revised 292c LPG PCB layout...
Page 3 of 4 [85 Posts]
Peake
PostPosted: Thu Aug 14, 2008 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see mods replacing the LF13331!
(Still working on finishing my 292c)
PostPosted: Fri Aug 15, 2008 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
that's good. and i think i will be going to build another one for myself...
guitarfool wrote:
fonik wrote:
the resonnance option is not tested, yet. i am not sure if someone built it in yet.
It's tested Very Happy I was going to build a classic LPG using an older layout, and yours came out right after I'd finished the panels. So I built my first one without the feedback.
I've since built a second one WITH the feedback option, and it is wonderful. Now I have to do a new panel, so if anyone wants a couple of Moog/Dotcom format panels for a classic LPG... Sad
Anyway, there is absolutely nothing wrong with the schematic or layout.
If yours works without the option (jumper between "A" amd "B" on JP1), then the switch is probably okay. In this configuration, JP2, R18 and P2 are not needed. For the resonance option, point "A" of JP1 is jumpered to point "A" of JP2, and point "B" of JP1 is jumpered to point "B" of JP2. Maximum resonance occurs when the wiper of P2 is at the R18 end of the pot. At the other end, feedback is unity and the circuit behaves exactly like one without the resonance option. I tried both of mine (the first one without the option) and the second one side by side in the same patch, and with the resonance set to minimum, they sounded identical. I hope to get a sound file up this weekend to demonstrate.
With the resonance control above about two thirds, it will self resonate.
The resonance control only affects the LP mode: it does nothing in Gate or Both modes.
I heartily recomend adding it Very Happy
Funky40
G2 patch files: 5
PostPosted: Fri Aug 15, 2008 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
neandrewthal wrote:
Every single LPG I've seen has no CV attenuators. Is there just no need for them in the way it is typically used, or is everyone using external attenuators?
my own drawing has three CV inputs and the Modul i built has 2 attenuators for CV.
But the behave of the pots is not 100% satisfaying ( maybe i took 100K and should be 10K )
there is a BIG ! need for multiple CV inputs AND for attenuators .( at least for me )
This File: http://funky40.podspot.de/post/16-visit-at-the-mars-zoo/
had not been possible without my new LPG.
It was made the first evening after the first tests, so it was somewhat the final testing for my new LPG.
Ilanode
PostPosted: Sun Aug 17, 2008 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
guitarfool wrote:
fonik wrote:
did i misunderstood his suggestions? can't see why. anyone?
No. You did good Very Happy
Yes, you did. My 2nd LPG works just fine and the Res. dials in very nicely different to other LPGs I know. Thanks for the layout!
synthmonger
PostPosted: Thu Aug 21, 2008 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about rotary switches?
http://www.ace4parts.com/Products/3-Pole--3-Position--Non-Shorting---Rotary-Switch__30-15303.aspx
cheaper and prettier imo ;D
synthmonger
PostPosted: Thu Aug 21, 2008 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
What does C5 and R5 do?
Ilanode
PostPosted: Fri Aug 22, 2008 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Serenadi posted the following explanation on a German forum: C5 and R5 make the input more sensitive to higher frequencies. AM will be a bit stronger which should solely noticable when connecting a VCO modulated by a slow LFO to the CV In. The sound should become a little brighter.
Hope that helps.
PostPosted: Fri Aug 22, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
good to know the what. the how is just another quenstion (that i could not answer, though).
Serenadi
PostPosted: Fri Aug 22, 2008 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
...the how is just another quenstion (that i could not answer, though).
It's easy but for me it's not as easy to explain in english. Very Happy
I'll try:
C5 and R5 are just wired parallel to R4, the main input resistor of the CV-input.
C5 functions as a highpass.
The easiest way to think of the function of a cap is to consider it as a frequency-dependant resistor.
The higher the frequency the lower its resistance.
So with higher frequencies of the modulation signal, think of a link instead of C5 (resistance=0).
The input resistor will be R5 parallel to R4, which gives a value of 82k.
At lower frequencies of the modulation signal, think of a break instead of C5 (resistance=infinite) - the input resistor is just R4 - 100k.
A little bit larger than 82k, so the sensitivity of the CV-input will be a bit larger at high frequencies.
Patch a VCO to the CV-Input and wobble its frequency from LFO range to higher audio frequency.
(e.g. with an lfo)
At LFO range, the modulation index is the same - with or without C5/R5.
But in the audio range, the index is a bit larger when C5/R5 are connected.
Hope someone could understand. Wink
PostPosted: Fri Aug 22, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
you did quite fine, serenadi. thank you a bunch for this good explanation...
Serenadi
PostPosted: Fri Aug 22, 2008 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
you're welcome.
guitarfool
PostPosted: Wed Sep 17, 2008 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a crappy sound sample of the LPG with resonance. It starts out with a square-wave audio input and a rounded-square LFO for the CV. It's in "LP" mode with resonance off. The resonance is gradually turned up to 3/4, and then the LFO is increased up into the audio range (FM!) and then back down. Notice that as the LFO is increased, the ausio signal starts bleeding through because the vactrol (due to it's sluggish response) no longer closes.
Well, sorry it took me so long to put this up. I hauled my entire modular up to Baltimore for the Baltimore SDIY / 8-bit festival and it took up all my time to get things ready. It was worth it Very Happy
Buchla_LPG_resonance&FM.wav
 Filename:  Buchla_LPG_resonance&FM.wav
 Filesize:  908.06 KB
 Downloaded:  1115 Time(s)
Luka
PostPosted: Wed Sep 17, 2008 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am about to build a quad using this design. i am going to adapt it onto one board, so i have a few questions to everyone who has a set.
is it worth adding a summing amp for the cv in so i can add multiple cv ins per lpg?
is it possible to bump up the summed cv and then drop them down again post LED to enable negative voltages. what kind of setup would let me do this? considering im buildig a quad i was hoping to intergrate a DIP or something to handle them all at once. will this introduce cross talk?
sorry about trying to pry all this out of everyone, obviously im still getting to grips with circuit design so any tips would be most awesome
problemchild
melbourne australia
Funky40
G2 patch files: 5
PostPosted: Thu Sep 18, 2008 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes !
i just added the input section without summing amp, but the lin/log characteristics of the attenuators seems to be a little to logarythmic to me.
I think i will add an OP amp input stage also for CV. It might give a better control over Gain and lin/log characteristics.
edit:
thanks Guitarfool for the Demo !
Luka
PostPosted: Thu Sep 18, 2008 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
great thanks for the info funky
ive had this idea that the lpg would love complex cv patterns
having no hands on experience with this unit i was keen to hear someone tell me it was worthwhile
thanx
ok ill do some futher research onto whether it is worthwhile feeding it negative voltages
problemchild
melbourne australia
vtl5c3
PostPosted: Thu Sep 18, 2008 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I built a quad LPG with single CV inputs. I used it for a gig about a month ago and regretted not having multiple control inputs. I ended up dedicating the CV ins for EG control, but I ended up wishing I could play with a quadrature LFO and Joystick without having to switch patchcords.
djthomaswhite
PostPosted: Thu Sep 18, 2008 8:09 pm    Post subject: LPG with Resonance PCB's Reply with quote  Mark this post and the followings unread
Hi Guys,
As a mod (although, not sure how electrically sound... it just works) you can connect a resistor between pins 6 and 7 of the TL084 to switch in a lower overall offset setting. I used a 47K.
I found this necessary on my build where I used slower VTL5C4 vactrols. This means even though the vactrol is a slow device and has a "fall time" you can use CV to make a more extreme upward opening of the filter when pulsing a much lower offset setting. I can switch it in and out. For example the lower offset does not help the VCA mode at all IMHO.
I have PCB Express design for the PCB (attached image). If you would like to get together on a small run of PCB's let me know and maybe we can put together a "shared buy". For example, a run of 50 would result in PCB's that cost about $10 for double sided, solder masked with silk screen. Any interest? It has the Resonance mod built on and is selectable with jumpers. There extra resistor mod also has pads.
Here is a link to my youtube file of the test run:
http://www.youtube.com/watch?v=S_Wu9NlI2qE
Thomas
ExpressPCB.pdf
Silkscreen layer and top of pcb
 Filename:  ExpressPCB.pdf
 Filesize:  55.3 KB
 Downloaded:  325 Time(s)
Thomas
www.naturalrhythmmusic.com/diy.html
neandrewthal
PostPosted: Thu Sep 18, 2008 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm down for a quad LPG with resonance Very Happy
fluxmonkey
PostPosted: Fri Sep 19, 2008 6:57 am    Post subject: Re: LPG with Resonance PCB's Reply with quote  Mark this post and the followings unread
absolutely! put me down for 8!
bbob
www.fluxmonkey.com
vtl5c3
PostPosted: Fri Sep 19, 2008 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd take a couple! Any chance the layout could be made to work with VTL5C4/2s?
Romeo
krisp14u
PostPosted: Fri Sep 19, 2008 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i would take 3 if thers a run
cheers
Paul Darlow
www.krisp1.com
bugfight
PostPosted: Fri Sep 19, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
akkk more temptation
if this happens, i'll take 4
gotta feed the queue.
ever hungry, all mighty queue...
Junk Rhythm
PostPosted: Sat Sep 20, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for at least 2.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
Photon
PostPosted: Wed Oct 22, 2008 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
does anyone have any tips for adjusting the trimmer? What should I be listening for?
Thanks
LektroiD
PostPosted: Thu Oct 23, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
If this is the same board as the one I ordered from djthomaswhite, I've made a massive boo boo! I ordered all the components as in the list:
http://electro-music.com/forum/download.php?id=14435
Cost me a fortune too!
Please tell me these are different boards Confused
