Piezo's in Parallel?
Page 1 of 1 [18 Posts]
PostPosted: Sat Aug 16, 2008 2:29 am    Post subject: Piezo's in Parallel?
Subject description: I think I'm getting somewhere now!
Hey everybody!
There's some very interesting, and yet painfully slow R&D going on in the Uncle Krunkus lab!
Ideas which have been going around in my head for quite a while are finally being made real, and are mostly being returned to the drawing board! Laughing
Still,...... Up from the ashes!
Anyway, I'm onto a new way of doing an old thing, kinda hybridising a whacky idea with a tried and true one, and I was wondering if you used two piezo's as a common pickup, would it be better to wire them in parallel, or series?
I think the answer is in parallel, as that would halve the impedance, which tends to be too high.
Any thoughts?
yusynth
PostPosted: Sat Aug 16, 2008 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess that in series you would add the amplitude (voltage) of picked signal but with a doubled impedance. In parallel, the amplitude would be the same and the impedance divided by two...
Yves
frijitz
Audio files: 54
PostPosted: Sat Aug 16, 2008 9:35 am    Post subject: Re: Piezo's in Parallel? Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
... I was wondering if you used two piezo's as a common pickup, would it be better to wire them in parallel, or series?
I'd say in parallel. These are capacitive devices with very low dc conductivity, so if you do try a series connection you will want a pair of large R's to provide the correct dc bias.
Ian
PostPosted: Sat Aug 16, 2008 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian,
I'm not 100% sure I understand the ramifications of them being "capacitive devices", but I'm sure I'll find out soon if they suit my needs. Very Happy
With two in parallel, would I still put a loading resistor/s across them before going to a TL07X buffer like in the SoundLab drum trigger? (link added for reference)
http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/drum_trigger.html
Unlike the drum trigger, I do need to keep hum and noise to a minimum.
frijitz
Audio files: 54
PostPosted: Sat Aug 16, 2008 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your project doesn't seem too hard. Here's a guy that makes seismometers from piezo discs. Shocked
http://jclahr.com/science/psn/chapman/piezo/index.html
If electrical pickup is an issue, you will need a high-impedance buffer right next to the disc to use it in voltage mode. You could use a single FET mounted close by, mayber even a cute little SMT circuit.
But if it was me, I'd see if I could go current mode (piezo as a current source driving an I-V converter). That way the disc is at zero potential so a shielded lead would guard the signal without any loading capacitance.
But I've never seen anyone do this. scratch
Ian
PostPosted: Sun Aug 17, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I saw a couple of Piezo pre-amps which used a FET. They actually reduced the signal rather than amplify it, the important thing was (as you said) to shift the impedance.
Hmmmm,..... Sounds great, but,
I've got no idea what it means or how to implement it. Laughing
frijitz
Audio files: 54
PostPosted: Sun Aug 17, 2008 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, if you're game to try it (just takes a second):
Opamp (+) input to ground
Opamp out through large R (10M? Experiment!) to opamp (-) input
Opamp (-) input to piezo bottom
Piezo top to ground.
Use a shielded cable, grounded near the opamp, to connect the piezo.
I've always wanted to try this but never got around to it. Let me know if you get a chance to give it a go.
Ian
PostPosted: Sun Aug 17, 2008 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks heaps Ian,
I settled on a particular mechanical setup last night, so the next thing is to build a couple of these right next to my two piezo's. Which I've decided to run antiphase, so I could take the outputs of these I->V converters straight to either side of a third op-amp yeah?
I think I may have damaged my last LM386 as well! Laughing
I didn't have a bypass cap (10uF) across the 12V for the LM386, and it started squealing! Then it got quite hot! So I shut down, put the cap back, powered up, and, no squealing. But also not as much signal to the transformer either! Confused Laughing I think I need a few new ones. Smile
frijitz
Audio files: 54
PostPosted: Sun Aug 17, 2008 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might try just reversing the leads of one transducer and feeding both into the same I-V converter.
I've been playing around with the current mode setup a bit today. Seems to be working. I only need about 220k for the feedback resistor. Are you doing audio, though? I've just been trying to detect taps. Audio might be more complicated.
Ian
PostPosted: Sun Aug 17, 2008 10:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried reversing the leads for an experiment, but for the main design idea I've got little hooks soldered to the brass base, they are not insulated, (you'll see why when I post another pic, soon) so reversing the leads would short one piezo out.
While we're at it, do you know what the efficiency of a piezo is? Effective both ways? For example, if you vibrate one piezo which is electrically connected to another, how much of the original vibration is reproduced on the other side? What kind of "booster" would work between the two in order to keep it at unity?
These might seem like silly questions, but I think it's good to get to know all about a certain "medium" while I'm in the thick of the brainstorming stage.
As a completely separate, and yet related question.
You know the standard pair of clipping diodes around the feedback loop of a classic fuzz circuit?
No,... on second thoughts, that is a silly question, or one I should just verify through my own experiments. I'll try to expand on that thought later. Wink
PostPosted: Mon Aug 18, 2008 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
My approach to these experiments is so lo-fi that taps are audio! Laughing
Anyway, I've got one set up, and it seems to sound great! Maybe a bit too bright, but that's exactly what I was hoping for! Very Happy My piezo lead is currently about 4" long and unshielded, and not picking up much noise. I'm gonna try doing the other one and then summing them antiphase through the third.
Is the first op-amp enough to buffer the piezo? The output of the third would definitely be fine to plug straight into a VCF yeah?
PostPosted: Mon Aug 18, 2008 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
No, with the two of them into a third op-amp, I get this high pitched squeal which sounds a bit like heterodyning (or ring mod?). It stops when I touch the output with my finger, but comes back if I just clap my hands.
PostPosted: Mon Aug 18, 2008 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now I've got something good happening which sounds stable.
I took the two outputs to the other two op-amps in a TL074. One of them just as an inverter, the other as a summing inverter. I used 10Ks all round except for the feedback on the summer which I set at 51K for a bit more gain. BTW Ian, is there a problem with reducing the 220Ks? As I'd like just a little more gain off the bat, or will that increase noise etc?
PostPosted: Mon Aug 18, 2008 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, actually, to increase the gain I'd increase the 220Ks wouldn't I?
frijitz
Audio files: 54
PostPosted: Tue Aug 19, 2008 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think what you want is each transducer connected to an I/V converter, with the two converters feeding a standard difference amplifier:
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/opampvar6.html
(second figure).
Yes, you can increase the output of the converters by increasing the resistors. My experimental setup yesterday put a very strong bending force on the transducer, so I got a nice strong output. You will have to experiment to find the best value for your experiment. The gain of the difference amplifier is R3/R1, so you can get gain there too. Also the correct way to roll off the high frequencies is to put identical caps across the two R3 resistors.
Glad you are getting useful results!
Ian
PostPosted: Tue Aug 19, 2008 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
(second figure).
Yeah I found one of those, and was going to try it, but it had V1 referenced to V2, V2 referenced to Gnd. I didn't know how to achieve that on the other side of the V-I converters, so I did the Inverter + Summer idea instead. I'll definitely try the differential amp you pointed me at though, as I want to keep it as simple as possible. Also, if things work out, this will just be one side of stereo version, so I'd like to keep the op-amp count as low as possible. I may yet have to incorporate a notch filter on each side as well! Rolling Eyes
The differential amp will be fine with 10Ks all round yeah?
Yeah, my piezos have a reasonable pulling force from the centre of the main brass disk, with two restraining/holding points soldered to opposite edges. They are actually putting out a very good signal.
These R3s are the feedback resistors on the two I-V converters yeah? I actually had already put a 1n2 cap around my summer, but I see now that it would be better to deal with this at the I-V converter. That way I'm not amplifying noise just to take it away later. Are there other good reasons for this I should know about?
Thanks again Ian for this help.
I think I have leapt far ahead in the pickup stakes. Now I need to re-visit the input drivers and see if I can finesse the way I get this thing moving around in the first place. Very Happy
frijitz
Audio files: 54
PostPosted: Wed Aug 20, 2008 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
That's OK. But you might want to build some gain into this stage also, just on the principle that it usually works best to distribute the gain in a high-gain circuit. So the two R3's in the diff amp schematic I linked you to could be maybe 33k or something.
No, I was refering to the two R3's in the diff amp schematic (feedback R and R from (+) to ground). This is how you get equal filtering on the two input signals.
Ian
PostPosted: Wed Aug 20, 2008 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay,
I'll be breadboarding this up tonight, and I should have my new LM386s by Friday, so I'll find out if the one I'm using is okay or not I guess.
In the meantime I'm going to put together the mechanics of the second channel, and see if I can break up these lower order harmonics. I'm starting to think I need to re-think the whole mechanical side of the experiment. That's the good thing with talking to you about the electronics involved, it's given me time to really see what was going on with the mechanics of it, and why that was holding back the results.
Thanks again for the brainstorming of my whacky ideas!! Laughing
