fonitronik
Page 1 of 1 [19 Posts]
PostPosted: Fri Jul 11, 2008 2:48 am    Post subject: fonitronik
Subject description: some layouts (more to come)
any rules?
so i am making a start posting layouts. i think i will just add a layout to this post from time to time...
Roman Sowa's RingMod
dual Thomas Henry's 8038 VCO
dual Thomas Henry's SSM2164 VCA
CV processor
292c LowPassGate
Jürgen Haibles Wasp VCF
Resonators (without LFO)
SSM2044 VCF
doepfer compatible bus board
synthmonger
PostPosted: Tue Jul 15, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Any chance you'll be posting your mixer? Very Happy
PostPosted: Tue Jul 15, 2008 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wink
i am currently asking for interest in a 2nd run of professional manufactured PCBs for the mixer...
synthmonger
PostPosted: Tue Jul 15, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Righteo!
You might want to post a link to your euro buss board pcb. It's very useful! Thanks again for that.
Danno Gee Ray
PostPosted: Tue Jul 15, 2008 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Mathias.
PostPosted: Wed Jul 16, 2008 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
synthmonger wrote:
Righteo!
sure. i forgot about it. actually i use stripboard now, since i found a 40cm piece at a german online shop: it is exactly what i want. 5 stripes allready drilled. one will only have to solder the female ribbon connectors to the board and that's it...
however i will post the link to the bus PCB soon.
Sound
PostPosted: Wed Jul 16, 2008 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.modular.fonik.de/pdf/TH_dual_VCA.pdf Very Happy 21st Century Synthesizer VCA
Για σας
Rykhaard
PostPosted: Wed Jul 16, 2008 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found the PCB (hand drawn) layout for my Liquid Hihat. The schematic is done as well, in Ray Wilson's software. I'll try and have both of those posted within this message, later tonight. If not, then by Friday. Smile
There'll also be a NEW LFO posted into here from me with a few days, once I come down to it's final schematic and PCB layout. I've just posted a huge bit of info on it, to the Design section of my web page.
(space reserved for Liquid Hihat data) Wink
PostPosted: Thu Jul 17, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Rych, maybe it would be better to start a new topic within the layout factory subforum, instead of just one fonitronik thread. we could things keep sorted. Wink
Rykhaard
PostPosted: Thu Jul 17, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Whoa! Thank golly, YOU're thinking! I should've been able to think of that for myself! Very Happy
Otay! I'm just going to make sure everything is fine / understandable for both of them and start a new thread then.
Thanks for cluing me in! Smile
scriptstyle
PostPosted: Thu Jul 17, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
im real excited about this new sub—forum!!! so far 100% awesome! Very Happy
and thanks fonik that doepfer bus board is just in time for me, power supply should be here today!
PostPosted: Tue Aug 05, 2008 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
added the SSM2044 VCF
don't forget to use an attenuator on the Q CV input. it is linear and the attenuator will give better control (i will redesign it, if there is enough interest for a new PCB sometimes).
j.dilisio
PostPosted: Fri Oct 23, 2009 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The sequential switch link is broken.
Is there a new address for this?
DRONEGOAT
PostPosted: Thu Nov 26, 2009 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
no, i had to delete it. it did not work properly, but you will find a schematic at least for a nice one at my site.
fiveman
PostPosted: Fri Aug 06, 2010 8:44 am    Post subject: sequential switch Reply with quote  Mark this post and the followings unread
OK, I understand now. I made the sequential switch pcb up and then put it on she shelf for a while. I then went to build it from my notes went to the link and found it busted and have been taring my hair out since.
bamboombaps
PostPosted: Thu Dec 17, 2015 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hey do all these work on 12V?
LFLab
PostPosted: Fri Dec 18, 2015 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built the 2044 VCF (actually, I built three), and the WASP VCF, and can confirm these all work on +/- 12v.
bamboombaps
PostPosted: Fri Dec 18, 2015 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Sebo
PostPosted: Sun Dec 27, 2015 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing!!!
Sebo
My Music:
