midi-sync24 schematic, not the best photocopy
Page 1 of 1 [11 Posts]
Luka
PostPosted: Tue Jul 22, 2008 7:03 pm    Post subject: midi-sync24 schematic, not the best photocopy
Subject description: please help me work out this schematic
i want to use my 606 and tb303 and hopefully this converter will do the job.
there are a few things inside it that are confusing me. first the cmos NOT gates at the start would be from a 4049 would they not? (pun intended Wink) it looks like 4044 is written down but 4049 makes more sense to me.
also between the top line of not gates there is a 10k resistor and something else. what is that, i havent seen that symbol used before and cant read the anotation.
problemchild
melbourne australia
widdly
PostPosted: Tue Jul 22, 2008 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice idea.
It looks like 4049 to me which makes sense.
The other thing is a crystal oscillator. They usually have a frequency. Very hard to read on your diagram.
Apparently this is powered from the midi port. There doesn't seem much detail on that. Is the power coming off the midi thru?
richardc64
Audio files: 26
PostPosted: Tue Jul 22, 2008 8:04 pm    Post subject: Re: midi-sync24 schematic, not the best photocopy
Even enlarged the crystal marking is hard to read. Looks like something5500KHz.
Power connections are omitted for "clarity." The horizontal lines above components seemingly going nowhere are the positive supply -- most likely 5volts -- and the horizontal line below components are ground.
etaoin
PostPosted: Tue Jul 22, 2008 11:48 pm    Post subject: Re: midi-sync24 schematic, not the best photocopy
According to the 6402 datasheet clock should be 16 times the received bitrate. So it should be 500 kHz. I think that is what it says, and there are some additional characters in front of it.
Clever use of the 6402... Might try this one myself.
Pity they left out an input optocoupler, but they needed to do that to make it "self-powered" (i.e. powered from midi-in).
http://www.casia.org/modular/
widdly
PostPosted: Tue Jul 22, 2008 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah the self powered bit is what I find intereseting. I have a few commercial boxes that are port powered and always wondered how they do it.
Is the 2k2 resistor coming of the midi in supplying the power? I would have thought you would need a capacitor as well.
Luka
PostPosted: Wed Jul 23, 2008 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
here is the pcb layout etaoin
there was no component layout posted
it came from here
http://www.hollis.co.uk/john/circuits.html
problemchild
melbourne australia
etaoin
PostPosted: Wed Jul 23, 2008 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
There is, near the 6402. And a 5.6V zener as well.
What I find more confusing is that the input isn't referenced to ground anywhere, but that's probably just missing from the diagram. Usually you'd use the fact that the midi outputs have pin 2 connected to ground.
I'm not a big fan of midi-powered equipment as most of those lose the advantage of midi equipment being opto-isolated and hence increase the potential for ground loops.
Dave Kendall
PostPosted: Thu Jul 24, 2008 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi All.
Maybe I can help out a bit.......? I've got a *very nearly* working 6402 based MIDI to sync24 converter on the test bench using CMOS and HCMOS. Sadly, it's been mothballed there for a year or so, as it's doing more or less everything it should, *except* that there is an extra pulse on the CLOCK OUT pin whenever a START or STOP command is recieved, which throws off the timing when a divider chip is used to get 1/16 divisions and so on.
I've used different parts from what I can make out from the schematic, and mine's got Blinkenlights on it Smile I suspect I'm not too far off at all, but have got stuck at the last hurdle....
There are some very rough schematics (well, sketches really....), and they will need re-working to take into account the latest bits that are on a breadboard. The original intention was to get the circuit fully working and donate the idea and schematics to electro-music if people were interested. Perhaps jointly we can get the best bits of the circuits and come up with a soild working design, and maybe even a PCB? My original idea was for a MIDI clock to pulse converter, with MIDI PGM change to select the divisions. The design looks like it will allow for this, although I've only had a few rough ideas so far for the PGM change decoding. This part would probably add quite a few extra logic ICs, but it's all PIC-Free for CMOS junkies! Smile
What do you all think?
Am very busy for a few days, so can't do much on it for a wee while, but am happy to share what I've got so far with EM......
Very early photo. About 7 ICs + a few extra bits and bobs needed to get it to work.....
 Filesize:  223.68 KB
 Viewed:  189 Time(s)
etaoin
PostPosted: Thu Jul 24, 2008 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Where did you find your 6402?
Dave Kendall
PostPosted: Thu Jul 24, 2008 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
On eBay UK. I got a few spare, and last time I looked production status was still listed as active on Intersil's site. Around $7 US in quantity IIRC.
etaoin
PostPosted: Thu Jul 24, 2008 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe I'll try to sample it. It needs to come cheap, as I already have two ADV-MIDI boards that do exactly the same (and more). I'm just intrigued by the simplicity of this one.
