are all 1.20. Nothing is sure about forward comptability... Can 1.08 load 1.20 Patches?
Wout Last edited by Wout Blommers on Mon Aug 04, 2008 12:43 am; edited 1 time in total |
HB3
Posted: Mon Aug 04, 2008 12:02 am Post subject:
| Heard from someone at Clavia who emailed me OS 1.08 -- yay! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Aug 04, 2008 12:46 am Post subject:
| HB3 wrote: | | Heard from someone at Clavia who emailed me OS 1.08 -- yay! | They started early, today As told in other threads: if they can help you they surely do.
Tell us if there are any troubles loading V1.20 Patches and also when it doesn't.
And send us a mp3 about the differences
Wout |
HB3
Posted: Mon Aug 04, 2008 12:13 pm Post subject:
| I tried installing some of the 1.20 patches and got an error saying I needed to active receive....it looks like it is activated as far as I can tell. Actually I don't think I've ever transfered any patches into it before, so I don't know if this is normal or abnormal...under midi I can select "Send and Receive" and set it to "send" "receive" "send and receive" or "off." I have it set to "send and receive." |
HB3
HB3
Alias
Posted: Sun Aug 24, 2008 12:58 pm Post subject:
| Thanks! |
